2012-07-09 Roman 0.8.0.2
2012-06-09 Roman 0.8.0.1
2012-04-25 Roman
Images update hang is prevented on previous image load lost (typical for Konqueror).
- FIX:DAQ.DAQGate: Parameters cache load/save is fixed. Attributes init fixed for XMLNodes childs process.
- SYS: Service command "" is added for config file against rescan.
- FIX:UI.Vision: Slider and Scroll bars realization of primitive "FormEl" is fixed for event generaton prevent
- !!:Archive: Link address to atribute of parameter of data source is make simpler by use DAQPath like "DAQMod.Cntr.Prm.attr".
- !:UI.VCAEngine: Uncatched events up to upper page send support is added. That allow central process global key combination and other.
- !!!!:SYS: Childs storing into map for base object TCntrNode is set to "const char*" key and all nodes have been
- !!!!:TVariant: Rewrited to storage mechanism change from "string" using to "union" and adaptive memory alloc using for strings
- FIX:UI.Vision: Crash on maximize runtime window for no one openned window project is fixed.
- FIX:DAQ: Wait to redundancy task start for archives' blocks of atributes DAQ parameters restore on start.
UnDo and ReDo acitions is fixed from activation lost on context menu calls.
- UI.Vision: Context record for widget atributes' value is moved to separated function and used also
for record context after active atribute value change.
- FIX:UI.Vision: Pointer cursor-hand lost for selected widgets after copy at some cases is prevented.
- FIX:DAQ: Status of controller objects grow is prevented on incorrect redundance configuration, from self to self.
2011-10-05 Roman
- SYS: Debian init script is updated by "almaz".
- SYS: GLibC version for EDEADLK processing hack is rised to 2.4 and features.h include for correct GLibC version check everywhere.
- FIX:DB.MySQL: Key limit to 1000 (300 UTF8) symbols hack is added for alow DB copy from SQLite to MySQL.
- DAQ.DAQGate: Return of the distributed synchronization mechanism for periodic acquisition.
- FIX:DAQ.ModBus: Error generaton on connection lost or no reply on timeout is fixed.
- !!:UI.QTCfg, UI.Vision: Syntax highlight engine is full rewrited for made simpler and prevent some hiden bugs.
- UI.QTCfg, UI.Vision: Size adjustement is added for all dialogs, after its show.
- DB: Into user API function "SQLreq()" is added set cell value to object property by collumn name, to row Array > 0.
Addon SNMP connection configuration parameters is added.
To DAQ.JavaLikeCalc addon string functions with using RegExp is realised:
- !!!!:DAQ.DCON: The module is full rewrited for fix bad format and code writing style.
- FIX:SYS.TCntrNode: User name copy to childs for group control request "CntrReqs" is set.
- DAQ.JavaLikeCalc: The VM commands CFunc, CFunc and CFuncObj is rewrited for structured access.
- !!!:FIX:Archive.FSArch: The archive files creation for messages is fixed and rewrited for more old messages place support.
- !!!!:DAQ.JavaLikeCalc: VM full rewrited for direct command's structure using.
- FIX:DemoDB: Config file is fixed at field value: ../share/openscada.
- !:Archive: Read access speed to values from soft grid buffer is rised.
- !!!!:SYS: OpenSCADA core library version is rised to 1:0:0
- !!:DemoDB: The script of main project page is rewrited to use new user's API object's functions.
- FIX:UI.Vision: Development window restor after close canceling is fixed.
- !!:Transport.Serial: Serial transport's timings store is moved to addon parameters field.
- FIX:DAQ.JavaLikeCalc: Error's collumn position calc is fixed for string constants and object's dots.
- !!:Archive.FSArch, Archive.DBArch: Addon parameters storing is moved to XML-field "A_PRMS".
- !!:FIX:DAQ, DAQ.BlockCalc, DAQ.JavaLikeCalc, DAQ.LogicLev, DAQ.Siemens: Geting broken data into redundance code for no redundance tasks and for no one reserve station present.
- FIX:DAQ.ICP_DAS: A lost tasks stoping is fixed.
- DAQ.ICP_DAS: Set EVAL value to parameters on connection lost time fixed for maximum time from current.
- DAQ.OPC_UA: Binary protocol data access function is added and present request processing is rewrited.
- FIX:UI.Vision: Time and date is localised and some updated into RunTime fullscreen mode.
- !!!!:FIX:DAQ.ModBus: Resource alloc lost on time data gathering is fixed.
- FIX:Transport.SSL: Restore try time is rised to 0.5 s.
- !!!!:Transport.SSL: Keep alive limits support is added. Reconection support is added, after connection close by server and prevent requests lost.
- Transport.Socket: Used addon parameters DB field for store properties the output transport.
- !!!:UI.Vision: An identical atributes of group widgets setup suport is added to the atributes inspector through group.
- FIX:UI.VCAEngine: Error message is added on time creation atribute with already present name.
- DAQ.ModBus: Error code into status is added for connection lost detect.
- DAQ.ICP_DAS: Fast task priority is rised to 32.
