Clone controller from jlc
Сообщение создано: 11. 09. 2025 [18:04]
walhi
Sergey Karpesh
Зарегистрирован(а) с: 26.01.2016
Good day. It is possible to clone controllers and parameters using a script on javalikecalc. According to the documentation, I have sketched out a simple code for an example. Is it possible to do such a manipulation with a remote host? I can do this through qtcfg, but I did not understand how to access the elements of a remote workstation.
src = SYS.DAQ.ModBus.Test;
target = SYS.DAQ.ModBus;
targetName = "NewPLC";
req = SYS.XMLNode("copy");
req.setAttr("path", src.nodePath() + "/obj".replace("/", "%2f"));
req.setAttr("src", src.nodePath());
if (typeof(src) == "TCntrNode:TController"){
	pref = "cntr_";
} else {
	pref = "prm_";
req.setAttr("dst", target.nodePath() + pref + targetName);
SYS.cntrReq(req);
By the way, the project wiki is not working at the moment.
Сообщение создано: 12. 09. 2025 [08:16]
See to the argument "stat" of the SYS.cntrReq() function!
Just see to traffic from QTCfg to the remote host for understanding — http://oscada.org/wiki/Special:MyLanguage/Documents/Program_manual#TrDiagnostic
It is working but under a highly DDoS, so its can be restarted time from time in process of blocking hundred thousands of attacking hosts.
Сообщение создано: 12. 09. 2025 [19:27]
walhi
Sergey Karpesh
Thank you. It's amazing how I missed this parameter when I read the documentation.
I have another question about mass activation of archiving. Is it possible? I want to go through all the elements of the SYS.DAQ.ModBus.x.y tree with a script and set up archiving of a certain attribute. Or is the only way to do it the other way around and create an archiver and specify the data source in it?
Сообщение создано: 12. 09. 2025 [22:56]
Through the Control Interface you can do all that do in a configurator, so just send requests in the tab "Archivation" of need parameters.
And the tip about understanding in the previous post also actual here!
22341
