2014-07-13 Roman 0.8.11
- API:
!!!!:Changes:
SYS: Enum TSYS::Errors (mostly DB Errors) is removed as deprecated.
TSYS::modifCfg() expanded for WR access check.
Primitive of functions strEncode() and strDecode() set unified.
XMLNode: Function childIns() and childDel() position argument's type set to signed (integer) for allow
insert and delete by count from end (negative value).
TCntrNode: To functions TCntrNode::load() and TCntrNode::save() argument "string *errs = NULL" is added for place
all loading and saving errors into the objects.
DB: Expanded functions TBDS::dataGet(), TBDS::dataSet() and TBDS::dataDel() by argument "noEx = false"
and exceptions generate at access to storage errors.
Transport: setAddr() set no virtual, instead global cfgChange() used.
To output transport's function "start()" argument time is added, which no zero value controls connection timeout.
DAQ: TTipDAQ::compileFunc() argument "maxCalcTm" set to 0, for sign to use default-configurable for the module.
Archive: TArchive, TMArchivator and TMArchivator moved to use TConfig::cntrCmdMake().
setValPeriod() and setArchPeriod() set no virtual, instead global cfgChange() used.
Appends:
SYS: Zero initial error object "TError() : cod(0)" is added.
Added new global simple function s2ll() into OSCADA namespace.
Function TSYS::strMess() variant is added for length control and wrap by set "...".
Archive: Selection priority to the value archivator object is added for provide order control and disable at all
into sources selection mode "All". Used for function getVal(), getVals() and archive service "/serv/val".
Function selPrior() and setSelPrior() added.
- DB.AGLKS.St.db: ModBus.testTCP, DAQGate.test and OPC_UA.test set for start by default.
Messages archivators "FSArch.NetRequsts" and "FSArch.StatErrors" fix.
{DAQ,Protocol}.ModBus: Test values expand, took from 0.9.
- SYS: User API functions strEncode() and strDecode() is added.
!!!!: Access to storage problems notify is added.
Complex tests for problems notify for storages: SQLite, MySQL, PostgreSQL, FireBird, DBF, Cfg.
The tests results: http://wiki.oscada.org/Works/Tests/DB.
To global node's services "" and "" added errors obtain and notifications.
TCntrNode: To ctrMkNode() append using 'pos' argument lesser -1 for count from end.
FIX:TFunction, TValue, UI.VCAEngine.Attr: Set TEValObj() to object type attribute by EVAL scalar set is added.
- DB: Decreased wait for free tables timeout to 1 second on the DB stop, for lost connection to network DB cases fast.
Prevent exceptions at the DB object disable, mostly after connection wrong for the network DB.
!:DBF: Periodic (10 seconds) sync changes from memory to file is added.
Inline DB folder selection for DB object is added.
RO access and errors is added. Some code clean up.
!:SQLite: Binary string write to DB support is added by "#'XXXXXX'" form.
Adapted for work into RO mode.
!:FireBird: Managed types expand to: blr_varying, blr_varying2, blr_text, blr_text2, blr_blob, blr_short, blr_long, blr_int64,
blr_float, blr_double and blr_d_float.
FIX: Connection timeout disabled by not real used and wrong into the DB.
FIX: Internal API data clean up is added at wrong connection.
fieldSet() and fieldDel() mostly rewrote for typical.
!:MySQL: Adapted for work into RO mode.
CR_CONNECTION_ERROR process at connection lost is added.
fieldDel() mostly rewrote for RO process.
!:PostgreSQL: Managed types expand to: text. character varyin, character(%d), character varying(%d), smallint, integer, bigint, real,
double precision, timestamp with time zone.
FIX: Connection lost processing move to after the request.
Transaction processing rewrote for typical.
Adapted for work into RO mode, fieldDel() mostly rewrote for RO process.
- DAQ:
FIX:TValue: Value type info fix for selectable.
FIX:JavaLikeCalc: "Error constant after constant" error fix by append position.
Append default safe timeout set into the module tab.
Root object TDAQS expanded by control interface's request "/serv/PrmAttr" for remote browsing allow the DAQ parameters tree.
!!:FIX:ModBus: Write to complex type like "_f", "_i4" for write-only mode is fixed.
Complex types expand by "u2" - uint16, "d" - Double.
!!:SNMP: Mostly expand for OIDs browser implement, MIB Tree using for access mode and enums obtain.
!!:OPC_UA: Inline browser by OPC UA nodes tree to the parameter object configuration is added.
FIX: Input packages' size and header control is expanded for broken packages process and early drop.
Commenting nodes into the list support is added, by symbol '#'.
!!:DAQGate: Inline browsing by external hosts and remote parameters tree is added.
Expanded for allow the paramter's identifiers independent namespace and the assign to remote parameter's ID.
Allow for pass "/prm/*" variables for some global lists process.
Expand for bind hierarchic parameters (from OpenSCADA 0.9).
Adapted for quick start at no remote host achives.
- Archive:
FIX: Lost archive's connection to archiver after the archiver restart is fixed.
FIX: Service "/serv/mess" on request direct to alarms set negative level fix for prevent storage data modify.
Set archiver period expanded for allow set zero value and disable the values buffer processing for only direct write there.
Adapted for writing unaligned to the period values and buffers.
FIX:DBArch: Reread meta data for value archives is force set after wrong that read at start with unaccessible network DB.
Disconnecting archivers to DB detect is added and instead uses next priority archiver.
{DBArch,FSArch}: Default priority set to 1 for DBArch and 1000 for FSArch.
- Transport: Meassured request's result after termination by an exception is added to "Sent" tab of output transport.
FIX: TTransportOut, TTransportIn fix for sets values check and process.
Sockets: Default timeouts of output transport set return to "5:1".
- Protocol:
!!:ModBus: Functions 0x2 (CI) and 0x4 (RI) support is added.
Classic form for registers added and complex types expand by "d" - Double.
!!:SelfSystem: The protocol implement improved for check and wait the header entirety.
Argument "conTm" to output protocol's part is added.
SES_OPEN limited by 10 for one source and user. Sessions moved to std::map for some access acceleration.
HTTP: Output protocol expanded by option "onlyHeader" for fast online documents check.
- UI:
!!:QTCfg: Check and warning about no apply changes at the page change is added.
Added and used function getPrintVal() for check and encode straight binaries.
Selected group nodes commands "load" and "save" support is added.
!!:VCAEngine: User API session area functions attr() and attrSet() expanded by argument "bool fromSess" and "bool toSess"
respectively for set the attributes to the session table.
!!:FIX: Change parent trace for project and widget's library fix.
VCAEngine: geomZ for widgets allows to negative.
Attributes' modify set after new the create into enabled session is added for guaranty the value read by the session visualiser.
The VCA project's session info some expanded.
Vision: Included widgets order updating function expand for prevent system widget's reorder and allow after sort by ID for equal Z.
FIX: Unproper events process at config set to element LineEdit, mostly for this view "Combo", are prevented by signals block.
FIX: For included to container's pages set attribute Qt::WA_WindowPropagation for allow true transparent by palette propagation.
Mostly for Slider hide.
FIX: Widgets order update fix after manual "geomZ" set into development mode.
geomZ manage changed to changing only for single widget and rip from real work position.
Mostly for prevent group widget's geomZ change and collisions to no changed widgets position.
{QTCfg,Vision}: For wait cursor uses QApplication::setOverrideCursor(Qt::WaitCursor).
!!:{VCAEngine,Vision}: Changes into visual items put down to the parent function is added.
!!:Check and warning about no apply changes into item's configure dialogs is added.
FIX:{Vision,WebVision}: Use absolute level after service "/serv/mess" into primitive "Protocol".
2014-05-01 Roman 0.8.0.10
- API:
!!!!:Changes:
Archive: Result to function TMArchivator::put() is added for accomplish writing control.
SYS.Mess,Archive.DBArch: The messages level type into structure TMess::SRec changed from Type to int8_t
for fix negative level into DB.MySQL.
SYS.XMLNode: Into function load() argument "full" replaced "flg" with flags:
0x01 - full mode; 0x02 - no remove spaces for begin and end tag's text.