- !!:UI.VCAEngine: Object's functions of user's API is added: user(), alrmSndPlay() and alrmQuittance().
- FIX:DAQ.DAQGate: Put parameter's attributes to EVAL and set parameter's err code on connection lost.
- FIX:UI.Vision: Collumns and rows resizing is fixed for primitive "Protocol".
- UI.Vision: The childs window of main window into runtime is made not resizible and not minimizable.
- SYS.Template: The collumn "Access" is renamed to "Configure".
- !!:/DemoDB: Some fixes. Translations updating. SO main page is feature expanded. Contour frame's fonts is rised and buttons for value changing is added.
- FIX:/DAQ: Redundance data restoring is made preemptive.
- FIX:/UI/VCAEngine: Attributes init and free is rewrited and some fixed.
- FIX:/UI/VCAEngine: Processing flag inherit is fixed for atributes "vCur" and "aCur" of primitive "Document".
- !!:/DAQ, /Value, /DAQ/DAQGate: Restore from archives mechanism is some updated for lost values fixing.
- !!!!:/Archive: Archive sync conception is changed for DAQ.DAQGate and DAQ-redundance.
- !!!!:/UI/VCAEngine: DB structure version is changed to 2 for performance rise and lost records into DB prevent.
- FIX:/DAQ/DAQGate: Vertical redundance is fixed.
- FIX:/Archive/Value: Last data into buffer lost is fixed on exit. Thread call by timer replaced by standalone thread.
- FIX:/SYS: owner() method is changed to no inline for all objects.
Used for deadline connection compensation and preventing data lost.
- /UI/VCAEngine: String alloc for direct readed value is fixed. Config template and value combined to one string continer.
- !:/UI/Vision: The time field display is added to the statusbar of runtime window and on fullscreen mode.
- FIX:/UI/VCAEngine: Alarm's quittance from widget's call procedures is fixed.
The navigation panel is updated and quittance buttons is added. Volumed pipe elements is added to library and used for all mnemos.
Context menu is added for digital taps. Value's text font is rised for input's views.
- !!:/UI/VCAEngine,/UI/Vision,/UI/WebVision: The attribute 'root' moved to main attributes container. Added atribute 'parent' for parent widget info allow.
The object is used for direct access to system's ("id" and "path") atributes of widgets of UI.VCAEngine.
- /Archive: Some inline helps is added to config-fields. Selection is added to archivator select string of accessing to values.
Realised support main calc clock reseting by resolution limit.
- /SYS: Function TSYS::cfgFileScan() is rewrited.
- !!:/SYS: Add release 0.6.3 anounce documents.
- FIX:/UI/Vision: Background palete is fixed for primitive "Protocol".
- !!:/UI/QTCfg: Use new, optimal for time, childs requst to tree build.
- !!:/SYS: Node childs control interface's request is added. Used for faster build navigation trees (QTCfg, WebCfgD).
- !!!/UI/Vision: Conception of painting is changed for primitive ElFigure, by means of wich performance is greatly improved in both: the runtime and the devel modes.
- !:/UI/VCAEngine: Independent load of generic attributes is added. For storing of geometry broken and lost base widgets of inherits.
- !!!!:/UI/Vision: For time optimal requests used new group request '/serv/attrBr'. Performance network and local request significantly rised!
- !!:/UI/Vision: The updating time control mechanism is rewrited.
- !!!!:/UI/WebVision: For time optimal requests used new group request '/serv/attrBr'. Performance of requests significantly rised!
- !:/UI/VCAEngine: Restore atribute 'time' from archived document on start is added.
- FIX:/UI/VCAEngine: Inherit flag is added to an atribute add function for first inherit fix on creation.
- !:/Special/FLibSYS: Direct access to archive or atribute's value address field is added for functions: varhBeg(), varhEnd(), varhGetR(), varhGetB() and varhGetS().
- FIX:/UI/VCAEngine: Widget's user atributes edit name, type and selected list for heritor is fixed.
- !:/SYS: New function TSYS::strMess() is added for inline format string support.
- FIX:/DAQ/BlockClac: Small values seting allow into real block's atributes is fixed.
- /UI/Vision: Disable word wrap for texts into attributes of the atributes inspector.
- FIX:/SYS/Elements: The short DB fields length atribute is fixed.
- !!:/SYS: Add release 0.6.2 anounce documents.
- FIX:/UI/Vision: Runtime window maximize and fullscreen on start is fixed.
- !!:/DAQ/JavaLikeCalc: Numbers process mechanism is rewrited. All generic operations made work with real type data, no integer separately.
- FIX:/DAQ/BlockCalc: No clear old atributes after attribute identifier changing is fixed.
- /UI/Vision: Maximize include widgets to container box size is added.
- /UI/Vision: Work pages attributes moved to QT object's atributes store.
- FIX:/UI/Vision: Maximize and full screen runtime window mode is fixed.
- /UI/Vision: Full screen and maximize run window attributes moved to project.
- FIX:/UI/Vision: Big images scroll position lost on development is fixed.
- /UI/Vision: Unselect included widgets on development at lost focus is disabled.
