Сообщение |
Сообщение создано: 19. 11. 2009 [23:09]
Rosnel
Rosnel M
Зарегистрирован(а) с: 19.11.2009
Hello, i'm Rosnel Martínez from Venezuela.
I'm trying to test the Modbus protocol, and when I connect a device and configure the "socket" for input and output module "trasports" failed to establish communication. I do this and then run a "Data Acquisition" module "modbus" using the TCP / IP using the "socket" previously configured.
The error says "Operation in progress" and not allow the connection or establñecer the test of "Data Acquisition".
Annex a picture of the error and socket configuration.
Can you help me?
Сообщение создано: 20. 11. 2009 [09:00]
Maximum count of port 65535.
100023 - ???
Сообщение создано: 20. 11. 2009 [14:31]
kuzulis
Денис Шиенков
Зарегистрирован(а) с: 10.07.2009
2 Rosnel,
see http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
set default port number is 502 (for Modbus TCP/UDP)
Сообщение создано: 20. 11. 2009 [14:44]
Rosnel
Rosnel M
100023 - ???
Thanks for the quick response.
you're right, I'm wrong in writing.
Testing with the 10,002 port which is open and the error still persists. Annex image error and the Data Acquisition module
And I'm sure that the device supports Modbus because the test is to make the comparison with LabView for Data Acquisition
Сообщение создано: 21. 01. 2011 [11:56]
jsantu
José Santurio
Зарегистрирован(а) с: 20.01.2011
Hi, I have the same problem, I need connect my ICP-CON ET-7067 with openSCADA through ethernet, but I couldn't. Do you have any solution for this mistake?
Thanks
Сообщение создано: 21. 01. 2011 [12:39]
Maxim
Maxim Lisenko
Hi. Your question is very poor, so it is impossible to understand your problem... Try to explain it more detailed and with screen shots may be.
Сообщение создано: 21. 01. 2011 [14:10]
jsantu
José Santurio
Thanks for you fast answer!
First, I need know about the ICP-CON ET-7067. This interface is supported for openSCADA?
I have openSCADA version 0.7.0
I'm working with linux fedora.
Сообщение создано: 21. 01. 2011 [14:31]
Maxim
Maxim Lisenko
In the documentation to this device the supports of ModBus is declared, so it can be connected to OpenSCADA. For more information read http://wiki.oscada.org/HomePageEn/Doc/QuickStart and http://wiki.oscada.org/HomePageEn/Doc/ModBus .
Сообщение создано: 31. 01. 2011 [17:09]
jsantu
José Santurio
I made the connection, thanks.
