Name | Version | License | Source | Languages | Author | Description |
Regulation elements library | 1.0 | GPLv2 | OscadaLibs.db (SQL, GZip) > DAQ.JavaLikeCalc.regEl | en, uk, ru | Roman Savochenko | Regulation elements library of block-schemes of the module DAQ.BlockCalc.
The library is created to provide functions of different control algorithms and it can be used in programmable logic controllers (PLC) based on OpenSCADA for construction control schemes in the module DAQ.BlockCalc. The library is not static, but based on the module JavaLikeCalc, allowing to create calculations on the Java-like language. The functions' names and their parameters are available in languages: English, Ukrainian and mRussian.
To addressing the library functions you can use the static call address DAQ.JavaLikeCalc.lib_regEl.{Func}() or dynamic SYS.DAQ.JavaLikeCalc["lib_regEl"]["{Func}"].call(), SYS.DAQ.JavaLikeCalc["lib_regEl"].{Func}()". Where {Func} — function identifier in the library.
For connection the library to a project of the OpenSCADA station you can obtain the database file as:
- supplied with a ready and proper package of the Linux distribution like to "openscada-libdb-main", "openscada-LibDB.Main";
- directly taken for most actual one from the subversion repository and converted to the DB SQLite file in way:
- downloaded for the one attached here.
This obtained file next you can place into the project's database directory of the station and create the database object for the DB module "SQLite", registering the database file in the configuration.
1 PID unified (pidUnif) |
1.0 | GPLv2 | * | en, uk, ru | Roman Savochenko |
Composite-unified analog and pulse PID. At the heart of the regulator is core a standard analog PID controller from the library FLibComplex1 and the implementation of the PWM for the pulse part.
Parameters
Identifier | Parameter | Type | Mode | Hide | Default |
var | Variable | Real | Input | false | 0 |
sp | Setpoint | Real | Input | false | 0 |
max | Scale: maximum | Real | Input | false | 100 |
min | Scale: minimum | Real | Input | false | 0 |
manIn | Manual input | Real | Input | false | 0 |
out | Output (%) | Real | Return | false | 0 |
impQup | Impulse output up | Boolean | Output | false | 0 |
impQdwn | Impulse output down | Boolean | Output | false | 0 |
analog | Analog | Boolean | Input | false | 1 |
auto | Automate | Boolean | Input | false | 0 |
casc | Cascade | Boolean | Input | false | 0 |
Kp | Gain | Real | Input | false | 1 |
Ti | Ti (ms) | Integer | Input | false | 1000 |
Kd | Gain differential | Real | Input | false | 1 |
Td | Td (ms) | Integer | Input | false | 0 |
Tzd | T differential lag (ms) | Integer | Input | false | 0 |
TImpPer | T impulses period (ms) | Integer | Input | false | 5000 |
TImpMin | T minimal impulse (ms) | Integer | Input | false | 500 |
KImpRfact | Impulse rate factor | Real | Input | false | 1 |
Hup | Upper output border (%) | Real | Input | false | 100 |
Hdwn | Neither output border (%) | Real | Input | false | 0 |
Zi | Insensitivity (%) | Real | Input | false | 0 |
followSp | Follow to variable by setpoint into manual | Boolean | Input | false | 1 |
K1 | Coefficient of input 1 | Real | Input | false | 0 |
in1 | Input 1 | Real | Input | false | 0 |
K2 | Coefficient of input 2 | Real | Input | false | 0 |
in2 | Input 2 | Real | Input | false | 0 |
K3 | Coefficient of input 3 | Real | Input | false | 0 |
in3 | Input 3 | Real | Input | false | 0 |
K4 | Coefficient of input 4 | Real | Input | false | 0 |
in4 | Input 4 | Real | Input | false | 0 |
impAnOut | Analog position of impulse regulator | Real | Input | false | 0 |
impAnImit | Analog position imitation | Boolean | Input | false | 0 |
impQupTm | Imp. output up lag for GUI | Integer | Output | false | 0 |
impQdwnTm | Imp. output down lag for GUI | Integer | Output | false | 0 |
f_frq | Calc frequency (Hz) | Integer | Input | true | 1 |
f_start | First start | Boolean | Input | true | 0 |
f_stop | Last start | Boolean | Input | true | 0 |
int | Integral accumulation | Real | Output | true | 0 |
dif | Differential accumulation | Real | Output | true | 0 |
lag | Lag accumulation | Real | Output | true | 0 |
impLag | Impulse lag time | Real | Output | true | 0 |
perLag | New impulse generation time | Real | Output | true | 0 |
2 PID dynamic (pidUnifD) |
Completely identical to the unified PID-regulator, but it is implemented dynamically on JavaLikeCalc. The dynamic implementation allows you to easily adapt the regulator to the desired requirements, simply editing it.
Parameters
QO | Opened state of the control mechanism | Boolean | Input | false | 0 |
QZ | Closed state of the control mechanism | Boolean | Input | false | 0 |
impAnOut | Real analog position of impulse regulator, [0...100], -1 - disable | Real | Input | false | 0 |
impAnImit | Full stroke time for analog position imitation, s | Boolean | Input | false | 0 |
integ | Integral accumulation | Real | Output | true | 0 |
difer | Differential accumulation | Real | Output | true | 0 |
dlag | Differential lag accumulation | Real | Output | true | 0 |
3 PID pulse (pidImp) |
Specialized pulse PID regulator is implemented on a special algorithm with compensation of double integration.
Parameters
outPID | PID output | Real | Output | false | 0 |
Ki | Gain integer | Real | Input | false | 1 |
err1 | Error step back | Real | Output | true | 0 |
err2 | Error two step back | Real | Output | true | 0 |
