[BugWrong] Graphical dont show float values
Повідомлення створено: 29. 10. 2016 [21:30]
o5i_
osi mr
Зареєстрован(а) с: 29.10.2016
Повідомлення: 2
Hi, first, this is my first post.. Hello! Great Project!
But i have a problem, when i setup the graphical ui on the display of the pi it doesent show float values, just the first numbers. But on the webinterface it shows everything correctly. how to fix it?
Повідомлення створено: 29. 10. 2016 [22:11]
Повідомлення: 3796
Do not break the locale and concrete LC_NUMERIC environment then all will be OK!
P.S. I have not any problem on Raspberry Pi2 Raspbian Wheezy(7), Jessie(8)!
Повідомлення створено: 30. 10. 2016 [10:05]
o5i_
osi mr
Повідомлення: 2
Hi, thanks for the reply... I thought it has to do whit the locales but it doesent work for me... I have to leave them as default en_GB or do i need to set them to something else.. maybe dpkg-reconfigure openscada? I start the graphical using a custom systemd script.. There is no display manager or something like that installed just X xinit... Maybee i need something?
[Service]
Type = idle
# ExecStart = /usr/bin/xinit /usr/bin/dbus-launch --exit-with-session /usr/bin/openscada -- :0 -nolisten tcp vt7
ExecStart = /usr/bin/xinit /usr/bin/openscada -- :0 -nolisten tcp vt7
# Restart=always
Restart = on-abort
RestartSec = 5
[Install]
WantedBy = multi-user.target
Повідомлення створено: 30. 10. 2016 [10:39]
Повідомлення: 3796
Sure you must and that sort of starting is mostly wrong and sure it's not OpenSCADA problem!
22514
