Is there a plan to support the IEC61850?
Сообщение создано: 09. 05. 2019 [11:41]
lygoflying
Lee younger
Зарегистрирован(а) с: 09.05.2019
Hi,
I found IEC80670 was supported by openscada 0.9.
Is there a plan to support the IEC61850?Or how can I implement IEC61850 at the current version?
by the way,library for IEC 61850 can be downloaded on the website -- https://libiec61850.com/libiec61850/downloads/.
Thank you very much for your attention and answer!
Best Regards
[Сообщение редактировалось 1 раз(а), в последний раз 09.05.2019 в 12:07.]
Сообщение создано: 09. 05. 2019 [12:21]
See in To do.
Сообщение создано: 09. 05. 2019 [19:44]
lygoflying
Lee younger
See in To do.
Thank you for your reply.
I have a uncertainty that the page of "To do" show the modules of DAQ and transport protocol for MMS and IEC 60850 will be created instead of IEC18650. It's meaning that IEC61850 will not be developed temporarily.
Looking forward to your reply.Thank you!!!
the part of To Do .PNG (Тип файла: image/png, Размер: 13.09 килобайт) — 2419 загрузок
Сообщение создано: 09. 05. 2019 [20:01]
This is meant, I will finish the IEC 60850 implementation into the present module "MMS", as the top layer above MMS (IEC-9506), once I will need that, or somebody other will order these functions:
- add for sessions support, optionally;
- implement IEC-60850 and test with "libiec60850".
7323