Transport: External hosts configuration improved for allow modes "User", "System", "User and System" select into single table.
Functions removed: sysHost(), setSysHost(). Functions change: extHostList(), extHostGet(), extHostSet(), extHostDel().
DAQ: API function "void vlSet();" expanded for same set value pass and prevent lost values.
Appends:
SYS: New resources allocation objects MtxAlloc and MtxString is added. To ResAlloc is added lock() and unlock().
TCntrNode: Base function _ctrMkNode() and specific for arguments set function ctrMkNode2() to original ctrChkNode() is added.
"TSYS::i{bits}_LE()", "TSYS::i{bits}_BE()", "floatBE{rev}()", "doubleBErev()" functions is added for endians processing.
Added new global simple functions into OSCADA namespace: tm2s(), s2i() and s2r().
TArrayObj: New direct access functions arGet() and arSet() is added, for fast access from internal.
XMLNodeObj: New function "childGet( string name, int num = 0 )" is added.
Transport,Transport.*: To output transports virtual functions timings() and setTimings() is added.
- SYS: *.core files process adapted.
openscada.spec is adapted for build on "redhat" based environments.
Checking for header phonon/VideoPlayer is added for allow automatic build with old Phonon configuration's headers path "Phonon/*".
ALTLinux RPM-spec depend to postgresql9.1-devel is changed postgresql-devel.
Variable DB_CFG is defined to "" and used everywhere.
Check for EVAL into description on TCntrNode::ctrMkNode() is added, for present save.
!!!: TConfig,TValue,UI.{VCAEngine,Vision}: Editable listed configure fields and DAQ attributes by TFld::SelEdit support is added.
User's API functions gmtime(), timegm(), strftimegm(), strptimegm() for time into GMT(UTC) processing allow.
!!: The code clean up for mostly warnings for build by GCC-4.8 and some hiden bugs fixed.
FIX:TVariant: User objects encode to XMLStr is fixed for EVAL represent by boolean, integer, real.
FIX: Close opened config file is fixed.
DB,TVariant,DAQ.JavaLikeCalc,Special.FLibSYS: Direct access, into backend, to user space object TArrayObj is set.
- DB:
FIX:DB.{SQLite,MySQL,PostgreSQL,FireBird}: Keys miss into DB check is fixed for fieldSeek() and fieldSet().
!!!!:DB.{SQLite,FireBird,PostgreSQL,MySQL}: Connection for network DB restore mechanism is changed
to enabling for toEnable() and disabled DB into transactions check cycle.
Requests to DB the resources allocation is changed to use pthread_mutex_t.
Complex tests pass for lost connections restore and generic test of module Special.SystemTests.
MTable::fieldDel() is adapted to remove fields with keys real miss into the DB's table.
!:MySQL: Transaction support and using is added, for performance rise on some DB storages.
!!:SQLite: Main SQLite3 type "REAL" handle is added for structure obtain.
- DAQ:
FIX: Modify flag set at using template edit try is fixed.
FIX: Disabled redundant mode work is fixed into TController::enable().
Templates: "Maximum calculate time (sec)" field set active only for started DAQ templates.
BlockCalc: To blocks' output links optional writing by changes is added.
Field "VAL" size for block's IO table increased from 20 to 10000 and "LNK" from 50 to 100.
FIX:DCON: Config field "ADDR" renamed to "Transport". Default requests try set to 1.
JavaLikeCalc: Direct access to object's properties set for some performance rise.
FIX: Insert object's item to Array into this creation by "new Array(0, 1, 2, ar[0])" is fixed.
FIX:LogicLev: Reflection type is fixed and expanded for connection to target parameter, update and attributes list sync into calc period.
ModBus: Remove connection try from controller's object start().
!!!!:OPC_UA.{*,LibOPC_UA}: LGPL COPYING file is added to the library.
FIX: libOPC_UA is fixed for client's service Write respond.
FIX: LifeTime for session processing into client's part is fixed and SC_RENEW support is added.
FIX: Close socket on server part at error and malformed packages. Possible crash on retract queue clean is fixed.
FIX: Try send publish response for no present into queue publish request is fixed.
FIX: Indexes for DeleteMonitoredItems service fix.
Debug messages "MSG Req" and "MSG Resp" are expanded and added added for "SubScription".
SubScriptions limit for 10 is set for sessions independent.
No error message but only service status set for some services.
FIX: Input protocol exception abort fix at short messages receive.
FIX: Unlock miss is fixed into function subscrSet().
FIX: OpcUa_Server_ServerArray variable process append. epEnAt() result process append for some crash prevent.
OpcUa_Server_NamespaceArray append into OpenSCADA module is added. NS_OPC_UA(0) and NS_SERVER(1) is added.
Browse allow is added for zero ReferenceTypeId.
Some NameSpaces using ordered and sync to 2055 content.
For OpenSCADA_DAQ_NS set index 2. For sessionId set NS to 1 and for authentication Token to 0.
Session lifetime process is added.
TranslateBrowsePathsToNodeIds is implement for hierarchical part (OpcUa_HierarchicalReferences) request process.
TranslateBrowsePathsToNodeIds is rewrote to use Browse service backend for hierarchical find path's items.
SubscriptionId and MonitoredItemId grow start from '1', for exclude invalid value '0'.
FIX: MonitoredItemId queueSize manage fix by set from 1 to 1000.
Remove transport start at the controller's object start.
User and password auth data set is added to client part and test program.
Secure policy set is added to test program. Auth password hide into client part is added.
libOPC_UA clean up from OPCVariant object and it removed.
Inline nodes browser is added to client's parameter object for insert selected nodes to processing list.
FIX: LibOPC_UA fix for secure policies for different client's and server's keys size.
Tested for OpenSCADA Client + OpenSCADA Server, OpenSCADA Client + IgnitionOPC_UA, UAExpert + OpenSCADA Server,
testOPC_UA + OpenSCADA Server, testOPC_UA + IgnitionOPC_UA.
FIX:System: New DA-type "UPS", by NUT-protocol is added.
Active DA check and creation is fixed for same origin parameters test, no the parameter identifiers.
Self atributes support allowed and used into DA-sources "Smart" and "UPS".
Set attributes to EVAL is expanded for separated fields.
Expanded for addition properties into the parameter object support.
TController,TTipDAQ: ID update after new child object create.
!!!!:BFN,DAQGate,ModBus,OPC_UA: Alarms for connection state to remote sources is made unified.
- Archive:
!!!:TMArchivator: Reimplemented messages archivation for allow the messages into the buffer resend at
the messages storage connection restore.
{start,stop}() functions implement into base class for active archivators of the messages list manage,
run state manage and messages header reset.
"messHead" attribute of the archivator for point to the messages buffer, instead global "headLstread".
setActValArch() renamed to setActVal() and container "actUpSrc" renamed to "actVal".
setActMess() is added for register active messages archivators to container "actMess".
Resource allocators mRes and vRes moved to pthread_mutex_t.
!!!!:FIX:Archive.*,Special.FLibSYS: Significant values archiving fixes:
Prevent for set negative period values into buffer.
TValBuf::vOK() expand for check aligned to the buffer period.
Disable pass for setVals by lastGet() for direct write allow.
setVals() is adapted for allow write unaligned border [beg:end] to period by round here.
*,DBArch: To TVArchEl::setValsProc() added result for allow archive's buffer's part write control. Used for rewrite to network DB by DBArch.
Field's "LEN" of messages table length set to "2" for allow negative (alarms).
Allow start Values and Messages archivators for DB error, predict restore the connection.
*,UI.{Vision,WebVision}: Service "/serv/val" of OpenSCADA is adapted for return EVAL_STR as EVAL for all string representing data modes.
"/prm/cfg/addr" control elements renamed to "/prm/cfg/ADDR" for equal to configuration (fields names into the DB table).
FIX:FSArch: Some access control fix for prevent use packed files. fwrite() result for items is fixed.
Check deleting Archives cycle is fixed.
Closing messages file on write error is fixed.
- Transport:
*: For input transport, using protocol() set only on create for some performance rise.
