Written on: 25. 09. 2013 [12:50]
ajinkya
Ajinkya Biradar
registered since: 17.12.2012
Hello Sir,
I mean the other button, not the one to select floor plan i.e. button names 1 or 2 or 3).
Each floor plan will have buttons for each lab, which will open the inner view of lab in pgCont area.
Also, For more clear explanation I have attached one image for desired final front end design, kindly have a look.
and is it possible?
Thank you for quick response.
Written on: 25. 09. 2013 [13:04]
and is it possible?
Sure, just take from the "Root Page(so)" "evProc" attribute's line for mnemo pages open by the button events and place it to this "floor plan" page attribute "evProc" and change here this button ID and related for open page address.
Written on: 26. 09. 2013 [07:14]
ajinkya
Ajinkya Biradar
Thank you sir,
This is also working now.
One more question, in documentation it is mentioned that
-->> The signal object's subbranches "Group {n}" have number identifier and can expanded by appending up to 16.
This is the actual limit or by modifying the program in process tab of "Root page (so)" we can add more??
Thank you very much for supporting. :-)
Written on: 26. 09. 2013 [09:21]
Sure, you can. The limit mostly for two rows of eight signal object's buttons concept.
Written on: 27. 09. 2013 [14:57]
ajinkya
Ajinkya Biradar
Thank you sir,
with your help and some reading I am done with my front end now,
One issue I wanted to raise here is when we set background for wdg_box
1. if the background image is smaller than widget size it automatically "tiles" (repeats same image on both right and bottom side) the image.
2. if the background image is bigger the we can understand that it provides scrolling mechanism.
so is there any option like "media -> image" has ---- "fit to widget size".
As I have so many "lab inner floor plans" and manually resizing them and then trials in openscada is quite time consuming,
also each lab is of different size so it is a problem in itself.
Written on: 28. 09. 2013 [08:54]
No, the background image just for textures set. So, for your task use "Media".
