Wago PLCs
Повідомлення створено: 29. 02. 2024 [13:43]
Aksels
Axel Spallek
Зареєстрован(а) с: 29.02.2024
Повідомлення: 3
Hi,
I would like to use OpenScada to get Data from several PLCs (Wago 750-890).
Wago has Modbus-TCP-Support.
I tried to set up a connection in OpenScada, although I did not find any examples I assumed, that the IP-Adress should be entered in TransportAddress.
In the Datanode I entered R:12298:R:var1:Variable1 bit I always get an error.
Where sould I put the IP-Adress?
Is the syntax of the Attribute correct?
Sincerely,
Aksels
Повідомлення створено: 29. 02. 2024 [18:55]
Whether the Quick Start manual is not examples?
How about the tooltip and the module manual?
Повідомлення створено: 01. 03. 2024 [09:52]
Aksels
Axel Spallek
Повідомлення: 3
Good morning.
I apologize for writing too quickly in the forum. But my customer wants a solution real quick. If I can convince him of using OpenScada I would like to pay you for your effort.
I have a meeting today at 11:00 am with that customer and I am trying to get a working example for him.
With your help (reminding me kindly of reading thoroughly and beeing precise) I managed to get an integer data correctly from a life plc.
Thank you very much.
Now I try to visualize that value.
I will report back..
Sincerely,
Aksels
Повідомлення створено: 01. 03. 2024 [11:45]
Aksels
Axel Spallek
Повідомлення: 3
Hi.
Is it possible to get different pages for every user?
So user1 logs in and gets only page1 and user2 gets page2?
Sincerely,
Aksels
[Повідомлення редагувалось 1 раз(ів), останній раз 01.03.2024 в 11:45.]
Повідомлення створено: 01. 03. 2024 [13:32]
Live Disks mentioned in Qiuck Start are very quick! :)
Which exactly? You pay here just for efforts I provide you right now
That is again just the Live Disks!
You can create SOs with different pages for different users, where one user will not access to pages of other, also you can place all elements both of them and set different access for the elements, you can generate the page completely dynamic and so on...
54196