Disable write access to field "Protocol" at running input transport.
Sockets: Default timeouts for output transports are set to "5:0.1".
SSL: Permition to temporary certificate file restrict to 0600.
SSL,Sockets: KeepAlive parameters of input transport is made unifical and descriptions append.
Default value of KeepAliveTm set to 60 for prevent input connections hang.
- UI:
QTCfg:
Start page change for set into localhost space and no warnings on the set on user change.
Check and change current page at it rename.
Rows and collumns of a table adjust mechanism set like from UI.Vision primitive FormEl view "Table".
Group-selected fields set support is added.
VCAEngine:
FIX: No Widget::attrSet() return -1 for wrong attribute set.
FIX: cntrCmdAttributes() return for primitive "FormEl" is fixed.
DB prefix "wlb_" is changed to "prj_" for projects' DB select.
Using source widget in base role if previous opened page miss for open command process is added.
pgOpenSrc clear at the page's container close is added.
Set links as active only after successful connection to it, for parameter's attributes.
Implement for some problems fix into dynamic linking.
Vision:
FIX: "Text" primitive update font size is fixed at it's scale change.
Scale on maximize and fullscreen is prevented for 1 > scale < 1.05.
FIX: ReadOnly for file dialogs set from RunTime user's fix.
QRectMask set pass only for edition border.
Cursor position into status display on "Ctrl" hold is added.
!!: To session object plain resources allocation dataM (pthread_mutexattr_t) is added and used for mOpen, mStProp.
FIX: Service is fixed for errors at page's widgets miss and recreate session try.
mCalcRes moved to pthread_mutexattr_t.
Select-group areas control of Development mode is moved to function selAreaUpdate() and moved
from Paint-event to particular places, mostly for fix dotted-box on selected moving for primitive
"Document" based on WebKit.
Set transparent background palette for the pages included to container.
Prevent Widgets copy or cut from self to self.
FIX:ElFigure: Index out of range next fix.
FIX: Widgets into libraries doubling at global tree update is fixed.
FIX:WebVision: Posible crash into primitive ElFig fix.
!!:UI.{QTStarter,QTCfg,Vision}: Adapted for Qt5, exclude Phonon.
QTStarter,QTCfg: Next "QT" to "Qt" renaming.
VCAEngine,Vision,WebVision: The primitives "Text", "Protocol", "Document", "Diagram" are moved to indexes from types.h.
VCAEngine,Vision:
!!!!: New view "Table" of primitive "FormEl" is added.
!: Update "ID" value to validated and return it by control interface for allow next modifications make from UI.Vision.
Vision,WebVision: To primitive "Diagram" and "Protocol" set trace time to real data time is allowed.
FIX: Possible crash on view "Spectrum" of primitive "Diagram" build is fixed, for tTime lesser of tTimeGrnd.
FIX: Possible hang into primitive "Diagram" for parameters into logarithm and mostly individual scale,
by prevent negative and zero values.
- Special:
FLibSYS: Unified CRC() calculation function is added.
!:FIX:SystemTests: Tests execution rules from config file fix.
- DB.*,Transport.*: TBD, TTransportIn and TTransportOut moved to use TConfig::cntrCmdMake().
2013-12-21 Roman 0.8.0.9
- SYS: "StartupNotify=false" line is added to *.desktop files.
TCntrNode: The attribute "force" is added to node control interface's commands "load" and "save".
!: Modification controlled writing to the config file is added for prevent writing unmodified fields dependent from system environment.
For the CPU frequency obtain used /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq and fields "cpu MHz",
"bogomips", "BogoMIPS" of /proc/cpuinfo in that order.
!!: Global definitions OBJ_ID_SZ and OBJ_NM_SZ is added and used for all configuration's ID and NAME.
Field's NAME limit length pass to configurators by field "idm", through OpenSCADA control interface.
FIX:TCntrNode: chldList() fix for negative group index correct processing and list clear anytime.
FIX: Date format into spec-files some fixed.
- DB: To functions TBDS::dataGet() and TBDS::dataSet() "forceCfg" flag is added for allow system data storing priority into config file.
For the system data set data bases connections table "DB".
Prevent writing to the config file empty fields for appropriate empty tags write.
!:MySQL: MULTI_STATEMENTS requests is enabled, but process and return only first result.
- TTransport: The output transport restart is set on the address change for allow to change the from internal procedures.
FIX:Serial: Set writing modem's exit command without next line symbols.
Sockets: Some code clear.
- Protocol.UserProtocol: To input transport's process procedure context is added attribute "tr" for input transport object represent.
- DAQ.{BlockCalc,LogicLev,ModBus},Archive,UI.VCAEngine:
Links to DAQ parameters and attributes is adapted for parameters to parameters including path like "{Mod}.{Cntr}.{Prm1}.{PrmN}.{Attr}".
- DAQ: Functions TDAQS::ctrListPrmAttr(), TDAQS::prmAt() and TDAQS::attrAt() are unified for no depending from order.
Function TDAQS::daqAt() is added for access to any DAQ path's items by TCntrNode, also used into TDAQS::prmAt() and TDAQS::attrAt().
Parameter: User's API function "DAQ.{Cntr}.{Prm}.cntr()" is added for access to the controller's object from any level parameter object.
FIX:TController: The controller's object strange reenable after its a parameter copy is commented.
JavaLikeCalc: "Null" value set to return false for cast to Boolean. For no present object return set Null.
Syntax highlight rules some improved for keywords "in" and "var" not higlight into variable form.
FIX:LogicLev: The parameters enabling to processing is made typical for nested parameters processing allow.
!!:LogicLev: Empty parameters as clean container creation allow.
FIX:DAQ.ModBus: Task terminated state display is added to status.
No lost connection restore for synchronous write mode and bits from register using is fixed.
Node's lock attributes into the protocol Node's mode "Data" is fixed.
For node's mode "Data" the register's and coils's blocks separated to read and write, for zero item's problem fix.
!!!!:OPC_UA: Publish, Subscribe, MonitoredItem and related services support for input protocol's part is added
(No Publish responds for LTS).
For access to EndPoints (EP) data is added and used self pthread_mutex_t.
Some variables is renamed and TSYS::taskEndRun() used for a task end command detect.
Service "BrowseNext" and ContinuationPoints for it is added.
Server part function reqData() is separated for OPC_UA binary encoding part into library and
same data request depend from the server data model specific for data services "Browse", "Read" and "Write".
Auth methods UserName and X509Identity processing is added, but not check yet for real users into OpenSCADA.
Secure channel's TokenId renew support into server part is implemented and some fixed into client part.
RePublish service and retransmission queue processing is added. Maximum notes per publish processing is added.
All library's files moved to separated folder libOPC_UA. The library libOPC_UA simple test program is added.
The library libOPC_UA namespace is changed from OSCADA_OPC to OPC.
From function messIO() two last arguments are removed.
Removing for assigned subscriptions at the session closing is added.
Server's services Browse, Read and Write is mostly rewrited.
Server's services Browse and Read is set for field "Name" of nodes return for OPC UA "BrowseName" request.
FIX: nodeClassMask processing into service "Browse" is fixed for input part.
FIX: Call tr.at().messIO() without return is fixed. Removed request's messages binary dump for debug messages.
FIX: Close input socket by CloseSecureChannel request.
- !!:TArchVal: LibGD2 using into core is fixed by set variable HAVE_GD_CORE.
To makeTrendImg() the argument for file type provide is added.
Test forming archive's values trend into "SVG" at LibGD miss is added.
Value archive's trend build is implemented through SVG for LibGD2 into core disable.
- FIX:Archive.{FSArch,DBArch}: Alarm messages by negative level requesting from messages archive is fixed.
- !!:FIX:TArchVal: allow access to next level archive into single request, like from 1m to 10m.
- UI:
{QTCfg,Vision}: Bind key combination Shif+F1 for WhatThis calls.
{VCAEngine,Vision}: Group attributes setting function Vision::attrsSet() is rewrited for strong ordering for
fix unordered writing to some yet missed attributes that appeared after upper changes; detected on primitive "ElFig".
