Повідомлення створено: 09. 03. 2014 [10:07]
snowboy
saman ahmadi
Зареєстрован(а) с: 14.09.2013
Повідомлення: 13
Hi Roman
I like to add new data bases (such as vcaBase) to OpenSCADA and don't use AGLKS.
So, I download those from oscada web site and I try to add them to SQLite. There was no problem in adding data bases But when I closed OpenSCADA and opened it again, there wasn't new data base ! I tried it several times but the problem still remained.
I need your help to solve this problem.
Thanks for your attention.
Best Regards
Saman
Повідомлення створено: 10. 03. 2014 [16:55]
You do not save new DB object, actually.
Or your configuration broken out and used configuration file unavailable for write access.
Повідомлення створено: 10. 03. 2014 [21:21]
snowboy
saman ahmadi
Повідомлення: 13
Is it possible to add new DB to OpenSCADA (via SQLite)?
I opened OpenSCADA as "root" user in order to use Db files of Mnemo and Electronic libraries.
I think root user have write permissions. Isn't it?
[Повідомлення редагувалось 1 раз(ів), останній раз 10.03.2014 в 21:22.]
Повідомлення створено: 11. 03. 2014 [11:28]
Yes, possible, read here: http://wiki.oscada.org/HomePageEn/Doc/QuickStart#h995-8
Yes and then you really do not save the DB object but I have not the problem neither for 0.8.0.9 LTS or 0.9 work version.
Повідомлення створено: 11. 03. 2014 [12:45]
snowboy
saman ahmadi
Повідомлення: 13
I tried again, but I didn't see any save button.
Screenshot of my settings is attached here.
After closing the software, the DB will be disappeared.
Повідомлення створено: 11. 03. 2014 [13:05]
snowboy
saman ahmadi
Повідомлення: 13
Now I understand why I don't see save button.
After adding new DB, if we use "Load system from this DB" button, we can't see any save button in OpenSCADA. In this condition "ctrl+s" also doesn't work.
Therefor I conclude that we must save DB before load system from it.
So the problem is solved
Thanks for your attention :)
