Повідомлення створено: 20. 07. 2022 [10:55]
thomas
Thomas Vetter
Зареєстрован(а) с: 19.07.2022
Повідомлення: 1
Hello,
I have build openscada from source on RHEL 8.2 with "configure --disable-PostgreSQL --disable-FireBird --disable-SoundCard".
When I start openscada after installation from cmdline the following error appears:
2022-07-20T03:34:40 3[/sub_ModSched/] Anfangsstation > Module Scheduler: Fehler SO '/usr/lib/openscada/ui_QTStarter.so': /usr/lib/openscada/ui_QTStarter.so: undefined symbol: _ZTVN9QTStarter11StartDialogE
I can't find the undefined symbol in the sources. Maybe it's an internal qt problem. I have installed the following qt5 packages:
[root@openscada openscada_installation]# rpm -qa | grep qt5
qt5-qtbase-common-5.12.5-4.el8.noarch
qt5-qtbase-devel-5.12.5-4.el8.x86_64
qt5-qtbase-5.12.5-4.el8.x86_64
qt5-qtdeclarative-5.12.5-1.el8.x86_64
qt5-qtsensors-devel-5.12.5-1.el8.x86_64
qt5-qtsensors-5.12.5-1.el8.x86_64
qt5-srpm-macros-5.12.5-3.el8.noarch
qt5-qtbase-gui-5.12.5-4.el8.x86_64
qt5-rpm-macros-5.12.5-3.el8.noarch
Any Idea about the reason for the problem ?
Here are some additional information:
./configure --disable-PostgreSQL --disable-FireBird --disable-SoundCard
* Status:
- To enable (yes), to include/builtin (incl), for a distributive (dist), to disable (no) all modules = individual
- Cross compilation = no
- The core library compilation only in static = no
* Generic features:
- Strings charset encode support (by iconv) = yes
- LibGD forcing for the core and the modules = no
- Compilation modules of the sunsystems:
"DB": SQLite MySQL DBF DBGate
"DAQ": JavaLikeCalc LogicLev BlockCalc DAQGate System ModBus DCON OPC_UA SNMP Siemens AMRDevs
"Archive": FSArch DBArch
"Transport": Sockets Serial SSL
"Transport's protocol": SelfSystem UserProtocol HTTP
"UI": VCAEngine QTStarter QTCfg Vision WebCfg WebCfgD WebVision WebUser
"Special": FLibSYS SystemTests FLibMath FLibComplex1
- Including/builtin modules to the OpenSCADA core:
* Features of some specific modules:
- FFTW3 to obtain spectrum of signal:
- Library of the Linux sensors: -lsensors
- Web-browser's engine WebKit:
- Media player's engine:
[root@openscada ~]# openscada
2022-07-20T03:34:40 1[/] Anfangsstation: Laden.
2022-07-20T03:34:40 1[/sub_BD/] Anfangsstation > Datenbank: Modul 'SQLite' Verbindung.
2022-07-20T03:34:40 1[/sub_BD/] Anfangsstation > Datenbank: Modul 'MySQL' Verbindung.
2022-07-20T03:34:40 1[/sub_BD/] Anfangsstation > Datenbank: Modul 'DBF' Verbindung.
2022-07-20T03:34:40 1[/sub_BD/] Anfangsstation > Datenbank: Modul 'DBGate' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'JavaLikeCalc' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'LogicLev' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'BlockCalc' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'DAQGate' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'System' Verbindung.
2022-07-20T03:34:40 1[/sub_Protocol/] Anfangsstation > TransportProtokolle: Modul 'ModBus' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'ModBus' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'DCON' Verbindung.
2022-07-20T03:34:40 1[/sub_Protocol/] Anfangsstation > TransportProtokolle: Modul 'OPC_UA' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'OPC_UA' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'SNMP' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'Siemens' Verbindung.
2022-07-20T03:34:40 1[/sub_DAQ/] Anfangsstation > Datenerfassung: Modul 'AMRDevs' Verbindung.