- FIX:/UI/Vision: Move childs widgets on development is fixed.
- FIX:/UI/Vision: ElFigure update view on atributes change is fixed.
- !!!/UI/WebVision: painting of the thick primitives ElFigure is modified for synchronization with QT.
- !:/UI/Vision: Filling mechanism for primitive ElFigure is changed for synchronization with Web.
- FIX:/UI/Vision: Size points widget's lost release mouse event is final fixed.
- FIX:/UI/Vision: Size points first appearance time wait is added (500ms). For mouse release event lost prevention.
- !!:/SYS/Node: TCntrNode::nodeDel() finction is added.
- FIX:/UI/Vision: The master page open procedure is rewrited.
- !:/UI/VCAEngine: Support user atributes into included widget's is added.
- FIX:/ModSched: Control modules libraries object SHD storing is rewrited.
- FIX:/DB/FireBird: FielSet() command is rewrited for made SQL INSERT optimize.
- FIX:/DAQ/DiamondBoards: Commands to atributes process is disadled on time controller stop.
- /UI/QTCfg: Changed atributes storing on page update is made.
- !:/DAQ/ModBus: Tune serial port atributes support is added. Some performance fixes is made.
- !!:/UI/Vision, /UI/VCAEngine: Focus atribute and events is added. Dynamic page linking support is added.
- FIX:/UI/VCAEngine: No visual atributes update transfer cause is fixed.
- FIX:/UI/VCAEngine: Deleting attributes of inheritable widgets on time deletion atributes of base widgets is fixed.
- FIX:/UI/VCAEngine: Change atributes processing is fixed.
- /UI/Vision: A palete widget's resizing from keyboard is added.
- FIX:/UI/Vision: Some crash into atributes inspector on time group widgets access is fixed.
- !!:/UI/Vision: Group widgets resizing is rewrited.
- FIX:/UI/Vision: The size hint for text fields of the atributes inspector is fixed.
- FIX:/UI/Vision: Resize widgets priority (box and childs) is fixed.
- FIX:/UI/Vision: Lost edit focus, on time atributes edit, is fixed.
- !!!:/WebCfg: Modul most rewrited.
- FIX:/UI/VCAEngine: Writing some no active atributes is fixed.
- !!:/UI/Vision: Path creation full rewrited for primitive "ElFig".
childs of session (pages and session's widgets).
- FIX:/DB/MySQL: Session lost is final fixed.
- FIX:/Control: A dublicate childs object no deleting is fixed.
- /UI/QTCfg: Vertical scrolbar position save is made.
- FIX:/UI/Vision: The atribute inspector is fixed for multilevel virtual groups process.
- /TElem: Addon attributes support is added to Control expression generator (TFld::cntrCmdMake()).
- /SYS/TCntrNode: Finctions connect() and disConnect() is renamed to AHDConnect() and AHDDisConnect().
- FIX:/DB/MySQL: Restoring the lost server connection is added.
- FIX:/DAQ/LogicLev: Pass removing blocked atributes is fixed.
- FIX:/DAQ: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/BlockCal: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/DiamondBoards: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/JavaLikeCalc: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/DAQ/OperationSystem: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- FIX:/Parameter: Fix no deleting parameter atribute's values.
- FIX:/Parameter: Fix parameters connect/disconnect. Add checking at present of value atributes at enable parameter to object tree.
- /TParam: Change logical level mechanism. Independent calc the template function and get a link atributes
- Removed support the "mode" control scenario`s atribute.
- /Parameter: Add base error info atributes: "err" and "err_mess".
- /Controller/BlockCalc: Made the multi block atributes mirorring to parameter.
- Fix:/Value: Fixed atributes direct read and write.
- Fix:/Controller/DiamondBoards: Fixed the atributes direct writing.
- !!!!:/Modules: Rename atributes: Source, Vers, Autors, DescrMod and License to mSource, mVers, mAuthor, mDescr and mLicense.
- !!!!: /System: Delete function TError::what(). Use public atributes cat and mess.
- /UI/QTCfg: Add checking atribute "descr" to a size for the changing structure page detect.
- !!!!: TGrpModule and childs: Replace function gmdInit() to gmdLoad().
- TKernel: Move atributes of the default DB to private section;
- XML::attr: Delete parameter 'add'. Now, always add atributes.
- TModule: Change acces to export finctions. Change function modGetFunc() and
- fix TContr::SYS length of atribute "seconds full" for uptime more than 5 symbols.
- UI::qtcfg: Fix go childs method!
- XML: add clean_childs() function and fix destructor!
- TValue: Add AutoHD resources for access to atribute;
- TContr: add atribute "o_name";
- TParamS: add owner and o_name atributes;
- TModSchedule fully rewrited;
- Fix no cleaned atribute in function XMLNode::cleanup();
- Fix no loading atributes of root XML node into XMLNode::load_xml();
- Clean n_opt atributes anywhere;
- create method Owner() instead public atribute owner;
- change BD, Archive ... atributes of TKernel to BD(), Archive() ... function
- fix destructor ~TGRPModule and into childs;
