2016-07-14 Roman 0.8.16 - FIX:!!:Archive: Old LTS problem with alarms is fixed, for the negative level read from the messages buffer and allow write to archives. - !!!!:FIX:DAQ.JavaLikeCalc: Second argument's type changing at compile is fixed but it is dynamic now mostly, detected on problems with some string operations. - FIX:UI.Vision: Pages including into the pages container is fixed for adjust at it's scale change. 2016-06-28 Roman 0.8.16 - API: !!!!:Changes: SYS,Transport,DAQ.DAQGate,UI.{QTCfg,Vision,WebCfgD}: External host upraise is implemented by the function extHostList() extension, the requests reforwarding by function cntrIfCmd() and the input part of the self-system protocol. pthread_mutex_t, MtxAlloc and MtxString moved to the mutex wrapper object ResMtx. DAQ: API functions tplE(), tplIOE(), errE() renamed to elTmpl(), elTmplIO(), elErr(). Archive: m_start, run_st, m_db were renamed to mStart, runSt, mDB. Appends: SYS: Resources locking in RW object "Res" expanded by the functions (synonyms) lock(), tryLock() and unlock(). Additional managing time macro FTM2 is added. TFunction: Virtual function prog() and setProg() is added for allow it's control through an abstract object. User API function SYS.sleep() expanded to accept first argument of time in seconds as float and allow to set here up to nanoseconds. DB: Resource's of the DB allocation TBD::resTbls is added. DAQ.BlockCalc: User API functions cntr(), cfg(), cfgSet() for blocks are added. Archive: messPut(), messGet() and same user API function expanded by the argument "arch" to allow direct to the pointed archivators requesting. User API function messGet() expanded by argument "upTo", for the timeout direct control allow. To messages get functions added a time result of the finished processing. Mostly for allow fast continue from the point after long terminated by the timeout requests. Values archivation a global option is added for time of taken values force to current and override it's source from. To values archive object an option is added for pass values fill to last value. Transport: Starting-connection time is added to the output transports. UI.VCAEngine: User API functions mess{Debug,Info,Note,Warning,Err,Crit,Alert,Emerg}() appended to the run-time widget and included the widget path as the category. Special.FLibSYS: The time functions are appended by tmSleep() for faster access to the short sleeping provides. - SYS: FIX:User's space flags to generic nodes (TCntrNode) processing fixed, mostly for "RM_Full" flag and DAQ paramter's archives propper removing. !!!!: CoreLib version rise to 2.4. DB,DAQ,Archive,Transport: Module's subsystems' version set to 8. !!!!:TCntrNode: Free of locked nodes and attach to disabled ones are prevented by propper resource locking to mUse. !!!!: For some productivity rise the exceptions catch moved from the object copy to it's reference. !!:{DAQ,Transport}.*: Tasks priorities range expanded up to 199 where 100-199 used for SCHED_FIFO tasks planing policy. !!:All key warnings next resolved. Include some controversial ones: DAQ.OPC_UA.libOPC_UA: Encoding mask processing in mix of operations '&' and '|'. Function realRound() some set simply. System configuration fields "workdir", "moddir", "icodir" set to readonly from the configuration interface, mostly for wrong changes prevent and the changes allow only by the configuration file edit. Security: Adapted to prevent passwords storing in open view as hash instead, for: OpenSCADA host (Transports), Protocol.SelfSystem, UI.Vision. crypt_r() using enabled only for "__USE_GNU" and the open passwords store instead. TSYS::strEncode() in variant SQL expanded by the doubling method of the pointed symbols. data/debian: the service's script openscada.init moved to separated package openscada-server. changelog: Author set to OpenSCADA , mostly for allow the sign after build by that key. - DB: !!!!: All DB modules rewrote to open table without exceptions into the table object constructor. !!:FIX:MySQL,SQLite,PostgreSQL: Prevented the "BEGIN;" and "COMMIT;" request's sequence breakage on high concurrency access activity. "connRes" moved from pthread_mutex direct to ResMtx wrapper. {PostgreSQL,SQLite}: TSYS::strEncode() in doubling method is used. FIX:DB.PostgreSQL: Fixed for symbols "'" '"' encoding by it replace to the doubling method. FIX: Fix cycling after unsuccessful a table's structure correction. MySQL: Executions into BD::postDisable() are prevented. - DAQ: !!: User API function funcCall() significant expanded to fix the result function for reusing and then significant performance rise. FIX:Value: Write access to DAQ attributes closed for all into the service request "set". FIX:*,DAQ.LogicLev: Special and translated IO from config are prevented from the redundancy. !!!!:*,LogicLev,ModBus: DAQ redundancy of the dynamic attributes is added. !:ModBus,Siemens,DCON: Pass of real requests at the first and last iterations, only the procedures execution. !!!!:FIX:OPC_UA: Module for client renamed to "Client OPC-UA" and for server to "Server OPC-UA". Some spare error messages removed. !!!!:Protocol: Works into the poll mode of input transport are allowed and enabled by default. The Publish service now allowed on the LTS! reqData() fixed for "NodeClass" processing of the "Browse" request, mostly for forward request to the data model. !!!!:FIX:libOPC_UA: Packages sequence number managing for server part is fixed by separating from the value of input packages. FIX: Packages sequence number managing for the client part also unified and fixed to prevent the value repeats. !!: Early Acknowledgements processing in request "Publish" is added. TimeStamps into the "Write" client request's are disabled but some servers tell 0x80730000 (OpcUa_BadWriteNotSupported). New client/server services implemented: RegisterNodesRequest, RegisterNodesResponse, UnregisterNodesRequest, UnregisterNodesResponse. Only formal and no a real doings! Initial filters support is added into requests CreateMonitoredItemsRequest and ModifyMonitoredItemsRequest only for OpcUa_EventFilter at AId_EventNotifier parse. Services CreateMonitoredItems and ModifyMonitoredItems processing merged to a singe one. Variable's statuses added, mostly for the "Publish" service. Initial "Publish" responses are added: first after the CreateSubscrition service and second after the CreateMonitoredItems service. Input Variants function iVariant() is added as a separated part of function iDataValue(). Successful adapting to work with UAExpert 1.4. !!!!:JavaLikeCalc: Support of included functions definition and it's call is added. !!: To function object is added "To start" parameter for allow disabled by default ones. Operation "||" and "&&" formal set to equal priority. Checking for IO moved before constants for it's override. Constant "EVAL" as a synonym to EVAL_REAL is added. FIX:Siemens: A crash problem at high and frequent interaction is fixed, fragments changing (by assign) is moved to replace everywhere. FIX:LibnoDave: gethostbyname() replaced to it's reentrant variant. DCON: Some cleaned. enRes and reqRes resources lockators moved from Res to ResMtx. ModBus: "Value" field of the templates set to use as a default link, on first enable. !!:BlockCalc: Configuration fields of block unified and moved to TConfig::cntrCmdMake(). Special attribute "this" of the object access set to processing into blocks. =Tmpl=: Some cleaned and expanded. - Archive: FIX: Time limit for get() messages fix. FIX: Group messages archives request timeout, for common, fix into get(). !!!!: messPut() expanded to write messages independent to the alarms table. Resources allocation space decreased exclusively to local buffers access and prevent some racecondition at the archivators access. DBArch,FSArch: Get messages request for equal begin and end time is allowed. !!!:FIX:FSArch: Check for duplicate as equal time, category, level (by the option "prevDblTmCatLev") and it prevent is added. !: Expanded for early limits check and it's check at unpack errors and then prevent storages overfull at close limits and small storages. Check for duplicated at all fixed. Time into cache changed from time_t to int64_t (in microseconds). Used FTM() for left the messages time. Get from XML set some optimal. Get from plain allowed for the messages time equal to end. !!!:FIX:DBArch: Get messages algorithm is rewrote to request by minutes. !!:Table structure's for value and messages set adaptive and moved to the objects TMArchivator and ModVArchEl. New option of the messages archiver are added: "Store time as pure integer". "Archive size (days)" for both values and messages adapted for set to zero (<0.1) and disable the limit at all. The used table closing after any put request is disabled. - Transport: Modify property is added to the external host's object for reconnect on it modification. !!:FIX:SSL,Sockets: gethostbyname() and getservbyname() replaced to it's reentrant variants. !!:FIX:Serial,Sockets: For result's reading, into output transport, added waiting for data at zero or/and EAGAIN error. FIX: Errors on writing in the output part is fixed. !!: Possible wrong readings after the select() wrong termination, with marking as a data present (some caused), is unified and better adjusted for different modes of the requesting and the not requesting mode of output transport. Sockets: Input transport's error messages some improved and set more informative. - Protocol: !!!!:SelfSystem: Force authentication update by attribute "rqAuthForce" is added. !!!: Reforwarding of host's requests by attribute "reforwardHost" into the input part is