2022-07-20T03:34:40 1[/sub_Archive/] Anfangsstation > Archiv-Geschichte: Modul 'FSArch' Verbindung.
2022-07-20T03:34:40 1[/sub_Archive/] Anfangsstation > Archiv-Geschichte: Modul 'DBArch' Verbindung.
2022-07-20T03:34:40 1[/sub_Transport/] Anfangsstation > Übertragungen: Modul 'Sockets' Verbindung.
2022-07-20T03:34:40 1[/sub_Transport/] Anfangsstation > Übertragungen: Modul 'Serial' Verbindung.
2022-07-20T03:34:40 1[/sub_Transport/] Anfangsstation > Übertragungen: Modul 'SSL' Verbindung.
2022-07-20T03:34:40 1[/sub_Protocol/] Anfangsstation > TransportProtokolle: Modul 'SelfSystem' Verbindung.
2022-07-20T03:34:40 1[/sub_Protocol/] Anfangsstation > TransportProtokolle: Modul 'UserProtocol' Verbindung.
2022-07-20T03:34:40 1[/sub_Protocol/] Anfangsstation > TransportProtokolle: Modul 'HTTP' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/] Anfangsstation > Benutzerschnittstellen: Modul 'VCAEngine' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/] Anfangsstation > Benutzerschnittstellen: Modul 'QTCfg' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/] Anfangsstation > Benutzerschnittstellen: Modul 'Vision' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/] Anfangsstation > Benutzerschnittstellen: Modul 'WebCfg' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/] Anfangsstation > Benutzerschnittstellen: Modul 'WebCfgD' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/] Anfangsstation > Benutzerschnittstellen: Modul 'WebVision' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/] Anfangsstation > Benutzerschnittstellen: Modul 'WebUser' Verbindung.
2022-07-20T03:34:40 1[/sub_Special/] Anfangsstation > Zusätze: Modul 'FLibSYS' Verbindung.
2022-07-20T03:34:40 1[/sub_Special/] Anfangsstation > Zusätze: Modul 'SystemTests' Verbindung.
2022-07-20T03:34:40 1[/sub_Special/] Anfangsstation > Zusätze: Modul 'FLibMath' Verbindung.
2022-07-20T03:34:40 1[/sub_Special/] Anfangsstation > Zusätze: Modul 'FLibComplex1' Verbindung.
2022-07-20T03:34:40 1[/sub_UI/mod_VCAEngine/wlb_originals/] Anfangsstation > Benutzerschnittstellen > VCAEngine: Widgetsbibliothek einschalten.
2022-07-20T03:34:40 1[/] Anfangsstation: Starten.
2022-07-20T03:34:40 1[/] Anfangsstation: Starten abgeschlossen ist!
[root@openscada ~]# ldd /usr/lib/openscada/ui_QTStarter.so
linux-vdso.so.1 (0x00007fffef9f7000)
liboscada.so.4 => /usr/lib/liboscada.so.4 (0x00007f7f54ec5000)
libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f7f54c54000)
libz.so.1 => /lib64/libz.so.1 (0x00007f7f54a3d000)
libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007f7f54814000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f7f54610000)
libQt5PrintSupport.so.5 => /lib64/libQt5PrintSupport.so.5 (0x00007f7f5577c000)
libQt5Widgets.so.5 => /lib64/libQt5Widgets.so.5 (0x00007f7f53f8d000)
libQt5Gui.so.5 => /lib64/libQt5Gui.so.5 (0x00007f7f53a65000)
libQt5Sensors.so.5 => /lib64/libQt5Sensors.so.5 (0x00007f7f55738000)
libQt5Core.so.5 => /lib64/libQt5Core.so.5 (0x00007f7f5354c000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f7f531b7000)
