Name | Founded | Status |
OpenSCADA adaption to the software platform "Android" | February 2017 | Implemented in these packages of the irregular building by Roman Savochenko for the branch Work and LTS:
Automatic Builder of OpenSCADA | May 2015 |
Implemented in the building (2) and syncing (1) scripts, building for up to 100 targets by: CHROOTs of the Linux repositories, VPS and different sub-environments. As the result of the Builder work is: the fresh and signed packages repositories of Linux, Live disk images and other binary archives of OpenSCADA. |
Server and hosting infrastructure of the OpenSCADA project | Jun 2014 | Implemented and exploiting now to store and present those and many other resources of the OpenSCADA project. |
Automation Linux distributive of the project OpenSCADA | Mar 2012 | Implemented in these repositories of the Automation Linux distributive and these Live Builds are provided now for the branch Work and LTS:
OpenSCADA generic embedding and programmable logical controllers (PLC). OpenSCADA adaption to the hardware platform ARM. | October 2008 | Implemented in many embedded solutions and continued to be implement in new ones, is appended for:
Generic conception of the Visual Control Area (VCA) | 2006 | Implemented into: UI.VCAEngine, UI.Vision, UI.WebVision |
Archiving of the values of continuous processes of OpenSCADA | 2006 | Implemented in the module FSArch and DBArch. |
Logical level of parameters of OpenSCADA | 2006 | Implemented in templates of the subsystem DAQ, the module LogicLev, Siemens, ModBus. |
Programming environment of the project OpenSCADA | 2006 | Implemented in the module JavaLikeCalc, BlockCalc and the OpenSCADA object API of user programming. |
Diploma project of developing of a programming environment of the project OpenSCADA for chemical-technological processes | Dec 2005 | Done. Sub-laid in the base of the sub-project "Programming environment of the project OpenSCADA". |
Diploma project of developing of the visualization subsystem for the control system of technological processes OpenSCADA | Dec 2005 | Done |
Materials of the OpenSCADA project of it implementation official starting | 2003 | Was used in the project implementation |
Initial technical task of the OpenSCADA project, DIYA Ltd | 2002 | Was used in the project implementation |
