compile error for openscada-0.8.14
Сообщение создано: 19. 02. 2016 [23:49]
aminsalmani.science
amin salmani
Зарегистрирован(а) с: 18.02.2016
hi
i download original source code openscada-0.8.14 for Linux. i use both openscada-res-0.8.14.tar_3 and openscada-0.8.14.tar. i install it like installation manual. i have error in making step. the picture has been attached shown error in make .
i follow this steps
autoreconf -ivf
./configure
make-->error has been detected.
error in this picture is in sound.cpp
thank you
[Сообщение редактировалось 1 раз(а), в последний раз 19.02.2016 в 23:52.]
error in compile source code.jpg (Тип файла: image/jpeg, Размер: 511.71 килобайт) — 2955 загрузок
Сообщение создано: 20. 02. 2016 [08:58]
May be you will start to read?
Are you read the demands for compiling at all: http://wiki.oscada.org/HomePageEn/Function#h737-7
DAQ.SoundCard module
libportaudio Multiplatform library for access to sound controller version 19 and higher.
Сообщение создано: 20. 02. 2016 [09:26]
aminsalmani.science
amin salmani
yes i install all demand in this document. i install portaudio19(http://packages.ubuntu.com/precise/devel/portaudio19-dev) but it didn't work. if each of these demands didn't install , it would make an error in configure step.
the error that i have is in make step no configure step.
do you think this error because of liportaudio??
thank you
Сообщение создано: 23. 02. 2016 [16:23]
http://oscada.org/en/development/tasks/posts/core/the_automatic_openscada_builder/
ftp://ftp.oscada.org/OpenSCADA/0.8.0/Ubuntu/12.04/
11187