FIX:{Vision,WebVision}: Two method applied for prevent primitive "Diagram" possible hung on some data combination begin
from different archivators.
Primitive "Diagram" horizontal scale width calculation is improved and fixed (for WebVision).
FIX:QTCfg: Detected node select by search into field from bellow is fixed for copy to the field.
QTCfg: Copy a node into the branch and no select direct the parent node, by copy to self, support is added.
Field "NAME" limit length apply to nodes append dialog is added.
WebCfgD: Type for media-file using is added for other to png images, like "svg" allow.
VCAEngine: Negative widget's position coordinate is allowed.
SVG extension is added for media-files inline navigation.
Map areas limit for primitive "Media" is expanded to 20.
FIX: The original "Alignment" variants text list for texts is fixed.
FIX: Dynamic linking to nested parameters is fixed.
FIX: Disable empty template attribute using for document generaton for primitive "Document".
FIX: Remove wrong inline navigator at media-resources for no "String" attributes.
!!!!:FIX: Lost attribute "name" the global ability to see after change primitive "FormEl" view from "Button"
to "Tree", "List" and other is fixed by A_FormElName force set it for all "name" attributes of primitive "FormEl".
FIX: Possibility for open and include new page to container the page into the "f_start" stage.
FIX: "prm:*" dynamic links wrong set is fixed by remove prefix "a_" from last item - attribute.
Vision: Tool windows centering is disabled and new pages loading by load("") is moved to constructor RunPageView for
allow DE for custom control to the windows placing behaviour.
Deprecated QPalette::Background is replaced to QPalette::Window.
GeomZ set to UP for the widget copy is added. New widget's id enumerated generation is made simpler.
FIX: UnDo records for align events, into development mode, set only for real changed widgets.
FIX: Mouse cursor shape changing allow into included editable widgets is fixed for the parent widget size
containing or equal to the widget.
FIX: Some original texts into the source is fixed.
FIX: To generic widget editable combo checking for equal to set text is added for prevent selection and cursor position lost.
FIX: No actions update on the library's widget rename or remove is fixed.
FIX: Set focus to MDIArea window after a widget drop to the window.
FIX: Some fix moving mouse pointer on widget-container resize from keyboard.
FIX: Allow "MousePress" event forming at the primitive "Media" map area click, after self specific event forming.
ElFig: Internal object's indexes SpecIdx and ShapeType are moved to global space.
Next code clean and refactoring, mostly for moveItemTo().
Control points set smaler and different coloring for linked and other.
FIX: Reloading is fixed after some figures append.
FIX: Bordered figures width scale is fixed.
FIX: Color's and Image's indexes copy on inundations copy is added.
FIX: Some checks to allowing the indexes is added for prevent different crashes by out of range.
FormEl: To view "Tree" set to "value" selected item used original item.
To views "Tree" and "List" set scroll and expand to selected item is added.
WebVision: Font's size obtain by getFont() is added and used for "FormEl" elements height tune.
FIX: Primitive "ElFigure" update at parent scaling change is fixed. Scroll for Box-containers is enabled.
FIX: Primitive "Diagram" cursor scale is fixed.
FIX: Oppress scroll for include page size equal to the container.
FIX: NaN value display prevented by check argument's result of the primitive "Text".
- !!:Special.FLibSYS: Some code clear.
2013-09-15 Roman 0.8.0.8
- FIX:SYS: User API function childIns() is fixed for XMLNodeObj argument 1.
- !:FIX:Archive.FSArch: Messages to plain archive placing is fixed for big, on string buffer size limit.
- FIX:DAQ.JavaLikeCalc: System functions removing is allowed.
- FIX:DAQ.ModBus: Wrong EVAL set by link id on error writing by output link is fixed.
- !:FIX:TVal: Stop archive is added on the object disable for unlock it and allow to finish act.
The problem often observed on DAQ parameter's configuration change.
- FIX:UI.VCAEngine: Archive's limit for primitive "Document" is fixed for expand to 1000000.
- !!:FIX:UI.{Vision,WebVision}: Items configuration loading of primitive "ElFigure" is fixed for demand to all points present.
The function attr{s}Set() of primitive "ElFigure", and "FormEl" into UI.Vision, full revised and set optimal.
Primitive "Diagram" fix to fill the trend buffer for duplicates on request to the archive for single value
and the requests moved to single request for current.
- !!:FIX:UI.Vision: Vector index_array reforming fixed for points 1 and 2 for place only common figures and once
(exclude Arc, for connection points 1 and 2). Fix crash on Lines and Arcs (previous wrong fix).
Primitive "ElFigure" fixed for scale and unscale widths by move scaling direct to the figures paint.
- FIX:UI.WebCfg: Date fields display for table and other is fixed.
- !!:SYS: Depend to module DAQ.DCON include to *-plc package.
"DESCR" DB fields size expanded from 300 to 1000 for everywhere.
NoEx flag is added to function TCntrNode::chldList().
Default string buffer size is increased from 3000 to 10000.
Default string buffer size for numbers is added by NSTR_BUF_LEN and set to 100.
*2str function implementation is changed to the switch style.
In-line links added to global functions i2s()->TSYS::int2str(), u2s()->TSYS::uint2str(), ll2s()->TSYS::ll2str(), r2s()->TSYS::real2str().
DAQ.Templates,Protocol.ModBus: String labels enumeration is added by strLabEnum().
Previous row using as template at one new creation is added.
Command line parameter "--StatName=" is added for station name set.
Station no present warning message disabled for no station select.
SYS.{WorkDir,IcoDir,ModDir},Archive.FSArch,DB.SQLite,Protocol.HTTP,Transport.Serial:
Function ctrListFS() is added and used for directories and files browsing into configure items allow.
- Transport: Address configuration record size is grown to 100.
- Transport.Sockets: The output transport is allowed for stop on the address change.
- !!:DAQ.{BlockCalc,LogicLev,ModBus},Archive.TArchVal,UI.VCAEngine:
DAQ parameters' attributes and the parameters browsing is moved to generic function TDAQ::ctrListPrmAttr() and used everywhere.
- DAQ.DAQGate: Sync inter remote station period disabling is allowed by set the value to zero.
- DAQ.{DAQGate,ModBus}: Gather task hot sheduling change is added.
- DAQ.JavaLikeCalc: Set default value to EVAL_REAL instead EVAL_STRING on value request is made for performance some increase.
"break" into the virtual machine commands is replaced to "continue" for some performance increase.
- !!!:DAQ.ModBus: Complex type "String", registers block, support is added to DAQ by suffix "_s" to the register "R[I]".
Complex types "Integer" (32 bit signed), "Float" and "String" (registers block) support is added to Node object of input protocol.
Attributes list field size is increased to 100000.
- !!!!:DAQ.OPC_UA,{Lib,Protocol}.OPC_UA:
OPC UA protocol's part for Client and Server is moved to LGPL v3 library for allow and simplify using by other projects.
Controller's object is made simply for EndPoints and transports selection and configuration.
For now you can set only EndPoint and the transport will created from it. Also for the controller object enabled
you will take list for browsed and allowed endpoins.
TokenId and SessionId allowed for complex NodeId processing and tested on Ignition OPC UA server.
OPC UA server fix for merged input messages processing.
Services "OpcUa_CreateSubscriptionRequest", "OpcUa_CreateMonitoredItemsRequest", "OpcUa_TranslateBrowsePathsToNodeIdsRequest",
"OpcUa_PublishRequest" first implementation is added.
Server objects and variables is added: "Server"->("ServerStatus"->"State", "NamespaceArray").
Generic node's attributes processing mostly improved and expanded.
- !:UI.{VCAEngine,Vision,WebVision}: Into primitives "FormEl", "ElFigure", "Media", "Box" are used indexes definitions from "types.h".
- UI.{Vision,WebVision}: Set background palette of run-time window to unbordered master page.
- UI.{Vision,VCAEngine}: View items variant "Tree" is added to primitive "FormEl".
Resources list and files in-line browsing is added for image/media attributes.
Mime table of containers is allowed for direct download, not only to selected, and mime detect from extension;
mime also used for unload files. Set limit for downloaded files size.
