Сообщение создано: 22. 01. 2015 [18:56]
fgdevel
fg fg
Зарегистрирован(а) с: 28.04.2014
Hello,
A few minutes ago, I tested to change some parameters on openscada (version 8.0.10) and it crashed.
Before I have set the system fot starting automatically the AGLKS operator interface (QT mode) on openscada_demo lauch.
When I change the calculate period parameter of the VCA module to 2000 ms (init value at 100ms), openscada crash at new startup.
You will find the crash report attached.
Hope this will help you
Сообщение создано: 22. 01. 2015 [19:37]
Sure not, use last LTS release 0.8.12 for the bugs reproduce.
Сообщение создано: 22. 01. 2015 [20:06]
The crash is by you have used into the script some like "y=x%0".
I will append checking for integer divide to zero try.
Сообщение создано: 22. 01. 2015 [22:23]
Fixed!
Сообщение создано: 23. 01. 2015 [11:28]
fgdevel
fg fg
Hi Roman,
I'm not sure to understand where was the problem because I didn't change any script from the DEMO, just some parameters.
Thanks for the fix. I will install Version 0.8.12 for testing.
Сообщение создано: 23. 01. 2015 [12:12]
Check an remember may be you really some changed! And be sure about your locale into UTF-8.
But I have not the problem for original DemoDB, also into English locale en_US.UTF-8.
You need get 0.8.12.1, build and next test that. About new releases policy here!