added. Authentication error processing for direct requests is added. Authentication errors moved from the connection kind to the request, into the tag attribute "rez" and text. Attribute "remoteSrcAddr" of the root node set/reserve to the remoted host's address. - UI: VCAEngine,Vision: Primitive's "Diagram" attribute "trcPer" type changed from "Integer" to "Real". UI.Vision also adapted for update the "Diagram" down to 0.01 ms and it limited to one second in the development mode. Logical groups separator of Widget's attributes is changed from ":" to ": " everywhere, mostly for allow the user attribute value's items separation and description it with the symbol ":". To view "Table" of the primitive FormEl into root tag "tbl" added attribute "sortEn" to direct sorting by columns and header's item option "sort" for point to initiate sorting column. FIX:Vision,WebVision: Mode "XY" of the primitive "Diagram" fixed for build by sorting by 'X' disable, only the hierarchical order. For primitive "Diagram" to data block "data:
" option "Approximation (aprox)" is added. FIX:UI.QTCfg: Read only of selected items are fixed in alignment with other items in single row. Changed user apply is fixed. FIX: Into TextEdit widget added a signals blocking at setPlainText() for prevent the cursor events, status bar update and crash in some cases here. FIX: External host's status processing mostly improved and fixed. FIX: Timeouts of external host are set configurable by the option "TmConChk". FIX: The options StartUser and StartPath are moved under a resource allocation by the type MtxString. FIX:VCAEngine: The function's resources locking is added for SesPage::setEnable(). FIX: Mostly information messages from the information level moved to the debug one. FIX: setNoTransl() at the attributes loading disabled by some problematic and no a sense. !: Force inheritance of links types is added, independent from the attribute local modification. Mostly for prevent the link's type changing lost, as significant one, into the modified attributes. !: To project objects were added a property "EnableByNeed" to control the projects ready after start and prevent long connection by the deferred enabling. Try to enable for disabled pages, at an alarm set action, is prevented by some strange crash here observed, only into LTS. Control request "activate" expanded by "aVls" and "aNms" determine. The runtime note messages are added: "User is changed to ...", "User is connected ...", "User is disconnected ...". Manual creation mark for pages is added. Mostly for modification of the childs clean up and it's inheritance storing prevent by it is spare and sometime problematic on the parent update, like messages about impossible to enable a widget. To messages reading by the repeating tags of primitive "Document" added attribute "docAMessArchs" to allow read only pointed archivators. !!!!:FIX:Vision: Too important fixes made in way of adapting to stable work with remote VCA servers: The module's attributes VCAStation, UserStart, UserPass and UserStBar::{user,pass,VCAStation} were moved under resources locking by the MtxString. To both runtime and development parts were added an initial connection with the restore connection timeout, for allow to load the VCA-server resources. In way of authentication as a default user the name takes from the attribute "user" of the session. Processing of the information dialog about a connection lost was moved to a single request (and thread) from updatePage(), for multithread access prevent and crashes (mostly from the notification tasks). !!!!:FIX: View "Table" of the primitive "FormEl" significant expanded by: global table's attributes: "hHdrVis", "vHdrVis"; row attributes "colorText", "font"; column attributes "color", "colorText", "font". FIX:Included to container's pages align processing rewrote to trace on the widget's geometry update and to the misaligned scroll-bars appearing sometime prevent. FIX: The palette restoring to visibleCheck function is added for prevent FormEl's artifacts at last. FIX: Mouse events at all enabled for "FormEl" primitive and some artifications like ticks lost into Slider but mostly into Table detected and fixed. FIX: Context menu problem for views List, Tree and Table of the primitive FormEl is fixed, for allow the right mouse button's event come to the system functions. !!!!: Requests to an external host moved to using cntrIfCmd(). !!!: Remote authentication moved to allow use the host authentication by default and the same connection for check it. !: Timeout of tries of restoring connection to a remote station set to progressive up to the pointed one and the error message display after the timeout value in 3 seconds. For the attribute inspector labels of the attributes the ToolTip is added to long names (>20). The view "Table" of the primitive FormEl mostly adapted to sorting by the columns. conErr pointer lost for not zero set at the master page free/replace is fixed. That sometime causes to crashes! Global modification mark processing moved to different function modifyGlbStUpdate() and some changed. UI.WebCfg: Source code significant cleaned. - Special.SystemTests: The DB tests are expanded by a seek test. 2016-01-19 Roman 0.8.15 - FIX:Protocol.UserProtocol: The regression fix by functions TProtIn::{waitReqTm,setSrcTr}() miss. 2016-01-12 Roman 0.8.15 - API: !!!!:Changes: SYS.TModule: The info attributes like m{Name} renamed to mMod{Name}. Function modInfoMainSet() added and used into all modules for main info attributes of module set. TProtocolIn, Protocol.UserProtocol, Transport.*, DAQ.{ModBus,OPC_UA}: The input transport store by locked header instead the path for faster access, API functions changed: open(), srcTr(), setSrcTr(). Appends: SYS: Object ResMtx is added for gather all platform specific mutex implementation. Function TSYS::taskUtilizTm() added for get utilize time by the pointed tasks. TElem: Item's resource mResEl moved from Res to pthread_mutex_t, and it allowed for public access. Hardware platform endian specific conversion function's implementation placed, for: i16_LE(), i32_LE(), i64_LE(), i16_BE(), i32_BE(), i64_BE(), floatBE(), floatBErev(), doubleBE(), doubleBErev(). DAQ.{LogicLev,ModBus}: Appended by user API functions to the parameter object attrAdd() and attrDel() for attributes free management. Transports: User API function {TrOut}.start() added for fast control for the output transport state. Protocol.{*,UserProtocol},Transport.{Sockets,SSL}: Function Protocol::waitReqTm() added for poll mode control of input protocols. - SYS: !!!!:FIX:TVarObj: Object's twice free possibility prevented. TVarObj::propGet() EVAL result fix. FIX: Wrong translation fix to Russian for the message "%s for type '%s' doesn't support module version: %d!" !!!!:Core library version rose to 2:3:0. DB, DAQ, Archive, Protocol, Special, Transports, UI subsystem type modules version rose to 7. TFunction: run_st renamed ro runSt. Archive.FSArch,DB.DBF,DAQ.{Comedi,SMH2Gi}: readdir_r() using rewrote to "dirent" structure direct malloc and prevent problems on other OS, like QNX. - DAQ: !!!!:FIX:OPC_UA: FIX:libOPC_UA: All wrong empty strings (-1) replaced by empty array (0). FIX: System attributes' value reading (AId_Value) fix for substitute first values to next, into single read package. FIX: Empty Read service list cicling fix. FIX: Auth processing for client fixed to storing current endpoint description for next actual "policyId" obtain and using to the auth service. FIX: Wrong NodeId::Opaque type set fix. FIX: Fix something "EndPoint" lack. FIX: Conditional session's clear for selected endpoint is added, mostly for prevent this lost at no "None" policies. Expanded to new error codes. To server part new default name spaces added: 2-"http://opcfoundation.org/UA/DI/, 3-"http://PLCopen.org/OpcUa/IEC61131-3/". Using the client certificate into a renewal secure channel request set only for no "None" policies. Full session clear at errors into a renewal secure channel request is added. Some lack information resolved like to "transportProfileUri" and "securityLevel". libOPC_UA independent version control is added. Specific value types OpcUa_IntAuto and OpcUa_UIntAuto added for adaptive integer type selection, mostly for provide integer into not fixed int32 (int64). Error OpcUa_BadNoSubscription added to PublishRequest. Server folder "ServerCapabilities" added and some items here. Virtual function connect() into client is added for the connection control, used into service "CloseSecureChannel" for close connection. "Nonce" of the Server part disabled into CreateSessionResponse and ActivateSessionRespons for policy "None". FIX:Client: Status codes display fix for the controller's attributes. Product URI changed to "urn:OpenSCADA:DAQ.OPC_UA". Appending information by: applicationUri(), productUri(), applicationName(). For empty "browseName" browsed nodes using "displayName" set. Test client's source code some cleaned and expanded. Server: OpenSCADA DAQ name space set to index 4. FIX:JavaLikeCalc: For library "run_st" renamed to "runSt" and init to false. FIX:ModBus: Some original messages fix. Some resources lock appended. !!!!:Siemens: Self implementing for ISO-TCP is added and tested, mostly by Proviron Holding NV request. Restoring timeout is added. Significant refactoring for the resources lock, error messages and other. - Transport: !!:FIX:{Sockets,Serial,SSL}: Resource of output transport lock into messIO() fixed, by no real a lock hold. !!: Poll mode of input protocol support is implemented. !!: No request mode support is added and all modules adapted to it, in way of
