OPC UA client tag by processing
Сообщение создано: 10. 02. 2025 [12:58]
capvc
Martin Komin
Зарегистрирован(а) с: 10.02.2025
Hi,
I have a question how to do get value from OPC UA tag directly in widget processing javaScript, without define IO link, if possible this ?
thank you.
Сообщение создано: 10. 02. 2025 [22:32]
thank you.
All that you can do wrote in the documentation — http://oscada.org/wiki/Special:MyLanguage/Modules/OPC_UA
And OPC-UA operates by Nodes, not tags!
And you can easy define the Nodes in attributes for the Standard parameter type.
If you mean direct requesting OPC-UA, like to DAQ.ModBus messIO(string pdu), then the DAQ.OPC_UA module doesn't provide such function.
42567
