[TaskDone] The knowledge base moving to a new Wiki engine
Повідомлення створено: 01. 08. 2017 [21:11]
Base: Road map
Funding: nope
Begin: 21.12.2015
Priority: high
Complexity: high and long term
State: The same moving are mostly done. During using: migration, updating, appending and translation.
Participants: Roman Savochenko (common work)
Objective Actual knowledge base (on WackoWiki) moving to a new Wiki engine on MediaWiki but the previous Wiki mostly deprecated and has more limitations and inconveniences and it is a condition of OpenSCADA 0.9 LTS releasing.
Estimation [Wacko,Media]:
10*[10,5] compatibility or simplicity for the original Wiki content migration — a procedure "wacko2media" into OpenSCADA was created to simplify the migration for most syntax specific;
9*[0,10] multilanguage from box;
8*[0,10] UTF-8;
9*[8,10] big page's content;
9*[8,10] subpages including;
5*[3,5] correct searching;
4*[2,5] correct the syntax highlight for source texts;
4*[2,10] provides template/skeleton pages for include as IFRAME into TYPO3, test on FAQ and also for OpenSCADA.
4*[3,7] easy for print-ready documentation generation from Wiki, see to different tools: export through LaTEX, asciidoc, pandoc, DocBook;
Summary: [287,513]
21.12.2015 MediaWiki test deploy
20.07.2017 MediaWiki final configuration and preparing to migration
30.07.2017 A new clean structure of the Wiki creation
01.09.2017 Main pages migration, updating, appending and translation for: Home, About, Work, Work/Road map, Functions and demands, Using
01.08.2017 Cross-linking between old and new Wikis. Switching to the new Wiki on the main site.
01.08.2017 Try and work-out of using articles of the Wiki on the main site.
09.09.2017 WackoWiki Converter work-out for simplify the migration — the converter uses "pandoc" (1.12.4.2) which mostly broken for tables, html2wiki also has more lacks, then there was written a procedure "wacko2media" into OpenSCADA to do this migration directly from WackoSource.
(*) Core documents migration, updating, appending and translation.
04.11.2017 A procedure creation for user accounts of the main-site (TYPO3) sync to the new Wiki.
20.10.2017 Switch OpenSCADA to the online documentation on the new Wiki.
03.11.2017 A script creation for prepare the offline documentation from the new Wiki — the script "docOffLine" into OpenSCADA directly created for the function.
(-) Moving to different VPS with newer PHP and the environment in whole.
Problems with the Wiki-engine MediaWiki:
25.10.2017 Moving to a different VPS is mostly successful but the redirection from "http://oscada.org/wiki" to "http://192.168.0.14/wiki" has problems but the HTTP server Apache2 changes the filed "Host: " of the HTTP header to 192.168.0.14.
24.10.2017 Big articles (> 65536) translation impossibility but the row "job_params" of the table "job" has type "BLOB" which limited in 2^16. The report here.
Повідомлення створено: 18. 09. 2017 [11:10]
Wiki-pages in processing and their current state and progress for: moving to the new wiki, presenting (revision, translation to the generic languages, creation):
Home: OK, OK
About: OK, OK
About/Related_projects: WAIT, WAIT
Functions_and_demands: OK, OK
Documents: OK, OK
Documents/[Releases/]0.8.0: OK, OK
Documents/[Releases/]*: WAIT, WAIT
Documents/Terms: OK, OK
Documents/FAQ: OK, OK
Documents/Quick_start: OK, WAIT
Documents/Program_manual: OK, OK
Documents/DAQ: OK, WAIT
Documents/User API (from the Program manual end): OK, OK
Documents/Operator_manual: WAIT, WAIT
Documents/API: OK, WAIT
Documents/Program_donors: WAIT, WAIT
Documents/Build_from_source: OK, OK
Documents/Create_module: OK, WAIT
Documents/Crash_report: OK, WAIT
Works: OK, OK
Works/Developers: WAIT, WAIT
Works/Road_map: OK, OK
Works/To_do: OK, OK
[Works/]Fund: OK, OK
Works/Technical support: -, WAIT
Works/Tests: WAIT, WAIT
Works/Tests/*: WAIT, WAIT
Works/Errors: WAIT, WAIT
Using: OK, OK
Libs: -, OK
Libs/User_protocol_devices: OK, OK
Sub-projects: OK, OK
Sub-projects/Adaption_to_Android: OK, OK
Sub-projects/Automation_Linux_distributive: LINK, WAIT
Sub-projects/Embedding_and_PLC: OK, OK
Sub-projects/*: LINK, WAIT
Modules: OK, OK
Modules/SQLite: OK, WAIT
Modules/MySQL: OK, WAIT
Modules/PostgreSQL: OK, WAIT
Modules/FireBird: OK, WAIT
Modules/DBF: OK, WAIT
Modules/ODBC: -, WAIT
Modules/LDAP: OK, WAIT
Modules/Sockets: OK, WAIT
Modules/Serial: OK, WAIT
Modules/SSL: OK, WAIT
Modules/SelfSystem: OK, WAIT
Modules/UserProtocol: OK, WAIT
Modules/HTTP: OK, WAIT
Modules/JavaLikeCalc: OK, WAIT
Modules/LogicLev: OK, WAIT
Modules/BlockCalc: OK, WAIT
Modules/DAQGate: OK, WAIT
Modules/System: OK, WAIT
Modules/ModBus: OK, WAIT
Modules/DCON: OK, WAIT
Modules/OPC_UA: OK, WAIT
Modules/MMS: -, WAIT
Modules/SNMP: OK, OK
Modules/ICP_DAS: OK, WAIT
Modules/Siemens: OK, WAIT
Modules/DiamondBoards: OK, WAIT
Modules/Comedi: OK, WAIT
Modules/SoundCard: OK, OK
Modules/BFN: OK, WAIT
Modules/SMH2Gi: OK, WAIT
Modules/AMRDevs: WAIT, WAIT
Modules/Fastwel: WAIT, WAIT
Modules/FT3: WAIT, WAIT
Modules/(BCM2835->GPIO): OK, WAIT
Modules/FSArch: OK, WAIT
Modules/DBArch: OK, WAIT
Modules/VCAEngine: OK, WAIT
Modules/QTStarter: OK, OK
Modules/QTCfg: OK, WAIT
Modules/WebCfgD: OK, WAIT
Modules/WebCfg: OK, WAIT
Modules/WebVision: OK, WAIT
Modules/WebUser: OK, WAIT
Modules/FLibSYS: OK, WAIT
Modules/SystemTests: OK, WAIT
Modules/FLibMath: OK, WAIT
Modules/FLibComplex1: OK, WAIT
13010
