[TaskDone] Creation an automation Linux distributive based on OpenSCADA
Повідомлення створено: 26. 09. 2012 [17:08]
Base: Demo and fast deployment distribution need
Funding: nope
Begin: 01.03.2012
Priority: middle
State: Mostly done.
Project page: http://oscada.org/wiki/Special:MyLanguage/Sub-projects/Automation_Linux_distributive
Repository: Based on Debian 8 (ftp://ftp.oscada.org/Debian/8), previous version based on ALTLinux T6 (ftp://ftp.oscada.org/ALTLinux/t6)
Live disk: Work, LTS
(+) Build local and adaptation TDE 3.5.13.
(+) Place TDE 3.5.13 build to ALTLinux Sisyphus.
(+) Place TDE 3.5.13 build to ALTLinux T6.
(+) Build universal LiveDisk based on ALTLinux-T6, TDE-3.5.13, OpenSCADA 0.8.0.3
(+) Stabilization and fixing TDE-3.5.13 and all LiveDisk environment.
(+) First try live-build of Debian.
(+) Create the Live Disk configuration with OpenSCADA 0.9 Work and TDE R14.
(+) Create Live Disk configuration with OpenSCADA 0.9 Work and TDE R14.
(+) Start apt-cacher on the new server for guaranty uninterruption the Live Disk building process by impossibility to an interruption continue.
(+) Adapt TDE R14 for live-build: create task-tde-desktop; adapt live-config-trinity
(+) Add language selection and approve for the Live disk.
(+) Add and test the installation.
(-) Some OpenSCADA branding creation.
Повідомлення створено: 08. 10. 2012 [10:08]
TDE-3.5.13 processing history (deprecated):
28.08.2012 kmix: Capture mixer's knob processing is fixed (http://bugs.pearsoncomputing.net/show_bug.cgi?id=1190).
30.08.2012 krusader: Chdir for copy into krarc is fixed for Cyrillic and generic UTF-8. Problem rar adding option "-r" is removed for prevent hang and scan source directory.
07.09.2012 compiz: kde3 — kde-window-decorator build is reverted.
06.10.2012 Adapting and build "kdegames".
Deprecated,07.10.2012 Adapting and build "SMB4K-0.9.9". For now need util "umount.cifs" which is not present into ALTLinux repository — need it replace.
15.10.2012 TDE-3.5.13.1 building: ftp://ftp.oscada.org/OpenSCADA/0.8.0/ALTLinux/Live and ftp://ftp.oscada.org/OpenSCADA/Work/ALTLinux/Live
08.12.2012 Fix "drkonqui" failure. Crash after mediamanger apply for kill block application is fixed. Media baseurl encoding patch is restored. Fuser call is fixed for cyrillic symbols into mount point, actually for CD/DVD disks. For correct fuser work need psmisc version 22.20.
31.12.2012 "KJobViewer" memory leak and some time crash on TDE session close (http://bugs.pearsoncomputing.net/show_bug.cgi?id=1369).
02.2013 Aid for observing and fix "kdesktop_lock" crashes or hangs (http://bugs.pearsoncomputing.net/show_bug.cgi?id=1288).
02.2013 Aid for observing and fix "smserver" crash at exit, for openned "kaffeine", (http://bugs.pearsoncomputing.net/show_bug.cgi?id=1394).
04.2013 Made "hal" adapting for work with new udev(systemd), patch fo ALTLinux.
07.2013 TDE 3.5.13.2 SRU build for ALTLinux.
08.2013 NetworkManager on GTK3 working into TDE system tray some fix.
09.2013 Koqueror and related icons list crash fix.
12.2013 KJobViewer crash at exit is fix.
02.2014 KJobViewer start to system tray at the system start.
Deprecated: Select user's images pattern into KDM.
Повідомлення створено: 09. 07. 2015 [10:35]
TDE-R14 processing history:
05.08.2015 Ark,Krusader: Cyrillic locale into ZIP archives fix — built packages libnatspec and unzip with the library.
25.07.2015 KJobViewer: Apply patches from ALTLinux-TDE for allow that start to system tray at the system start.
02.2016 tdelibs, tdebase rebuild at version TDE 14.0.4 release.
06.2017 KMix working with PulseAudio as master device was fixed and expanded for generic control from KMilo by DCOP.
06.2017 Qt3, TDELibs: Were expanded for brightness keys support.
06.2017 KMilo: Was fixed for launch keys and expanded for sound volume control through real master device of KMix and for brightness control through DCOP to TDEPowerSave.
05.2019 KRfb: Impossible to key enter in locales different to EN and disabling for keys layouts.
Повідомлення створено: 11. 07. 2017 [16:05]
Debian 9 adaption history:
24.06.2017 Create chroots for platforms x86, x86_64. Start OpenSCADA building for Debian 9, for 0.9 Work and 0.8 LTS.
08.07.2017 Start Live Disks building for Debian 9, manually.
22.07.2017 Place building of the Live Disks to the automatic builder: create Debian 9 VPS on OpenSCADA server; append the Live Disks building exclusively into the VPS but there are some problems into building Debian7 disks by new live-builder.
Known problems:
07.2018 Starting error on AMD A8-6500APU (Radeon HD 8570D) — rebooting once trying to load the module "radeon" with current firmwares into the package "firmware-amd-graphics", into the initial image of the kernel.
Повідомлення створено: 12. 04. 2025 [17:58]
All other actions are registered only on the project page: http://oscada.org/wiki/Special:MyLanguage/Sub-projects/Automation_Linux_distributive
16318
