Ошибки при сборке (ArchLinux x86-64)
Сообщение создано: 17. 11. 2010 [23:29]
angri
Антон Грицай
Зарегистрирован(а) с: 17.11.2010
Пытаюсь собрать версию из svn по этому PKGBUILD: http://aur.archlinux.org/packages.php?ID=32234
autoreconf -ivf дает следующий вывод:
autoreconf: Entering directory `.'
autoreconf: configure.in: not using Gettext
autoreconf: running: aclocal --force
/usr/share/aclocal/progsreiserfs.m4:13: warning: underquoted definition of AC_CHECK_LIBREISERFS
/usr/share/aclocal/progsreiserfs.m4:13: run info '(automake)Extending aclocal'
/usr/share/aclocal/progsreiserfs.m4:13: or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
autoreconf: configure.in: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
autoreconf: running: /usr/bin/autoconf --force
autoreconf: running: /usr/bin/autoheader --force
autoreconf: running: automake --add-missing --copy --force-missing
configure.in:360: required file `src/moduls/daq/BFN/Makefile.in' not found
autoreconf: automake failed with exit status: 1
Простой запуск ./configure обрывается на
configure: Pass global library using
checking for moc-qt4... no
checking for moc... moc
checking for rcc-qt4... no
checking for rcc... rcc
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src_call/Makefile
config.status: creating src/moduls/Makefile
config.status: creating src/moduls/arhiv/Makefile
config.status: creating src/moduls/bd/Makefile
config.status: creating src/moduls/protocol/Makefile
config.status: creating src/moduls/special/Makefile
config.status: creating src/moduls/daq/Makefile
config.status: creating src/moduls/transport/Makefile
config.status: creating src/moduls/ui/Makefile
config.status: creating src/moduls/bd/DBF/Makefile
config.status: creating src/moduls/bd/MySQL/Makefile
config.status: creating src/moduls/bd/SQLite/Makefile
config.status: creating src/moduls/bd/PostgreSQL/Makefile
config.status: creating src/moduls/daq/System/Makefile
config.status: creating src/moduls/daq/BlockCalc/Makefile
config.status: creating src/moduls/daq/JavaLikeCalc/Makefile
config.status: creating src/moduls/daq/LogicLev/Makefile
config.status: creating src/moduls/daq/SNMP/Makefile
config.status: creating src/moduls/daq/Siemens/Makefile
config.status: creating src/moduls/daq/ModBus/Makefile
config.status: creating src/moduls/daq/DCON/Makefile
config.status: creating src/moduls/daq/DAQGate/Makefile
config.status: creating src/moduls/daq/SoundCard/Makefile
config.status: creating src/moduls/daq/OPC_UA/Makefile
config.status: creating src/moduls/daq/AMRDevs/Makefile
config.status: error: cannot find input file: `src/moduls/daq/BFN/Makefile.in'
Что я упускаю из виду?
Сообщение создано: 18. 11. 2010 [08:42]
Последний срез возьмите.
Сообщение создано: 18. 11. 2010 [21:45]
angri
Антон Грицай
Спасибо, с последним собирается и работает.
13288
