OpenSCADA
Documents/How to/Debug
If you strictly follow the Quick Start manual then you will not encounter any problems, but if you do something yourself then you may need some debugging. OpenSCADA provides extensive opportunities for debugging and identifying programming problems in the overall OpenSCADA user space and the problems of OpenSCADA itself and its parts.
Basic approaches to custom debugging include:
Basic debugging mechanisms have been expanded in the latest versions of OpenSCADA for the subject:
1 Debugging the current execution context
This method of debugging involves monitoring values of the variables of the execution context, including the addition of intermediate values, for detail.
Current execution context of DAQ procedures you can observe into a proper page of the object of the execution context, like: the tab "Attributes" of the Logic Level parameter (Fig. 1), the tab "Calculation" of the Java-like based calculator (Fig. 2) and so on. To append some interim values you can temporary append (or set as an read-only attribute) and link some attributes to the template or append and link some IO to the function.
Fig. 1. Tab "Attributes" of the Logic Level parameter.
Fig. 2. Tab "Calculation" of the Java-like based calculator.
Current execution context of the VCA procedures (procedures of the widgets) you can observe on the tab "Attributes" of the proper page or widget of the session of the executed now project (Fig. 3). To append some interim values you can temporary append and link several attributes to the widget/page.
Fig. 3. Tab "Attributes" of a page or widget of the session of the executed now project.
2 Debugging the execution sequence
That debugging method means placing and/or enabling debugging messages and next their observing into the generic interface of the messages archiving and observing (Fig. 4) or into the interface proper to the OpenSCADA part:
Fig. 4. Generic messages archiving and observing interface.
Fig. 5. Tab "Diagnostics" of a controller object of a data source.
Fig. 6. Tab "Diagnostics" of a project object of VCA into the configurator.
Fig. 7. Tab "Diagnostics" of project properties of the development mode of UI.Vision.
To append messages in debug or other levels to your procedures you can use next functions:
At.png The debugging messages (the suffix is "Debug" or the level is 0), on the last versions of OpenSCADA, will be allowed to observe only after the debugging enabled: the field "Least level" set to "Debug (0)" (Fig. 8) and check category(es) of the messages (Fig. 9), for the details read here! The debugging messages enabling and disabling allows you to include the debug messages permanently into the procedures with the proper category of the place. All other, not debug, messages will show anytime, for levels more or equal to the globally set (Fig. 8). Some messages, as VCA-Events, will be also enabled with that mechanism!
Fig. 8. Field "Least level" set to "Debug (0)".
Fig. 9. Select categories of nodes for debugging and debugging messages.
At.png The internal or system parts of the controller object of the data source are enabled independently for diagnostics by setting the "Level" property to "Debug (0)" on the appropriate diagnostic interface (Fig. 5).
Documents/How_to/Debug/en - GFDLMarch 2026OpenSCADA 0.9.9
