Written on: 25. 03. 2013 [16:41]
citrizin
Abolfazl
registered since: 04.10.2012
Great
I think I'm just understanding....
Therefore I'm not looking for a PROFIBUS message. I want to play the role of CP243.
I just want to receive oscada message and that's it. No matter this message is not PROFIBUS based. whatever it is, I want to receive it in my micro controller.
Seemingly this message is transferred in "ISO TCP" format (which is not a closed one). Can I receive this message using just a LAN cable?
At the end of this LAN cable is my micro controller which is able to receive bytes in TCP format.
Written on: 25. 03. 2013 [18:10]
registered since: 25.09.2008
"citrizin" wrote: Seemingly this message is transferred in "ISO TCP" format (which is not a closed one).
This is another protocol. I do not know the protocol is open or not, is not known with which TCP port Ethernet it works. Perhaps Roman will tell precisely.
"roman" wrote: "iso tcp" is specific application level protocol, mostly closed, by Siemens GMBH.
"citrizin" wrote: Can I receive this message using just a LAN cable?
If the message is to get (know which port is TCP request), but what to answer for completion exchange?
"citrizin" wrote: I want to play the role of CP243.
This is a server role. You need to write server protocol "ISO TCP". OpenSCADA uses the "ISO TCP" only as a client. The connection between two computers via OpenSCADA "ISO TCP" impossible. Client-client does not allow the correct exchange.
[This article was edited 1 times, at last 25.03.2013 at 18:12.]
Written on: 07. 04. 2013 [12:03]
citrizin
Abolfazl
Thanks for your answer,
Do you know on which port openSCADA sends its request?
I have written a TCP server now and I'm trying to receive openSCADA messages which are sent through ISO_TCP. but I don't on which port should my server listen.
Written on: 08. 04. 2013 [07:03]
Maybe port 102.
http://www.delta.com.tw/product/em/control/touch_hmi/download/manual/Siemens%20S7%20300%20_ISO%20TCP__ENG.pdf
http://www.faqs.org/rfcs/rfc1006.html
http://www.faqs.org/rfcs/rfc983.html
http://cache.automation.siemens.com/dnl/zUwNTEyMQAA_21555710_HB/MN_s7-cps-ie_76.pdf
[This article was edited 2 times, at last 08.04.2013 at 07:32.]
Written on: 08. 04. 2013 [10:36]
The port is 102 but you can simple the port detect from any network sniffing program, like "wireshark".