- UI.VCAEngine: Export symbols moved to file types.h and it allowed for include from visualizers.
The include widgets to box change parent on widget library's or page's parent change is added, on the enable.
TSYS::int2str() replaced to i2s().
- UI.Vision: Inactive mode for primitive's "FormEl" items set readonly but allow for scroll and other unmodified operations.
Set current value of primitive "FormEl" is moved to separated function.
- UI.WebVision: Some code clear for primitive "ElFig".
2013-07-11 Roman 0.8.0.7
- TArchVal,UI.WebCfgD: Compression level for PNG creation is set to optimal for time level '1'.
- SYS,*: Include I18N.mk script direct to core and modules' *.am files.
- !!:FIX:DAQ.JavaLikeCalc: Remove wrong syntax rule "expr OR CONST{" but finite action to first constante independent next operations.
Conditional logical commands '||' and '&&' is fixed for constants.
- Transport: "Request" tab of output transport is set accessable all time and any request send cause the transport start try.
- DAQ.DAQGate: Alarms generation on connection problems is added.
- !!:FIX:Transport.{Sockets,Serial}: Check for write() errors and EAGAIN by select() into input transports is added.
- FIX:UI.{Vision,WebVision}: The primitive "Diagram" data buffer's loading by current data and lost old data by limit is fixed by
write current values to pixel-size alignment time.
- !!:FIX:Transport.{Serial,Sockets}: Errno EAGAIN process is added to write() for output transport for prevent errors on big data transfer.
- !!:UI.WebVision: Session object's ID is renamed to PATH and nodeName() set to separated string by "." path.
PNG compression level option is added for some performance control on images build and default value set to "1".
- !!!:TCntrNode: For flags, and for modifications also, used connections' mutex instead node resource.
Deprecated feature removed from save().
- DAQ.SoundCard: Acquisition task, from PortAudio, priority set is provided. Some error messages is added. Some performance is rose.
- UI.Vision: QFileDialog save context moved to root object's function getFileName() for development and run modes.
To development mode window's title is added the station name.
- TArchVal: Tab "Values" items list into values table is inverted.
- DAQ.{ModBus,LogicLev,BlockCalc,Siemens}: Prevent executable context reload from DB on the controller run.
- FIX:UI.Vision: Twice inundation contour drawing into primitive "ElFigure" is fixed.
Two events generation for buttons of primitive "FormEl" is fixed.
- DAQ.Template,DAQ.{JavaLikeCalc,ModBus},Protocol.UserProtocol,UI.WebUser: Procedure text limit for the DB field is expand to 1000000.
- UI.{VCAEngine,Vision,WebVision}: To view "Trend" of primitive "Diagram" added attribute "sclHorPer"
for force (disable automatic mode) grid period of horizontal scale set.
- FIX:UI.Vision: Prevent exit on close last run-project window if it have not correct session opened.
- UI.Vision: The warning dialog for request to select present session or to create new is rewrote for allow cancel and mostly to clean.
Antialiasing enable for draw lines width more 2 is added to primitive "Diagram".
- UI.{Vision,WebVision}: Values dimension limit, for primitive "Diagram", is expand to 5 symbols for prevent early using exponential form.
- FIX:UI.{Vision,WebVision}: Absolute rounding to hours of view "Trend" of primitive "Diagram" for horizontal scale length more hours is fixed
by hours count into Unix time value "0" (for zone 2 is 1.1.1970 3:0:0), on the grid draw.
- FIX:DAQ.Template: Omit for copy "DB" field on the template library node copy.
- !!!:UI.{VCAEngine,Vision,WebVision}: To primitive "Diagram" trends build from direct data is added, by prefix "data:" and "line:".
- !:FIX:UI.Vision: Function WdgView::attrsSet() is added and used for group attributes set into one request,
for prevent several linked events lost on processing and general performance rise on network.
- UI.WebVision: Functions modStart() and modStop() is added for the events from OpenSCADA core process.
- !!:DB.SQLite: Opened transaction close on the module stop is added for prevent data lost after crash on some other module
detach, for example UI.QTStarter module is often crash, by QT4 components' problems.
- !:FIX.UI.Vision: Primitive "ElFigure" next changes and fixes:
- Crash on click to common point for arc's points 1,2 and line point 1 is fixed.
- Not full anti-aliasing is fixed.
- Significant code clear.
2013-05-11 Roman 0.8.0.6
- !:UI.QTStarter: Wrong "QT" mostly renamed to "Qt". Messages translation from original Qt4 dialogs is fixed and appended.
- UI.Vision: Exit on last run project close control is added for run projects.
- Several arcs' point 5 separating is fixed on keyboard and mouse move.
- Mouse cursor moving according to keyboard moving is added.
- Circle contour gap by moving from keyboard is added.
- FIX:DAQ.DCON: "DO_METHOD" separated symbol ',' is fixed to ';' and "8DO (#AA00FF)", 12DO (#AA000FFF) is fixed for channels number.
- FIX:DB.PostgreSQL: Connection procedure is rewrote for allow connect to need DB and only for errors connect to "template1",
check for present and create for need. The allow to set permition only to need and present DB, without "template1".
- SYS: Default messages level is set to "Info (1)".
- !!!!:UI.{VCAEngine,Vision,WebVision}: Scales separation for different parameters of primitive "Diagram" is implemented.
- UI.Vision: Status line display control is added for run projects.
- UI.WebVision: The property "Margin" for primitive "Text" behavior is changed and border calculation added.
- UI.WebVision: Control information clear for closing pages is added. "overflow: hidden;" for primitive "Text" is added.
- !!:UI.WebVision: External JS file "WebVisionVCA.js" loading try from current directory is added. JS code changes:
- mostly clean and fix;
- zero opacity checking is added for background disable;
- asynchronous main cycle requests try;
- primitives 'ElFigure', 'Media', 'FormEl' mostly adapted for prevent non full context replacing on single dynamic properties change.
- drag for images is disabled for FireFox.
- FIX:UI.WebVision: Mostly JS code clean, direct objects free is added, memory leak fix into this.mousedown and this.mouseup functions' arrays.
- DAQ.DCON: Any other besides "Serial" transports selection is allowed.
- SYS.Value: Attribute print name is set to container name and the attribute description.
For empty name used only the attribute description.
- FIX:SYS,UI.{Vision,WebVision}: Precision boundary for real to string converting is set to > 0. Padding boundary is set to (-1000;1000).
- FIX:Archive: Access to source for "Passive" mode is disabled.
- DAQ.Siemens: Try requests for different DB disabled on the task endrun.
- SYS.{TCntrNode,TPrmTmpl},DAQ.JavaLikeCalc,UI.{VCAEngine,Vision}:
For tables list used preferable table name instead the table mask "[TableName]".
- !:FIX:ModShedul,Archive.FSArch,DB.DBF:
The hidden problematic readdir() function is replaced to reentrant variant readdir_r().
- FIX:SYS: ieee754_float using instead ieee754_double into floatLE() and floatLErev() is fixed.
- Archive.{FSArch,DBArch}: Editable control for Values and Messages archives' configuration fields depends from "Start" state is added.
- FIX:UI.Vision: Documents export is made equal to display and clean.
- UI.WebVision: To JavaScript function getColor() opaque obtaine property is added.
- UI.{Vision, WebVision}: Source files of primitive "ElFigure" is reformatted for replace 8 spaces to tabs and other fix.
2013-02-28 Roman
- FIX:Archive.FSArch: Wrong EVAL place on archive files seam is fixed.
- Transport.Sockets: Editable control for Input transport object's configuration fields depends from "Start" state is added.
- !:FIX.UI.Vision: Primitive "ElFigure" changes and fixes:
- Value range define is added and used.
- ShapeItem::Type enumeration for figures "Line", "Arc" and "Bezier" is added.
- Significant code clear;
- Widths, Styles and Colors indexes copy on the figures copy is added.
- !:UI.{Vision,WebVision}: Expanded upper limit for primitive's "Diagram" parameters number to 20.
