How to Center WebPage
Сообщение создано: 23. 09. 2009 [17:16]
Unaie
Unai Ezta
Зарегистрирован(а) с: 30.06.2009
1. How can I center WebVision in Browser?Any change in VCA.js, where? (I suppose to resize is not possible)
2. I need to change default directory when you export a file from QTVision. Now it opens always in ~/.openscada. I tryed
cd /mydir
openscada --Config=/home/ni/.openscada/oscada.xml $@
but this fails, default dir is always the stablished in .xml:
<prm id="Workdir">~/.openscada</prm>
, and you cannot change it because oscada depend on it to load.
In my project Oscada runs in a read only flash partition and i want a default directory to save files in a persistent partition.
3. is it possible to change templates docRept in code? I want to make interval depending on Size and this fails:
docRept="XXXXX<?dp return varinteger;?>"
My solution is 3 extra templates defined in attributes and I change beetwen them.
4. Where can I change the color or disable loading text when screen in rootpage is changing?
5. Any info about new Styles feature?
[Сообщение редактировалось 1 раз(а), в последний раз 23.09.2009 в 17:59.]
Сообщение создано: 24. 09. 2009 [10:03]
It is not possible now. I don't know how it to make without absolute position broken but I will try make it.
For resize to full window size you can use standard browser's scale function. Firefox and Opera good support it by Ctr++
Changing default directory operationally is not supported. Simple create link to writable partition into default directory or use unionfs and like for bridging default directory to its writible clone. For example read here http://wiki.oscada.org/Using/PLC
docRept is statical attribute.
It is correct.
I don't understand what you mean.
http://wiki.oscada.org/Doc/VCAEngine?v=1b2n#h668-8
http://wiki.oscada.org/Doc/Vision?v=1934#h669-5
Сообщение создано: 28. 09. 2009 [10:43]
Unaie
Unai Ezta
This message when you change between Mnemos in DemoDB:
Load page 'ses_.............'
Сообщение создано: 30. 09. 2009 [10:39]
I have set collor for this massage to "BorderColor" of the Box-container.
22488
