OpenSCADA
Libs/Service procedures
Name Version License Source Languages Author Description
Service procedures library 1.2 GPLv2 OscadaLibs.db (SQL, GZip) > DAQ.JavaLikeCalc.servProc en, uk, ru Roman Savochenko Library of the service procedures of different application.
  • Founded: November 2017
  • Initially created: in the old Wiki
  • Used by: different OpenSCADA processes
The library is created to provide service functions of performing service tasks about the OpenSCADA environment. The library is not static, but based on the module JavaLikeCalc, allowing to create calculations on the Java-like language. The functions' names and their parameters are available in languages: English, Ukrainian and mRussian.
To addressing the library functions you can use the static call address DAQ.JavaLikeCalc.lib_servProc.{Func}() or dynamic SYS.DAQ.JavaLikeCalc["lib_servProc"]["{Func}"].call(), SYS.DAQ.JavaLikeCalc["lib_servProc"].{Func}()". Where {Func} — function identifier in the library.
For connection the library to a project of the OpenSCADA station you can obtain the database file as:
This obtained file next you can place into the project's database directory of the station and create the database object for the DB module "SQLite", registering the database file in the configuration.
1 TEST: Packing of the archiver on FS (archPackFStests)
1.0 GPLv2 * en Roman Savochenko
Tests set for packing of the value archives to File System, to check the optimization algorithm. The stages are provided:
Function parameters
Identifier Name Type Mode Default
tm Start time (14.03.2015 21:37) Integer Input 1426361839
per Period, seconds Integer Input 60
addr Archive address String Input test123
archiver Archiver address String Input FSArch.1m
step Step (0-8), -1 for all Integer Input -1
2 TEST: Release (releaseTests)
2.0 GPLv2 * en Roman Savochenko
Set of formal tests of the OpenSCADA releases:
0: System
1: Security User/Group tests
2: Transport subsystem tests
means presence of the input transports with the name "testRelease[{N}]" and the connected output transport adress into description or address field (if equal one).
3: Protocol subsystem tests
means presence of the controller object DAQ.ModBUS.testTCP.
means presence of the controller object DAQ.OPC_UA.test.
means presence of the user protocol object Protocol.UserProtocol.up_test.
4: Archive subsystem tests
means presence the message archivers "test";
means presence "/DAQ/LogicLev/experiment/F3" with the attribute "ed", and the value archivers "1s"
means presence the archive "testArch_cntr" with the data period 1s and processed by the archiver FSArch.1s.
5: DB subsystem tests
means presence of the test DB with the name "testRelease".
6: DAQ subsystem tests
presence of the DAQ parameter LogicLev.experiment.F3.
presence of the DAQ parameter LogicLev.experiment.F3.var.
presence the DAQ controller object "KM102cntr" for copy the block scheme.
presence the DAQ parameter LogicLev.experiment.F3.var.
7: UI subsystem tests
8: Special subsystem tests
Function parameters
sub Subsystem (-1:All;0:SYS;1:Security;2:Transport;... Integer Input -1
rez Result Text Output
rezF Result for HTML file Text Output
3 CRC 16 (crc16)
Standard Cyclic Redundancy Check (CRC) with free setting the polynomial, by default 0x8005. It isn't actual more by the common common CRC implementing.
Function parameters
in Input String Input
out Result Integer Output
poly Polynomial (reversion) Integer Input 40961
4 Archives recalculation (procArh)
Value archives recalculation.
Function parameters
fromarch From archive String Input Archive.va_ai3_code
toarch To archive String Input Archive.va_ai3_dP
begs Begin time String Input 2006-08-08 9:21:56
ends End time String Input 2006-08-08 11:21:55
5 EXT: WackoWiki to MediaWiki (wacko2media)
1.1 GPLv2 * en Roman Savochenko
Procedure of conversion Wiki-dialect from WackoWiki to MediaWiki. Used and using to move OpenSCADA Wiki to MediaWiki.
Function parameters
ndb MySQL DB id String Input wiki
wpg Wiki page String Input HomePageUk/Doc/SQLite
rez Result Text Return
6 EXT: Off-line documentation (docOffLine)
1.3 GPLv2 * en Roman Savochenko
Procedure of forming the offline documentation of OpenSCADA from Wiki by reading and processing the specified Wiki pages on different languages, currently it is: English, Ukrainian, mRussian.
Function parameters
res Result String Output
reqTr Tries of requests Integer Output 3
resDir Results directory String Input /home/roman/roman/work/Проекти/OpenSCADA/doc/
pages Pages list
Rows in the form "{wiki}:{langs}:{dest}".
