Автор |
Повідомлення |
Повідомлення створено: 29. 04. 2022 [12:56]
zhxyahoo
HONGXIANG ZHOU
Зареєстрован(а) с: 30.03.2022
Повідомлення: 6
I am new to Linux system and Raspberry Pi.
try to Installing-building from the source texts on Raspberrypi 4B(Raspberry Pi OS with desktop,2022-01-28-raspios-bullseye-arm64).
The step is follows:
1. $ sudo apt-get install autoconf
2. $ sudo apt-get install libtool
3. download tar archive from /http-server http://ftp.oscada.org/OpenSCADA/
4. $ cd Downloads
5. $ tar -xvf openscada-0.9.5.tar.xz
6. $ cd opensacada-0.9.5
7. $ tar -xvf ../openscada-res-0.9.5.tar.xz
8. $ sudo apt-get install subversion
9. $ svn co http://oscada.org/svn/trunk/OpenSCADA/
10. $ cd OpenSCADA
11. $ sudo autoreconf -ivf
Then there displayed, "autoreconf: configure.ac not using Gettext"
If I go on to do the next step:
12. $ sudo ./configure
Then there displayed, "configure erroe, Some utilities of I18N gettext are not present! Install the gettext utilites package."
Please help me, how can I install the gettext utilites package? Thanks!
Повідомлення створено: 29. 04. 2022 [13:08]
Повідомлення: 3741
Why?
What problems with installing the ready packages http://oscada.org/en/main/download/ you have?
"PLC: Raspberry Pi Zero,1,2,3 (Raspbian 9 ARMv6); Raspberry Pi 2,3,4 (Debian 8,9,10,11 armhf-ARMv7) ..."
And if you very want to build yourself, read the dependencies http://oscada.org/en/main/characteristics/ carefully:
"gettext A group of utilities for preparation and compilations of translations of the interface of programs on various languages in conformity with the internationalization standard I18N."
And build by the Debian tools — "dpkg-buildpackage" as that wrote in the manual "Build from source".
Повідомлення створено: 29. 04. 2022 [13:23]
zhxyahoo
HONGXIANG ZHOU
Повідомлення: 6
I did according the following link, "How to/Build from source",
http://oscada.org/wiki/Documents/How_to/Build_from_source
It‘s not "Install OpenSCADA from ready-made packages".
Is something wrong or missing?
Повідомлення створено: 29. 04. 2022 [14:25]
zhxyahoo
HONGXIANG ZHOU
Повідомлення: 6
I also tried to Install OpenSCADA from ready-made packages as following step:
1: edit the /etc/apt/sources.list file by inserting one line:add "deb http://ftp.oscada.org/Debian/11/openscada ./
2. Adding the signature verification key (the authenticity) of the repository and packages in it (not necessarily and not in all repositories): $ sudo wget -O - http://ftp.oscada.org/Misc/pkgSignKey | sudo apt-key add -
3. $ sudo apt-get update
4. $ sudo apt-get install openscada-model-aglks
Then display:
Повідомлення створено: 29. 04. 2022 [14:31]
Повідомлення: 3741
Debian-based distributions — DEB packages
Повідомлення створено: 29. 04. 2022 [14:39]
Повідомлення: 3741
ARMHF is not ARM64, so use 2022-04-04-raspios-bullseye-armhf (Raspberry Pi OS)
Повідомлення створено: 29. 04. 2022 [14:51]
zhxyahoo
HONGXIANG ZHOU
Повідомлення: 6
Download link:
https://www.raspberrypi.com/software/operating-systems/#raspberry-pi-os-64-bit
After click and download, the file name is "2022-04-04-raspios-bullseye-arm64.img". It's not "2022-04-04-raspios-bullseye-armhf.img".
Повідомлення створено: 29. 04. 2022 [14:58]
Повідомлення: 3741
https://downloads.raspberrypi.org/raspios_armhf/images/raspios_armhf-2022-04-07/2022-04-04-raspios-bullseye-armhf.img.xz
Повідомлення створено: 29. 04. 2022 [15:01]
zhxyahoo
HONGXIANG ZHOU
Повідомлення: 6
Ok, I see. It's 32bit system with desktop, it means that OpenSCADA is not support OS-64bit, right?
Повідомлення створено: 29. 04. 2022 [15:06]
Повідомлення: 3741
It means there is no ready build for ARM64.
P.S. The free support from Roman Savochenko is exhausted for you (... can response five(5) and for newbies ...), then here will no reply more from him!
