Сообщение |
Сообщение создано: 10. 01. 2017 [13:34]
wunker
Kamil Piecha
Зарегистрирован(а) с: 28.09.2016
Hello.
I have trivial problem with attrGet, but I simply cannot get this to work.
(Inside "for" loop):
IsEnabled[i] = this["Widget_" + i].attrGet("en");
Testing with:
messPut("arrayEn",1,IsEnabled);
As a result in system message, I only receive an array of bool filled with 0.
I assume my syntax is wrong?
Сообщение создано: 10. 01. 2017 [14:48]
Sure but that function isn't presented for widgets at all, see here!
Сообщение создано: 10. 01. 2017 [17:03]
wunker
Kamil Piecha
I see, I was using deprecated syntax. Right now everything is working flawlessly. Thank You.
Сообщение создано: 17. 01. 2017 [13:18]
wunker
Kamil Piecha
Hello,
I don't want to start a new thread, so I will continue in this one.
Right now I want to do something like this.
I have some code in DAQ:
Java-like based calculator (module) -> Controller -> Test (controller) -> Result (Parameters).
In Test (controller) I have some code, and I want to connect with (DAQ):
ModBUS -> Test -> List
in List I have attributes set as:
R:0:rw:reg0
R:1:rw:reg1
R:2:rw:reg2
R:3:rw:reg3
So, here is my syntax problem. I was reading :
http://wiki.oscada.org/HomePageEn/Doc/JavaLikeCalc
Point 1.1
"Attributes of the parameters of system OpenSCADA (starting from subsystem DAQ, as follows "{Type of DAQ module}.{Controller}.{Parameter}.{Attribute}")."
So, my syntax is (of course in Test (controller)):
parameter = SYS.DAQ.ModBUS.Test.List.("reg0");
This reads only 0 (instead of value of 321 which is passed by ModBUS protocol, and can be readed directly on the page that contains List.
This (according to point 1.1) doesn't work (it reads EVAL):
parameter = SYS.DAQ.ModBUS.Test.List.reg0;
Сообщение создано: 17. 01. 2017 [13:44]
RTFM again!
In last case you get the attribute's object but it isn't its value.
Again read here for attributes!
Сообщение создано: 17. 01. 2017 [16:35]
wunker
Kamil Piecha
Well, I was reading this F manual very acutely...
I was struggling with this whole day. It turned out, that if I'm connecting with ModBus protocol and I have syntax error, then
controller (Name:Test as mentioned in post above) in Java-like based calculator can hang. Therefore, there is no possibility to put new changes, because it will simply not compile (without symptoms). That was main reason for creating this post and my strange syntax attempts.
Solution - restart OpenSCADA.
(I am running most recent 0.9+r2460)
Anyway, Thank You for help, because You said, that I should get attribute's object (so EVAL that I was getting was wrong).
Сообщение создано: 17. 01. 2017 [17:52]
"wunker" wrote:
Point 1.1
That isn't related at all to the bottom samples!
This sample wrong at all!
And this into "parameter" will handle only the attribute "reg0" object, no value, if its accessible at all!
But you at last have an error into module id "ModBUS" but this module calls "ModBus"!
For "reg0" attribute's value get you need call to the object's function "get()", like that:
tvl = SYS.DAQ.ModBus.Test.List.reg0.get();
And sure for me that works always!
vl = SYS.DAQ.ModBus.testTCP.test.reg4.get(); //Dynamic call through this objects
vl = ModBus.testTCP.test.reg4; //Static call by direct link at the compile.
SYS.messInfo("TEST","vl="+vl);
2017-01-17T17:49:16 1[TEST] vl=10138
Then RTFM and See The Multiple Examples into DemoDB!
