Scada for managing a pinball machine?
Повідомлення створено: 26. 06. 2021 [07:22]
Marc-Dubois
Marc Dubois
Зареєстрован(а) с: 26.06.2021
Повідомлення: 2
Hello everyone,
I am new here, I am an electronic technician and I want to make a pinball machine, unfortunately I have very little programming knowledge, but if you consider that a pinball machine is just a normal machine, do you think that scada software can manage it normally like (I / O) interface ,scorring display, and sound events, thank You
Повідомлення створено: 28. 06. 2021 [01:55]
trayor
trevor kenyon
Зареєстрован(а) с: 14.05.2020
Повідомлення: 8
Hi, and welcome,
The scada software can be used in the application that you suggest.
Typically this type of software is used for the supervision of industrial or commercial systems.
However, a pinball machine would be a good application to learn and implement the principles of SCADA.
As you mention the "pinball machine is just a normal machine".
The scale and low risk nature of the machine make it suitable for learning in my opinion
I hope the project goes well.
Повідомлення створено: 03. 07. 2021 [04:40]
Marc-Dubois
Marc Dubois
Повідомлення: 2
Thank you for the answer Trayor,
I did well to ask, your confirmation will allow me to start on a good basis, I will explore this option, and I hope it will give good results, thank you and good luck.
13396