- !!:DAQ.DCON: Significant changes from Almaz Karimov:
- analog inputs reading of one methods is added;
- the method 1AO (#AA) (blocks NL-1AO, I-7021, ADAM-4021) working is fixed;
- the method 4AO (#AACN) is added for working with block ADAM-4024;
- the digital inputs reading methods @AA is replaced to $AA6 for compatibility with ADAM blocks;
- the digital outputs writing methods 4DO (#AA000F), 8DO (#AA00FF), 12DO (#AA000FFF) is added for working with ADAM blocks.
- !:DAQ.JavaLikeCalc: Assigns separating by symbol ',' is added to the language for like the constructions:
var1=1, var2=3, var4=var1+var2;
for(var1=0, var2=0, var3=-1; var1 < 10; var1++, var2++) var3++;
- UI.WebVision: Attribute "width='100%'" is added to primitive's "Protocol" table for fill full the widget width.
- UI.Vision: Symbols '\n' process is added into attribute "name" of "Button" type of primitive "FormEl" for multiple line text
into buttons show allow.
- FIX:UI.VCAEngine: Lock session on enabling try pages with broken child widgets, like no parrent set, is fixed
and the error ignored for full project start.
- FIX:UI.VCAEngine: Global attributes translation read for field "CFG_VAL" is fixed.
- FIX:UI.Vision: Attributes change for group widgets and for equal to first attribute value into the group is fixed.
- FIX:DAQ.BlockCalc: Parameter's attributes first checking for remove is removed for prevent to free linked but present attributes.
- FIX:DAQ.JavaLikeCalc: Unaligned access for double and integer constants is fixed for some ARM-processors.
- FIX:UI.QTCfg, UI.Vision: Find shortcuts for TextEdit widgets is set context to the widget.
- UI.Vision: The file dialog for export is set stored for save directory place and other.
- !!:UI.WebCfg: Source code is made clean and some values encoding to HTML is fixed.
- !:SYS: User API function SYS.mktime() is added for get time since the Epoch 1.1.1970 converted from broken-down time.
- FIX:DAQ.JavaLikeCalc: Increment, decrement and like operations fixed for object's items.
- DAQ.JavaLikeCalc: IO type sets to "Text" and display its into DAQ attributes.
- FIX:UI.VCAEngine: Using "Object" type into primitive "Document" calculation environment is fixed.
- UI.VCAEngine: The primitive "Document" generation starting is added by set attribute "time" to zero and previous no zero restore.
2013-02-02 Roman 0.8.0.5
- FIX:UI.QTStarter: Splash early hide is fixed by the splash hide only after all "Qt" modules processing.
- !:FIX:Function: Remove function gettimeofday() twice call on it execution time measurement, for each calls.
Add the function execution time limit to 10 seconds.
- FIX:Security: Group tab's name is fixed.
- SYS: Translation for core update.
- SYS:ModSched: Fields "ModAllow" and "ModDeny" open for edit and save its to config-file.
- UI.VCAEngine: Brackets '' processing into syntax highlight rules for XHTML tag's attribute is added.
- UI.Vision, UI.WebVision: Default loadable tag for primitive "Document" set to "body".
- DB, DB.*: Editable control object's configuration fields depends from "Enable" state is added for DB object.
Some charsets list for field "CODEPAGE" is added.
- DAQ.LogicLev: Editable control for Controller object's configuration fields depends from "Start" state is added.
2013-01-26 Roman
- DAQ.Templates, DAQ.LogicLev, DAQ.ModBus, DAQ.Siemens:
IO type sets to "Text" and display its into DAQ attributes and template's constants.
- Transport.Serial: Editable control object's configuration fields depends from "Start" state is added for input transport.
- FIX:UI.Vision: Size points for selected widgets into development mode display is fixed.
- FIX:SYS: RPM build spec-files some fixed for ALTLinux.
- SYS: Tasks priority level context help message is added.
- !:DAQ.*: Editable control for Controller object's configuration fields depends from "Enable" and "Start" stats is added.
- !!:DAQ.ModBus: Context help for protocol's node into "Data" mode for data's field "Id" and link status by "(+)" is added.
ModBus protocol log generation is some updated and added this messages into tab "Diagnostics" of the Controller object,
for debug level (0).
- !!:Transport.Serial: Configure field "Priority" for input transport's task is added.
- !!:UI.VCAEngine: Primitive "Diagram" field "Parameters number" limit expand to 20.
- Archive: Level field for messages list set selectable from readable levels "Debug (0);Information (1);...".
- UI.VCAEngine: "f_start" and "f_stop" attributes set on user API SYS.UI functions use this.wdgAdd() and this.wdgDel().
2012-12-31 Roman
- DAQ.Serial: Working with modem process log is added.
- FIX:UI.Vision: MDI window icon generation and set is fixed.
- !!:UI.Vision: Real visible a widget part (by pixel) checking is added and used for events generate and context menu call,
mostly used for "Box" and "ElFigure" primitives.
2012-12-11 Roman
- FIX:DB.PostgreSQL: Text fields cut to declared length on write to DB for long string errors from PostgreSQL prevent.
- FIX:DAQ.LogicLev: "PRM_BD" and "PRM_BD_REFL" DB fields length expanded to 40 and 50 symbols.
- !:FIX:UI.Vision: Primitive "ElFigure" arc drawing quality is fixed.
Arc and other figures drawing code is mostly cleared and make time optimal.
- FIX:UI.Vision.ElFigure: Multiple edit exit function call is fixed and it is fixed some problems into the primitive.
Variable "itemInMotion" set to NULL into edit enter for some cases crash into the primitive prevent.
Circle contour gap is fixed for begin and end points seperating.
QPainter::Antialiasing is enabled for lines with width and border more and equal to 2 pixels for some fix low quiality big arc.
- FIX:UI.Vision: Inner widgets edit border building fixed for inner-widget contains widget-container.
- !!:FIX:SYS: Adapting to one symbol system charsets support, tested on KOI8-R:
- TMess::codeConv() change quiet and for replace wrong symbols to '?'.
- TVariant: Userspace object loading (parsing from string) from XML and default charset set from system's charset.
- XMLNode: Wrong or no present entity for XLNode parsing cause no converting termination and set symbol '?'.
- UI.VCAEngine, UI.Vision: Primitive "Document" converting charset is changed to system charset.
- UI.WebCfgD, UI.WebVision: Charset for AJAX requests forced set to UTF-8 and generic codepage set to system charset.
Charset for GD's text forced set to UTF-8.
- !!!:FIX:SYS.*: System function "getopt" for command line parsing full replaced to self implementing function TSYS::getCmdOpt()
on reason the system getopt() is not reentrant nature and wrong processing for independent calls from different OpenSCADA parts.
Start program rewrited for use SYS::getCmdOpt().
- !:FIX:Archive: Messages buffer processing task moved from creation by timer to standard OpenSCADA task for some system memory
leak prevent.
- !:TElem: Resources review for some problems prevent.
- FIX:TValFunc: Assign default value for variable "mMdfChk".
- TSYS, TModule, TParamContr, TVarObj, TEValObj: Debug objects counters for "-DOSC_DEBUG=1" and print its finish number
on exit is added.
- !!:FIX:TVal: Memory leak for objects into destructor TVal::~TVal() is fixed, detected by "ValGrind".
- !!:FIX:Archive.FSArch: Value archive data corruption into some cases by index buffer memory overlap is prevented,
- FIX:DAQ.=Tmpl=: Some updated and fixed.
- FIX:DAQ.SoundCard: TMdContr objects free early for used its data parameters objects TMdPrm is prevented, detected by "ValGrind".
- SYS.TFunction, DAQ.JavaLikeCalc, SYS.Tmpl: TValFunc execution context full moved from DAQ.JavaLikeCalc.
- FIX:UI.VCAEngine: Project's subtree copy from one project to other fixed for inherited attributes copying.
- !!:SYS: To task create function added control and freeing for finished but the object present and not detached tasks.
For prevent some errors like to "Task '...' is already present!".
- !!!:UI.WebVision: Update period time calculation is rewrited for provide more responsibility and adaption to real network
channel properties.
