This page contains changes which are not marked for translation.
Single-board computers Orange Pi
Begin: 04 (April) 2017
Participants: Roman Savochenko
Description: "Orange Pi" is a single-board computers related to Raspberry Pi ones but much cheaper sometimes.
Materials: http://ftp.oscada.org/OpenSCADA/Devices/OrangePi
Features:
  • Positive: small size, cost about 7$, nearly of RPi3 performance, minimal power consumption about 0.9W, abundant for IO, Audio Input.
  • Negative: slower compare to RPi for WLAN, GPIO (up to four times).
Means and tips:
  • [7533.11.06/2026.01]: Onboard WLAN disabled finally as unstable one.
  • [7533.05.25/2025.07]: Observed the device hang only in WLAN or completely after 10 days of running, which specified as overheating the WLAN chip and resolved by covering also the chip by the generic heatsink.
  • [7533.05.20/2025.07]: I2C correctly work only the second on /dev/i2c-1 when the first doesn't work seems due to support by modern kernels only devices from ones based on the H3 chip.
  • [7533.05.15/2025.07]: After updating to kernel 6.12.30 there is no need in the overlay "cpu-clock-1.3GHz-1.3v".
  • [7531.01.04/2023.03]: Updated to Armbian 23.02 Bullseye. The modern firmware switches the CPU frequency to 1.008 GHz by default and due to decreasing the CPU powering down to 1.2 V. So, to return the powering we need to append the variable "overlays" by the value "cpu-clock-1.3GHz-1.3v" in the file "/boot/armbianEnv.txt", and that won't raise the minimum power consumption.
Parameters: Orange Pi Zero
Hardware platform: Cortex-A7 (ARMv7)
Central processor: H2 Cortex-A7 H.265/HEVC 1080P, 1.2GHz, 4 Cores
Memory: 256MB/512MB DDR3 SDRAM
Solid memory: µSD, optional SPI NOR Flash on board
Video subsystem: Mali400MP2 GPU @600MHz
Audio subsystem: integrated to CPU
Electrical power: DC 5V DC-IN via µUSB or pin headers or PoE
Interfaces: 3xUSB Host, 1xUSB OTG, Ethernet 10/100M POE, WiFi 802.11 b/g/n, TV out, microphone, stereo line-out, 3xUART, 2xSPI, 2xI2C
Weight: 26 g.
Size: 48 × 46 × 17 mm
Hardware CPU Entry into JavaLikeCalc, us Operation sin(Pi) [in JavaLikeCalc], us Operation pow(Pi,2) [in JavaLikeCalc], us Model AGLKS [Vision, main mnemo], %(core) Extra tests and notes
Orange Pi Zero ARM Cortex-A7, Allwinner H2(+), 40nm, 1.2 GHz, 4 Cores 0.616 0.489 [0.554] 0.625 [0.734] ** - Updated: 04.03.2023
Minimum power consumption (on 240MHz): 0.89W, 1.02W(+Eth), 1.15W(+WIFI)
Performance for 1.29W, 240MHz: GPIO 1.2us
RT: The realtime policies SCHED_RR and SCHED_OTHER are completely missing
For working with the board there firstly were used a special distributive Armbian "Jessie". As builds of OpenSCADA there used the packages repository, mostly for the generic architecture ARMHF for which performs regular building of OpenSCADA by the Automatic Builder of OpenSCADA into the cross-compiling environment.
The board provides many low level buses (3xUART, 2xSPI, 2xI2C) despite its small size, and restricted GPIO in 16 pins which mostly used by the buses. The buses are standard ones but GPIO is a specific one and for that there was implemented special support in the available module DAQ.GPIO making it more unified one.
1 GPIO
2x13 Header
1 3.3V 2 5V
3 TWI0_SDA / PA12 / GPIO12 4 5V
5 TWI0_SCK / PA11 / GPIO11 6 GND
7 PWM1 / PA06 / GPIO6 8 UART1_TX / PG06 / GPIO198
9 GND 10 UART1_RX / PG07 / GPIO199
11 UART2_RX / PA01 / GPIO1 12 SIM_CLK/PA_EINT7 / PA07 / GPIO7
13 UART2_TX / PA00 / GPIO0 14 GND
15 UART2_CTS / PA03 / GPIO3 16 TWI1-SDA / PA19 / GPIO19
17 3.3V 18 TWI1-SCK / PA18 / GPIO18
19 SPI1_MOSI / PA15 / GPIO15 20 GND
21 SPI1_MISO / PA16 / GPIO16 22 UART2_RTS / PA02 / GPIO2
23 SPI1_CLK / PA14 / GPIO14 24 SPI1_CS / PA13 / GPIO13
25 GND 26 SIM_DET/PA_EINT10 / PA10 / GPIO10
1x13 Header
1 5V
2 GND
3 USB-DM2
4 USB-DP2
5 USB-DM3
6 USB-DP3
7 LINEOUTR
8 LINEOUTL
9 TV-OUT
10 MIC-BIAS
11 MIC1P
12 MIC1N
13 CIR-RX
LEDs
Name GPIO
Red LED PA17
Green LED PL10
2 Links
