Generate “delay time” at openscada
Сообщение создано: 10. 02. 2012 [03:10]
OPMOTOR
OP MOTORS
Зарегистрирован(а) с: 21.01.2011
Dear Friends, I have the follow question,
I´m using a Modbus device.
I read a bit register (read), and by the respective template, at the instant that the readed bit is ( true ),
I need activate ( read-write) a bit register to turn on a motor,
at the same time start "delays times" to activate other components that have a sequence of activation at time to turn on my process.
So my question is,
¿How I generate “delay time” at openscada using at the template the java script language.?
Do you have an example of code, or file example for reference.
Thanks a lot.
Сообщение создано: 10. 02. 2012 [11:23]
See to template "digitBlock" and like into DAQ templates library "Main templates" (base).
27887