libm.so.6 => /lib64/libm.so.6 (0x00007f7f52e35000)
libc.so.6 => /lib64/libc.so.6 (0x00007f7f52a73000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f7f5285b000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f7f5263b000)
/lib64/ld-linux-x86-64.so.2 (0x00007f7f555ce000)
libGL.so.1 => /lib64/libGL.so.1 (0x00007f7f523a8000)
libpng16.so.16 => /lib64/libpng16.so.16 (0x00007f7f52173000)
libharfbuzz.so.0 => /lib64/libharfbuzz.so.0 (0x00007f7f51ecd000)
libsystemd.so.0 => /lib64/libsystemd.so.0 (0x00007f7f51b89000)
libicui18n.so.60 => /lib64/libicui18n.so.60 (0x00007f7f516c8000)
libicuuc.so.60 => /lib64/libicuuc.so.60 (0x00007f7f51306000)
libicudata.so.60 => /lib64/libicudata.so.60 (0x00007f7f4f75c000)
libpcre2-16.so.0 => /lib64/libpcre2-16.so.0 (0x00007f7f4f4e3000)
libgthread-2.0.so.0 => /lib64/libgthread-2.0.so.0 (0x00007f7f4f2e1000)
libglib-2.0.so.0 => /lib64/libglib-2.0.so.0 (0x00007f7f4efc8000)
libGLX.so.0 => /lib64/libGLX.so.0 (0x00007f7f4ed96000)
libX11.so.6 => /lib64/libX11.so.6 (0x00007f7f4ea52000)
libXext.so.6 => /lib64/libXext.so.6 (0x00007f7f4e83f000)
libGLdispatch.so.0 => /lib64/libGLdispatch.so.0 (0x00007f7f4e583000)
libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007f7f4e2c7000)
libgraphite2.so.3 => /lib64/libgraphite2.so.3 (0x00007f7f4e09b000)
librt.so.1 => /lib64/librt.so.1 (0x00007f7f4de92000)
liblzma.so.5 => /lib64/liblzma.so.5 (0x00007f7f4dc6b000)
liblz4.so.1 => /lib64/liblz4.so.1 (0x00007f7f4da54000)
libcap.so.2 => /lib64/libcap.so.2 (0x00007f7f4d84e000)
libmount.so.1 => /lib64/libmount.so.1 (0x00007f7f4d5f4000)
libgcrypt.so.20 => /lib64/libgcrypt.so.20 (0x00007f7f4d2d8000)
libgnutls.so.30 => /lib64/libgnutls.so.30 (0x00007f7f4cf1c000)
libxcb.so.1 => /lib64/libxcb.so.1 (0x00007f7f4ccf3000)
libbz2.so.1 => /lib64/libbz2.so.1 (0x00007f7f4cae2000)
libblkid.so.1 => /lib64/libblkid.so.1 (0x00007f7f4c890000)
libuuid.so.1 => /lib64/libuuid.so.1 (0x00007f7f4c688000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f7f4c45d000)
libgpg-error.so.0 => /lib64/libgpg-error.so.0 (0x00007f7f4c23c000)
libp11-kit.so.0 => /lib64/libp11-kit.so.0 (0x00007f7f4bf09000)
libidn2.so.0 => /lib64/libidn2.so.0 (0x00007f7f4bceb000)
libunistring.so.2 => /lib64/libunistring.so.2 (0x00007f7f4b96a000)
libtasn1.so.6 => /lib64/libtasn1.so.6 (0x00007f7f4b757000)
libnettle.so.6 => /lib64/libnettle.so.6 (0x00007f7f4b51e000)
libhogweed.so.4 => /lib64/libhogweed.so.4 (0x00007f7f4b2ee000)
libgmp.so.10 => /lib64/libgmp.so.10 (0x00007f7f4b056000)
libXau.so.6 => /lib64/libXau.so.6 (0x00007f7f4ae52000)
libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007f7f4abce000)
libffi.so.6 => /lib64/libffi.so.6 (0x00007f7f4a9c5000)
[root@openscada ~]#
Regards
Thomas
Повідомлення створено: 20. 07. 2022 [11:48]
Повідомлення: 3742
What a problem in use the ready packages for CentOS 8 ?
Build and install packages!
You have a mixed installation from building different OpenSCADA versions due to such symbol is missing in both actual LTS and Work branches!
