Is there a plan to support the IEC61850?
Written on: 09. 05. 2019 [11:41]
lygoflying
Lee younger
registered since: 09.05.2019
Hi,
I found IEC80670 was supported by openscada 0.9.
Is there a plan to support the IEC61850?Or how can I implement IEC61850 at the current version?
by the way,library for IEC 61850 can be downloaded on the website -- https://libiec61850.com/libiec61850/downloads/.
Thank you very much for your attention and answer!
Best Regards
[This article was edited 1 times, at last 09.05.2019 at 12:07.]
Written on: 09. 05. 2019 [12:21]
See in To do.
Written on: 09. 05. 2019 [19:44]
lygoflying
Lee younger
See in To do.
Thank you for your reply.
I have a uncertainty that the page of "To do" show the modules of DAQ and transport protocol for MMS and IEC 60850 will be created instead of IEC18650. It's meaning that IEC61850 will not be developed temporarily.
Looking forward to your reply.Thank you!!!
the part of To Do .PNG (File type: image/png, Size: 13.09 kilobytes) — 2031 downloads
Written on: 09. 05. 2019 [20:01]
This is meant, I will finish the IEC 60850 implementation into the present module "MMS", as the top layer above MMS (IEC-9506), once I will need that, or somebody other will order these functions:
- add for sessions support, optionally;
- implement IEC-60850 and test with "libiec60850".
15249
