Serial Interface with usb-rs232 converter
Сообщение создано: 02. 02. 2011 [22:17]
gustavo
Gustavo Duarte
Зарегистрирован(а) с: 02.02.2011
Hi all,
We need use Serial Interface to get and send data from and to external device. The server in which openScada is running doesn't has serial port, only usb. For this reason we have to use a usb to rs-232 converter.
Before try with OpenScada, we tested the converter writing and reading to and from /dev/ttyUSB0 device, using a shell script and loop tx and rx pin. And all work fine.
However when we try to configure Serial Interface using GUI OpenSacada, first we set Address: /dev/ttyUSB0:2400:8N1:s and then when we do click for activate, the GUI become as darkness and freeze until we disconnect the converter from USB port.
Somebody know if OpenScada support serial interface with usb-rs-232 converter ?
Thanks in advance.
Сообщение создано: 03. 02. 2011 [09:24]
Possible you have like that problem http://oscada.org/ru/forum/posts/otslezhivanie_oshibok/ne_mogu_prisoedinit_ovenovskii_preobrazovatel_ac4_usb .
And equal for that, I have not any USB->RS-232(485) device for test and I have not any like problem for any other USB->GSM devices.
For like that specifical problems you can:
- Take sources of work version from SVN, add trace messages, build and detect where serial port init command is wrong for that device.
- Or take technical support here: http://oscada.org/en/services/technical-support
Сообщение создано: 03. 02. 2011 [21:32]
gustavo
Gustavo Duarte
Thanks Roman,
We will try downloading sources and add debug messages.
We let to know results.
Regards.
Сообщение создано: 04. 02. 2011 [10:13]
The problem like for that: http://mhonarc.axis.se/dev-etrax/msg07432.html.
And I am some updated Serial transport for port init made using previous properties and allow for miss any port properties set. Last SVN-snapshot already have the changes.
Сообщение создано: 05. 02. 2011 [13:44]
gustavo
Gustavo Duarte
Thanks Roman, I could see your updated in "Checked out revision 1256". I will compile again and try and then will let to know results.
Regards.
Сообщение создано: 07. 02. 2011 [15:05]
gustavo
Gustavo Duarte
Regards.
After compile last SVN-snapshot version, I made attemp again, and the result was the same.
When I do click to run in serial port configuration screen, openscada became freeze until usb-rs232 converter is disconnected.
What is your suggestion ? Analyze serial port message trace ? There are some way to enable message traces or debug mode ? Or we have to add "printf' s" in mod_serial.cpp ?
Thanks in advance.
Gustavo.
Сообщение создано: 07. 02. 2011 [15:49]
Place printf() to the function "void TTrOut::start( )" of the file OpenSCADA/src/moduls/transport/Serial/mod_serial.cpp. And see to where hang is.
Сообщение создано: 08. 02. 2011 [19:51]
gustavo
Gustavo Duarte
I added several printf() at different places of TTtOut::start() and I can see application hang when
fd = open(mDevPort.c_str(), O_RDWR|O_NOCTTY); function is called.
I tried adding O_NONBLOCK flag to open and work fine, oscada did not hang.
However I think that the problem is that driver of usb-serial converter is not work properly.
Because, I was the following test:
1) Start, server.
2) Try run port serial and oscada hung.
3) Add O_NONBLOCK flag, try again run port serial and work fine.
4) Remove O_NONBLOCK flag, and try run port serial and also work fine.
As you could see this is very strange, I can find out an explication, only that the usb-serial coverter driver is not working properly.
Thanks.
Сообщение создано: 08. 02. 2011 [19:58]
gustavo
Gustavo Duarte
1) Start, server.
Thanks.
I think that I was not clear enough in my last post. My opinion is that the problem is in usb-serial converter. Openscada work fine.
Thanks and sorry.
Сообщение создано: 09. 02. 2011 [10:19]
OK. I will place O_NONBLOCK to function open() and you please test for permanent work it.
22187