Text Input
Documents:en,uk,ru:index.html
Documents/Release_0.9:en,uk,ru:Release_0.9.html
About:en,uk,ru:About.html
Documents/Terms:en,uk,ru:Terms.html
Functions_and_demands:en,uk,ru:Functions_and_demands.html
Works/To_do:en:To_do.html
Documents/FAQ:en,uk,ru:FAQ.html
Documents/Quick_start:en,uk,ru:Quick_start.html
Documents/Program_manual:en,uk,ru:Program_manual.html
Documents/How_to:en,ru,uk:How_to.html
Documents/How_to/Install:en,ru,uk:How_to_Install.html
Documents/How_to/Live_disk:en,ru,uk:How_to_Live_disk.html
Documents/How_to/Violations,_alarms_and_notifications:en,ru,uk:How_to_Violations.html
Documents/How_to/Cyclic_programming:en,ru,uk:How_to_Cyclic_programming.html
Documents/How_to/Debug:en,ru,uk:How_to_Debug.html
Documents/How_to/Transferring_project_configuration:en,ru,uk:How_to_Transferring_project_configuration.html
Documents/How_to/Build_from_source:en,ru,uk:How_to_Build_from_source.html
Documents/How_to/Crash_report:en,ru,uk:How_to_Crash_report.html
Documents/How_to/Create_module:en,ru,uk:How_to_Create_module.html
Documents/DAQ:en,uk,ru:DAQ.html
Documents/User_API:en,uk,ru:User_API.html
Documents/API:en:API.html
Modules/SQLite:en,uk,ru:Modules/SQLite.html
Modules/MySQL:en,uk,ru:Modules/MySQL.html
Modules/FireBird:en,uk,ru:Modules/FireBird.html
Modules/DBF:en,uk,ru:Modules/DBF.html
Modules/PostgreSQL:en,uk,ru:Modules/PostgreSQL.html
Modules/Sockets:en,uk,ru:Modules/Sockets.html
Modules/Serial:en,uk,ru:Modules/Serial.html
Modules/SSL:en,uk,ru:Modules/SSL.html
Modules/SelfSystem:en,uk,ru:Modules/SelfSystem.html
Modules/UserProtocol:en,uk,ru:Modules/UserProtocol.html
Modules/HTTP:en,uk,ru:Modules/HTTP.html
Modules/JavaLikeCalc:en,uk,ru:Modules/JavaLikeCalc.html
Modules/LogicLev:en,uk,ru:Modules/LogicLev.html
Modules/BlockCalc:en,uk,ru:Modules/BlockCalc.html
Modules/DAQGate:en,uk,ru:Modules/DAQGate.html
Modules/System:en,uk,ru:Modules/System.html
Modules/ModBus:en,uk,ru:Modules/ModBus.html
Modules/DCON:en,uk,ru:Modules/DCON.html
Modules/OPC_UA:en,uk,ru:Modules/OPC_UA.html
Modules/SNMP:en,uk,ru:Modules/SNMP.html
Modules/ICP_DAS:en,uk,ru:Modules/ICP_DAS.html
Modules/Siemens:en,uk,ru:Modules/Siemens.html
Modules/DiamondBoards:en,uk,ru:Modules/DiamondBoards.html
Modules/Comedi:en,uk,ru:Modules/Comedi.html
Modules/SoundCard:en,uk,ru:Modules/SoundCard.html
Modules/BFN:en,uk,ru:Modules/BFN.html
Modules/SMH2Gi:en,uk,ru:Modules/SMH2Gi.html
Modules/GPIO:en,uk,ru:Modules/GPIO.html
Modules/FSArch:en,uk,ru:Modules/FSArch.html
Modules/DBArch:en,uk,ru:Modules/DBArch.html
Modules/VCAEngine:en,uk,ru:Modules/VCAEngine.html
Modules/QTStarter:en,uk,ru:Modules/QTStarter.html
Modules/QTCfg:en,uk,ru:Modules/QTCfg.html
Modules/Vision:en,uk,ru:Modules/Vision.html
Modules/WebCfgD:en,uk,ru:Modules/WebCfgD.html
Modules/WebCfg:en,uk,ru:Modules/WebCfg.html
Modules/WebVision:en,uk,ru:Modules/WebVision.html
Modules/WebUser:en,uk,ru:Modules/WebUser.html
Modules/FLibSYS:en,uk,ru:Modules/FLibSYS.html
Modules/SystemTests:en,uk,ru:Modules/SystemTests.html
Modules/FLibMath:en,uk,ru:Modules/FLibMath.html
Modules/FLibComplex1:en,uk,ru:Modules/FLibComplex1.html
pagesCur Current pages list
Rows in the form "{wiki}:{langs}:{dest}", for empty here used "pages".
Text Input
Libs/Service_procedures/en - GFDLJune 2025OpenSCADA 0.9.8
