[TaskDone] Functions extending of the module OPC-UA
Повідомлення створено: 22. 06. 2010 [19:01]
Base: Plan and Agreements
Component: The "OPC UA" module of “Data acquisition” and “Transport protocols” subsystems
Funding: for move to different LGPL v3 library, Chunks and CreateSubscriptionRequest implementing.
Begin: 7.06.2010
Priority: high
(+) Main secure politics implementation "Base128Rsa15" and "Base256".
(+) 19.08.2013: OPC UA protocol's part for Client and Server is moved to LGPL v3 library for allow and simplify using by other projects.
(+) 19.08.2013: Controller's object is made simply for EndPoints and transports selection and configuration.
(+) 09.12.2013: "Publish" (Subscriptions and MonitoredItems) request processing into the protocol's input part.
(+) Cap for the service RegisterNodeRequest adding
(+) Moving to input protocol's pooling mode instead direct writing and the separated publish processing task. Mostly to simplify.
(+) Authentication support append, for user.
(+) Adapting to B&R Embedded OPC-UA Server specific
(+) Adapting to UAExpert 1.3
(+) Adapting to UAExpert 1.4
(+) Chunks implementation for big requests.
Повідомлення створено: 05. 08. 2025 [15:07]
The task has done mostly in the active development and all other actions you can trace on the DAQ.OPC_UA page!
16260
