[BugWrong] не собирается под debian 7 x64 модуль OPC_UA
Written on: 07. 04. 2014 [15:36]
kirill256
Кирилл Андрезен
registered since: 05.05.2011
не собирается под debian 7 x64 падает на сборке модуля OPC_UA
g++: error: /home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA/.libs/libOPC_UA.a: No such file or directory
libtool: link: g++ -fPIC -DPIC -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.7/crtbeginS.o .libs/daq_SoundCard_la-sound.o -lportaudio -L/usr/lib/gcc/x86_64-linux-gnu/4.7 -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/4.7/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crtn.o -O2 -Wl,-soname -Wl,daq_SoundCard.so -o .libs/daq_SoundCard.so
libtool: link: ( cd ".libs" && rm -f "daq_SoundCard.la" && ln -s "../daq_SoundCard.la" "daq_SoundCard.la" )
make[5]: Leaving directory `/home/user/open-scada/OpenSCADA/src/moduls/daq/SoundCard'
Making all in OPC_UA
make[5]: Entering directory `/home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA'
Making all in libOPC_UA
make[6]: Entering directory `/home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA/libOPC_UA'
/bin/bash ../../../../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../../../src -fpic -g -O2 -MT libOPC_UA_la-libOPC_UA.lo -MD -MP -MF .deps/libOPC_UA_la-libOPC_UA.Tpo -c -o libOPC_UA_la-libOPC_UA.lo `test -f 'libOPC_UA.cpp' || echo './'`libOPC_UA.cpp
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../../../../../src -fpic -g -O2 -MT libOPC_UA_la-libOPC_UA.lo -MD -MP -MF .deps/libOPC_UA_la-libOPC_UA.Tpo -c libOPC_UA.cpp -fPIC -DPIC -o .libs/libOPC_UA_la-libOPC_UA.o
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../../../../../src -fpic -g -O2 -MT libOPC_UA_la-libOPC_UA.lo -MD -MP -MF .deps/libOPC_UA_la-libOPC_UA.Tpo -c libOPC_UA.cpp -o libOPC_UA_la-libOPC_UA.o >/dev/null 2>&1
mv -f .deps/libOPC_UA_la-libOPC_UA.Tpo .deps/libOPC_UA_la-libOPC_UA.Plo
/bin/bash ../../../../../libtool --tag=CXX --mode=link g++ -fpic -g -O2 -o libOPC_UA.la libOPC_UA_la-libOPC_UA.lo -lssl -lcrypto
libtool: link: ar cru .libs/libOPC_UA.a .libs/libOPC_UA_la-libOPC_UA.o
libtool: link: ranlib .libs/libOPC_UA.a
libtool: link: ( cd ".libs" && rm -f "libOPC_UA.la" && ln -s "../libOPC_UA.la" "libOPC_UA.la" )
make[6]: Leaving directory `/home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA/libOPC_UA'
make[6]: Entering directory `/home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA'
/bin/bash ../../../../libtool --tag=CXX --tag=disable-static --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../../src -g -O2 -MT daq_OPC_UA_la-moduls.lo -MD -MP -MF .deps/daq_OPC_UA_la-moduls.Tpo -c -o daq_OPC_UA_la-moduls.lo `test -f 'moduls.cpp' || echo './'`moduls.cpp
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../../../../src -g -O2 -MT daq_OPC_UA_la-moduls.lo -MD -MP -MF .deps/daq_OPC_UA_la-moduls.Tpo -c moduls.cpp -fPIC -DPIC -o .libs/daq_OPC_UA_la-moduls.o
mv -f .deps/daq_OPC_UA_la-moduls.Tpo .deps/daq_OPC_UA_la-moduls.Plo
/bin/bash ../../../../libtool --tag=CXX --tag=disable-static --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../../src -g -O2 -MT daq_OPC_UA_la-mod_daq.lo -MD -MP -MF .deps/daq_OPC_UA_la-mod_daq.Tpo -c -o daq_OPC_UA_la-mod_daq.lo `test -f 'mod_daq.cpp' || echo './'`mod_daq.cpp
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../../../../src -g -O2 -MT daq_OPC_UA_la-mod_daq.lo -MD -MP -MF .deps/daq_OPC_UA_la-mod_daq.Tpo -c mod_daq.cpp -fPIC -DPIC -o .libs/daq_OPC_UA_la-mod_daq.o
mv -f .deps/daq_OPC_UA_la-mod_daq.Tpo .deps/daq_OPC_UA_la-mod_daq.Plo
/bin/bash ../../../../libtool --tag=CXX --tag=disable-static --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../../src -g -O2 -MT daq_OPC_UA_la-mod_prt.lo -MD -MP -MF .deps/daq_OPC_UA_la-mod_prt.Tpo -c -o daq_OPC_UA_la-mod_prt.lo `test -f 'mod_prt.cpp' || echo './'`mod_prt.cpp
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../../../../src -g -O2 -MT daq_OPC_UA_la-mod_prt.lo -MD -MP -MF .deps/daq_OPC_UA_la-mod_prt.Tpo -c mod_prt.cpp -fPIC -DPIC -o .libs/daq_OPC_UA_la-mod_prt.o
mv -f .deps/daq_OPC_UA_la-mod_prt.Tpo .deps/daq_OPC_UA_la-mod_prt.Plo
/bin/bash ../../../../libtool --tag=CXX --tag=disable-static --mode=link g++ -g -O2 -module -avoid-version -no-undefined -o daq_OPC_UA.la -rpath /usr/lib/openscada daq_OPC_UA_la-moduls.lo daq_OPC_UA_la-mod_daq.lo daq_OPC_UA_la-mod_prt.lo -lssl -lcrypto -LlibOPC_UA/ -lOPC_UA
libtool: link: g++ -fPIC -DPIC -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.7/crtbeginS.o .libs/daq_OPC_UA_la-moduls.o .libs/daq_OPC_UA_la-mod_daq.o .libs/daq_OPC_UA_la-mod_prt.o -Wl,--whole-archive /home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA/.libs/libOPC_UA.a -Wl,--no-whole-archive -LlibOPC_UA/ -lssl -lcrypto -L/usr/lib/gcc/x86_64-linux-gnu/4.7 -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/4.7/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crtn.o -O2 -Wl,-soname -Wl,daq_OPC_UA.so -o .libs/daq_OPC_UA.so
make[6]: *** [daq_OPC_UA.la] Ошибка 1
make[6]: Leaving directory `/home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA'
make[5]: *** [all-recursive] Ошибка 1
make[5]: Leaving directory `/home/user/open-scada/OpenSCADA/src/moduls/daq/OPC_UA'
make[4]: *** [all-recursive] Ошибка 1
make[4]: Leaving directory `/home/user/open-scada/OpenSCADA/src/moduls/daq'
make[3]: *** [all-recursive] Ошибка 1
make[3]: Leaving directory `/home/user/open-scada/OpenSCADA/src/moduls'
make[2]: *** [all-recursive] Ошибка 1
make[2]: Leaving directory `/home/user/open-scada/OpenSCADA/src'
make[1]: *** [all] Ошибка 2
make[1]: Leaving directory `/home/user/open-scada/OpenSCADA/src'
make: *** [all-recursive] Ошибка 1
user@disp2:~/open-scada/OpenSCADA$
Written on: 07. 04. 2014 [16:13]
Соберётся, после "autoreconf -if"!
34559
