Тема без ответов
[BugEnvironment] [Qt+NotMainThread] Crash in the common exit at opened of the text edit window of an text attribute of the development UI.Vision
Сообщение создано: 18. 03. 2018 [10:57]
OpenSCADA: Work 0.9-r2539, LTS 0.8.19
Linux: Debian 8 64
Resume: An environment bug of the Qt working in a not main thread.
... LTS: There is no way for workaround the problem.
... Work: It is solved by building OpenSCADA for Qt working into the main thread, by the build time option --enable-QtMainThrd; after the version 0.9-r2540 it is the default behavior which is triggered by the command-line starting up argument --QtInNotMainThread.
AGLKS_core_2018-03-18_10.55.crash.gz (Тип файла: application/gzip, Размер: 30.87 килобайт) — 1849 загрузок
7634