2012-11-13 Roman 0.8.0.4
- Archive: To value archive service request is added for name get.
- To service request made processing for longer period.
Primitive "Document" object created for filtering attributes "tmpl" and "doc" from comments and internal procedure's tags ,
2012-11-01 Roman
- !!!!:FIX:DAQ.SoundCard: Rewrited acquisition for realtime provide and control for samplerate and lost frames.
2012-10-29 Roman
- UI.WebVision: Childs update is added on "geomXsc" or "geomYsc" attributes modify.
- Transport.Serial: New flow control mode "rs485" by TIOCSRS485 is added.
2012-10-02 Roman
- FIX:ICP_DAS: Configure field "MOD_PRMS" size is expanded to "100000".
2012-09-09 Roman 0.8.0.3
- FIX:DAQ.SNMP: DAQ parameter's field "OID_LS" length expand from 100 to 100000.
- FIX:Transport.Serial: Stop output transport at read() error, possible by serial device lost.
- FIX:Archive: TVArchive::archivatorAttach() rewrited for new archivators correct attach and set it into "ArchS" config-field.
- SYS: Library "Phonon" using force disable is added for without build to pure environments with litle memory set.
- UI.Vision: Widget's childs update at single "geomXsc" and "geomYsc" changing is added, for full scale update to the subtree.
2012-07-09 Roman 0.8.0.2
2012-06-09 Roman 0.8.0.1
2012-04-25 Roman
Images update hang is prevented on previous image load lost (typical for Konqueror).
- FIX:DAQ.DAQGate: Parameters cache load/save is fixed. Attributes init fixed for XMLNodes childs process.
- SYS: Service command "" is added for config file against rescan.
- FIX:UI.Vision: Slider and Scroll bars realization of primitive "FormEl" is fixed for event generaton prevent
- !!:Archive: Link address to atribute of parameter of data source is make simpler by use DAQPath like "DAQMod.Cntr.Prm.attr".
- !:UI.VCAEngine: Uncatched events up to upper page send support is added. That allow central process global key combination and other.
- !!!!:SYS: Childs storing into map for base object TCntrNode is set to "const char*" key and all nodes have been
- !!!!:TVariant: Rewrited to storage mechanism change from "string" using to "union" and adaptive memory alloc using for strings
- FIX:UI.Vision: Crash on maximize runtime window for no one openned window project is fixed.
- FIX:DAQ: Wait to redundancy task start for archives' blocks of atributes DAQ parameters restore on start.
UnDo and ReDo acitions is fixed from activation lost on context menu calls.
- UI.Vision: Context record for widget atributes' value is moved to separated function and used also
for record context after active atribute value change.
- FIX:UI.Vision: Pointer cursor-hand lost for selected widgets after copy at some cases is prevented.
- FIX:DAQ: Status of controller objects grow is prevented on incorrect redundance configuration, from self to self.
2011-10-05 Roman
- SYS: Debian init script is updated by "almaz".
- SYS: GLibC version for EDEADLK processing hack is rised to 2.4 and features.h include for correct GLibC version check everywhere.
- FIX:DB.MySQL: Key limit to 1000 (300 UTF8) symbols hack is added for allow DB copy from SQLite to MySQL.
- DAQ.DAQGate: Return of the distributed synchronization mechanism for periodic acquisition.
- FIX:DAQ.ModBus: Error generaton on connection lost or no reply on timeout is fixed.
- !!:UI.QTCfg, UI.Vision: Syntax highlight engine is full rewrited for made simpler and prevent some hiden bugs.
- UI.QTCfg, UI.Vision: Size adjustement is added for all dialogs, after its show.
- DB: Into user API function "SQLreq()" is added set cell value to object property by collumn name, to row Array > 0.
Addon SNMP connection configuration parameters is added.
To DAQ.JavaLikeCalc addon string functions with using RegExp is realised:
- !!!!:DAQ.DCON: The module is full rewrited for fix bad format and code writing style.
- FIX:SYS.TCntrNode: User name copy to childs for group control request "CntrReqs" is set.
- DAQ.JavaLikeCalc: The VM commands CFunc, CFunc and CFuncObj is rewrited for structured access.
- !!!:FIX:Archive.FSArch: The archive files creation for messages is fixed and rewrited for more old messages place support.
- !!!!:DAQ.JavaLikeCalc: VM full rewrited for direct command's structure using.
- FIX:DemoDB: Config file is fixed at field value: ../share/openscada.
- !:Archive: Read access speed to values from soft grid buffer is rised.
- !!!!:SYS: OpenSCADA core library version is rised to 1:0:0
- !!:DemoDB: The script of main project page is rewrited to use new user's API object's functions.
- FIX:UI.Vision: Development window restor after close canceling is fixed.
- !!:Transport.Serial: Serial transport's timings store is moved to addon parameters field.
- FIX:DAQ.JavaLikeCalc: Error's collumn position calc is fixed for string constants and object's dots.
- !!:Archive.FSArch, Archive.DBArch: Addon parameters storing is moved to XML-field "A_PRMS".
- !!:FIX:DAQ, DAQ.BlockCalc, DAQ.JavaLikeCalc, DAQ.LogicLev, DAQ.Siemens: Geting broken data into redundance code for no redundance tasks and for no one reserve station present.
- FIX:DAQ.ICP_DAS: A lost tasks stoping is fixed.
- DAQ.ICP_DAS: Set EVAL value to parameters on connection lost time fixed for maximum time from current.
- DAQ.OPC_UA: Binary protocol data access function is added and present request processing is rewrited.
- FIX:UI.Vision: Time and date is localised and some updated into RunTime fullscreen mode.
- !!!!:FIX:DAQ.ModBus: Resource alloc lost on time data gathering is fixed.
- FIX:Transport.SSL: Restore try time is rised to 0.5 s.
- !!!!:Transport.SSL: Keep alive limits support is added. Reconection support is added, after connection close by server and prevent requests lost.
- Transport.Socket: Used addon parameters DB field for store properties the output transport.
- !!!:UI.Vision: An identical atributes of group widgets setup suport is added to the atributes inspector through group.
- FIX:UI.VCAEngine: Error message is added on time creation atribute with already present name.
- DAQ.ModBus: Error code into status is added for connection lost detect.
- DAQ.ICP_DAS: Fast task priority is rised to 32.
- !!:UI.VCAEngine: Object's functions of user's API is added: user(), alrmSndPlay() and alrmQuittance().
- FIX:DAQ.DAQGate: Put parameter's attributes to EVAL and set parameter's err code on connection lost.
- FIX:UI.Vision: Collumns and rows resizing is fixed for primitive "Protocol".
- UI.Vision: The childs window of main window into runtime is made not resizible and not minimizable.
- SYS.Template: The collumn "Access" is renamed to "Configure".
- !!:/DemoDB: Some fixes. Translations updating. SO main page is feature expanded. Contour frame's fonts is rised and buttons for value changing is added.
- FIX:/DAQ: Redundance data restoring is made preemptive.
- FIX:/UI/VCAEngine: Attributes init and free is rewrited and some fixed.
- FIX:/UI/VCAEngine: Processing flag inherit is fixed for atributes "vCur" and "aCur" of primitive "Document".
- !!:/DAQ, /Value, /DAQ/DAQGate: Restore from archives mechanism is some updated for lost values fixing.
- !!!!:/Archive: Archive sync conception is changed for DAQ.DAQGate and DAQ-redundance.
- !!!!:/UI/VCAEngine: DB structure version is changed to 2 for performance rise and lost records into DB prevent.
- FIX:/DAQ/DAQGate: Vertical redundance is fixed.
- FIX:/Archive/Value: Last data into buffer lost is fixed on exit. Thread call by timer replaced by standalone thread.
- FIX:/SYS: owner() method is changed to no in-line for all objects.
Used for deadline connection compensation and preventing data lost.
- /UI/VCAEngine: String alloc for direct readed value is fixed. Config template and value combined to one string container.
- !:/UI/Vision: The time field display is added to the statusbar of runtime window and on fullscreen mode.
- FIX:/UI/VCAEngine: Alarm's quittance from widget's call procedures is fixed.
