Повідомлення |
Повідомлення створено: 15. 10. 2012 [09:00]
abdullahkhalili
Abdullah Khalili
Зареєстрован(а) с: 08.07.2012
Повідомлення: 5
Hello experts.
I wanted to know that when we want to read a tag from PLC, how it is stored in the data block?
This is done in quickstart using DB Test|[Offset].
I wanted to know where this DB Test is defined and how we can store PLCs tags in it?
Thanks
Повідомлення створено: 15. 10. 2012 [10:58]
Why? OpenSCADA store itself and you typical not need know for DB structure. And what the data block you mean?
Where?
Into or from PLC.
P.S. Maybe you tell what PLC and DAQ module use?
P.P.S. This questions are not bugs!
Повідомлення створено: 20. 10. 2012 [10:25]
abdullahkhalili
Abdullah Khalili
Повідомлення: 5
Hello,
Thanks dear roman
my PLC is Siemens S7-300 and we use the DAQ.Siemens module
please tell me how could read an input of plc (for example i124.0 value)
Thanks
Повідомлення створено: 20. 10. 2012 [17:01]
Copy its to DB, into S7 function or OB, and next read into OpenSCADA.
Повідомлення створено: 21. 10. 2012 [01:06]
abdullahkhalili
Abdullah Khalili
Повідомлення: 5
thanks dear roman,
I am a student and cannot understand your answer, can you please explain with an example for me? :oops:
one of my plc input is i124.0 and output is q124.0 (default siemens tags), in wincc or labview we are adding these I/O in opc da server and with these we can read or write data on PLC, but in openScada i confused, if i can connect to PLC directly by DAQ.Siemens and use in openscada HMI, please give me an example how to configure and add inputs and outputs, if need opc ua, please help me about this, i read openscada document, but confused in adding inputs and outputs
Really Thanks for your answer :-?
[Повідомлення редагувалось 1 раз(ів), останній раз 21.10.2012 в 01:10.]
Повідомлення створено: 21. 10. 2012 [21:00]
WinCC and OPC DA server use official API from Siemens on OS Windows for that, but on Linux OS the library is not available and here used LibnoDave and other CP which have some limits by closed solutions from Siemens GMBH. But direct IO reading by IO_TSAP (Industrial Ethernet) allowed in LibnoDav and not implemented into OpenSCADA, for getting all data used DBs (Data Blocks).
That is no issue for OpenSCADA examples. Take "Step 7", programming PLC, write some program on STL for your PLC for copy IO to DB, and next read typical DBs from OpenSCADA, for that examples see into DemoDB.
Повідомлення створено: 22. 10. 2012 [08:53]
abdullahkhalili
Abdullah Khalili
Повідомлення: 5
Really Thanks Dear Roman, :-?
We are defined a datablock in S7-300 PLC named "DB5" and some variable in that like "a" "b" "c", now how can read that in DAQ.Siemens?
And i have another Question: Where or What is the DemoDB? if DemoDB is AGLKS or not?
As big Thanks for your Answers :oops:
Повідомлення створено: 22. 10. 2012 [09:33]
http://wiki.oscada.org/HomePageEn/Doc/QuickStart
Повідомлення створено: 28. 10. 2012 [08:33]
abdullahkhalili
Abdullah Khalili
Повідомлення: 5
Thank you Dear Roman, we are connected with DAQ.Siemens without any problem, but if we can directly use OPC_UA? for example if output implemented in DAQ.OPC_UA? we are added DAQ.Siemens DB into OPC_UA node list and reading this Data Blocks. but we can not write or change any of that
As Thanks for your answer:-?
Повідомлення створено: 29. 10. 2012 [11:35]
For writing there is real problem, and now I have fixed it.
