Тема без ответов
[TaskDone] Build OpenSCADA and firmware for "ICP DAS" PLC LP-5141
Сообщение создано: 05. 09. 2011 [09:32]
Base: Order and hardware from Petro Litkovets
Funding: available
Begin: 29.08.2011
Priority: high
State: Finished 12.09.2011
Project page: http://wiki.oscada.org/Using/LP5xxx
+ Obtained working and more new toolchain, which is compatible with the current firmware: http://voipac.com/downloads/pxa/toolchain/bin/arm-linux-gcc-3.4.1.tar.gz
+ Libraries current firmware is successfully replaced.
+ Basic configuration OpenSCADA is loaded and configured for remote control.
+ In the process of checking the calculator DAQ.JavaLikeCalc fixed a number of critical errors.
+ Fixed and improved storing into the configuration file.
+ DB.SQLite loaded and detected cooperation problem into single thread, the problem in GlibC 2.3.2. Made self realization for self-blocking check, and also self-blocking is excluded in DB.SQLite.
+ LibGD checked and work. Set FONTCONFIG_FILE=/etc/fonts/fonts.conf for fontconfig work.
+ Made repacking for ICP DAS official firmware with OpenSCADA build include.
+ Making a project document to build and create firmware for ICP_DAS LinPAC ARM.
+ Add module DAQ.ICP_DAS build with ARM static libraries.
+ OpenSCADA auto-start configure.
+ Other modules of OpenSCADA add to result firmware.
+ Modules check to work.
1782