The navigation panel is updated and quittance buttons is added. Volumed pipe elements is added to library and used for all mnemos.
Context menu is added for digital taps. Value's text font is rised for input's views.
- !!:/UI/VCAEngine,/UI/Vision,/UI/WebVision: The attribute 'root' moved to main attributes container. Added atribute 'parent' for parent widget info allow.
The object is used for direct access to system's ("id" and "path") atributes of widgets of UI.VCAEngine.
- /Archive: Some in-line helps is added to config-fields. Selection is added to archivator select string of accessing to values.
Realised support main calc clock reseting by resolution limit.
- /SYS: Function TSYS::cfgFileScan() is rewrited.
- !!:/SYS: Add release 0.6.3 anounce documents.
- FIX:/UI/Vision: Background palette is fixed for primitive "Protocol".
- !!:/UI/QTCfg: Use new, optimal for time, childs requst to tree build.
- !!:/SYS: Node childs control interface's request is added. Used for faster build navigation trees (QTCfg, WebCfgD).
- !!!/UI/Vision: Conception of painting is changed for primitive ElFigure, by means of wich performance is greatly improved in both: the runtime and the devel modes.
- !:/UI/VCAEngine: Independent load of generic attributes is added. For storing of geometry broken and lost base widgets of inherits.
- !!!!:/UI/Vision: For time optimal requests used new group request '/serv/attrBr'. Performance network and local request significantly rised!
- !!:/UI/Vision: The updating time control mechanism is rewrited.
- !!!!:/UI/WebVision: For time optimal requests used new group request '/serv/attrBr'. Performance of requests significantly rised!
- !:/UI/VCAEngine: Restore atribute 'time' from archived document on start is added.
- FIX:/UI/VCAEngine: Inherit flag is added to an atribute add function for first inherit fix on creation.
- !:/Special/FLibSYS: Direct access to archive or atribute's value address field is added for functions: varhBeg(), varhEnd(), varhGetR(), varhGetB() and varhGetS().
- FIX:/UI/VCAEngine: Widget's user atributes edit name, type and selected list for heritor is fixed.
- !:/SYS: New function TSYS::strMess() is added for in-line format string support.
- FIX:/DAQ/BlockClac: Small values seting allow into real block's atributes is fixed.
- /UI/Vision: Disable word wrap for texts into attributes of the atributes inspector.
- FIX:/SYS/Elements: The short DB fields length atribute is fixed.
- !!:/SYS: Add release 0.6.2 anounce documents.
- FIX:/UI/Vision: Runtime window maximize and fullscreen on start is fixed.
- !!:/DAQ/JavaLikeCalc: Numbers process mechanism is rewrited. All generic operations made work with real type data, no integer separately.
- FIX:/DAQ/BlockCalc: No clear old atributes after attribute identifier changing is fixed.
- /UI/Vision: Maximize include widgets to container box size is added.
- /UI/Vision: Work pages attributes moved to QT object's atributes store.
- FIX:/UI/Vision: Maximize and full screen runtime window mode is fixed.
- /UI/Vision: Full screen and maximize run window attributes moved to project.
- FIX:/UI/Vision: Big images scroll position lost on development is fixed.
- /UI/Vision: Unselect included widgets on development at lost focus is disabled.
- FIX:/UI/Vision: Move childs widgets on development is fixed.
- FIX:/UI/Vision: ElFigure update view on atributes change is fixed.
- !!!/UI/WebVision: painting of the thick primitives ElFigure is modified for synchronization with QT.
- !:/UI/Vision: Filling mechanism for primitive ElFigure is changed for synchronization with Web.
- FIX:/UI/Vision: Size points widget's lost release mouse event is final fixed.
- FIX:/UI/Vision: Size points first appearance time wait is added (500ms). For mouse release event lost prevention.
- !!:/SYS/Node: TCntrNode::nodeDel() finction is added.
- FIX:/UI/Vision: The master page open procedure is rewrited.
- !:/UI/VCAEngine: Support user atributes into included widget's is added.
- FIX:/ModSched: Control modules libraries object SHD storing is rewrited.
- FIX:/DB/FireBird: FielSet() command is rewrited for made SQL INSERT optimize.
- FIX:/DAQ/DiamondBoards: Commands to atributes process is disadled on time controller stop.
- /UI/QTCfg: Changed atributes storing on page update is made.
- !:/DAQ/ModBus: Tune serial port atributes support is added. Some performance fixes is made.
- !!:/UI/Vision, /UI/VCAEngine: Focus atribute and events is added. Dynamic page linking support is added.
- FIX:/UI/VCAEngine: No visual atributes update transfer cause is fixed.
- FIX:/UI/VCAEngine: Deleting attributes of inheritable widgets on time deletion atributes of base widgets is fixed.
- FIX:/UI/VCAEngine: Change atributes processing is fixed.
- /UI/Vision: A palette widget's resizing from keyboard is added.
- FIX:/UI/Vision: Some crash into atributes inspector on time group widgets access is fixed.
- !!:/UI/Vision: Group widgets resizing is rewrited.
- FIX:/UI/Vision: The size hint for text fields of the atributes inspector is fixed.
- FIX:/UI/Vision: Resize widgets priority (box and childs) is fixed.
- FIX:/UI/Vision: Lost edit focus, on time atributes edit, is fixed.
- !!!:/WebCfg: Modul most rewrited.
- FIX:/UI/VCAEngine: Writing some no active atributes is fixed.
- !!:/UI/Vision: Path creation full rewrited for primitive "ElFig".
childs of session (pages and session's widgets).
- FIX:/DB/MySQL: Session lost is final fixed.
- FIX:/Control: A dublicate childs object no deleting is fixed.
- /UI/QTCfg: Vertical scrolbar position save is made.
- FIX:/UI/Vision: The atribute inspector is fixed for multilevel virtual groups process.
- /TElem: Addon attributes support is added to Control expression generator (TFld::cntrCmdMake()).
- /SYS/TCntrNode: Finctions connect() and disConnect() is renamed to AHDConnect() and AHDDisConnect().
- FIX:/DB/MySQL: Restoring the lost server connection is added.
- FIX:/DAQ/LogicLev: Pass removing blocked atributes is fixed.
- FIX:/DAQ: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/BlockCal: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/DiamondBoards: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/JavaLikeCalc: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/OperationSystem: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/Parameter: Fix no deleting parameter atribute's values.
- FIX:/Parameter: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- /TParam: Change logical level mechanism. Independent calc the template function and get a link atributes
- Removed support the "mode" control scenario`s atribute.
- /Parameter: Add base error info atributes: "err" and "err_mess".
- /Controller/BlockCalc: Made the multi block atributes mirorring to parameter.
- Fix:/Value: Fixed atributes direct read and write.
- Fix:/Controller/DiamondBoards: Fixed the atributes direct writing.
- !!!!:/Modules: Rename atributes: Source, Vers, Autors, DescrMod and License to mSource, mVers, mAuthor, mDescr and mLicense.
- !!!!: /System: Delete function TError::what(). Use public atributes cat and mess.
- /UI/QTCfg: Add checking atribute "descr" to a size for the changing structure page detect.
- !!!!: TGrpModule and childs: Replace function gmdInit() to gmdLoad().
- TKernel: Move atributes of the default DB to private section;
- XML::attr: Delete parameter 'add'. Now, always add atributes.
- TModule: Change acces to export finctions. Change function modGetFunc() and
- fix TContr::SYS length of atribute "seconds full" for uptime more than 5 symbols.
- UI::qtcfg: Fix go childs method!
- XML: add clean_childs() function and fix destructor!
- TValue: Add AutoHD resources for access to atribute;
- TContr: add atribute "o_name";
- TParamS: add owner and o_name atributes;
- TModSchedule fully rewrited;
- Fix no cleaned atribute in function XMLNode::cleanup();
- Fix no loading atributes of root XML node into XMLNode::load_xml();
- Clean n_opt atributes anywhere;
- create method Owner() instead public atribute owner;
- change BD, Archive ... atributes of TKernel to BD(), Archive() ... function
- fix destructor ~TGRPModule and into childs;
