EnglishРусскийУкраїнська
project help
Written on: 19. 08. 2009 [17:20]
villalta0218
Miguel Ortiz
registered since: 19.08.2009
Hello
I need help with one project
I was able to configure your program to manual request the state of a coil, and receive the right answer from the PLC, but I need more for this project.icon_rolleyes.gif
To start:
It is possible connect to three different PLC with Modbus TCP/IP protocol; to continue read from specific registers or coil, and record the state changes on a table with a day and time went this changes occurs; If your answer it is yes. Can you explain to me how?icon_wink.gif
Best Regards,
Written on: 19. 08. 2009 [23:33]
Попков Алексей
registered since: 31.07.2008
http://wiki.oscada.org/HomePageEn/Doc/ModBus?v=12s1
Written on: 20. 08. 2009 [09:29]
Yes of course. And write to table it is simple and standard value archive: http://wiki.oscada.org/HomePageEn/Doc/FSArch or http://wiki.oscada.org/HomePageEn/Doc/DBArch .
Written on: 20. 08. 2009 [20:06]
villalta0218
Miguel Ortiz
Thank you, for your immediate reply.
Written on: 17. 09. 2009 [17:15]
villalta0218
Miguel Ortiz
System=CENTOS 5.3
Linux-2.6.18-128.7.1.el5
On the data acquisition module:
if I do changes on the web interface the period of the task on data acquisition modulo (modbus sub modulo) to be 1800s, this parameter is record to be only 100s on the table and it is display like 100s on the web interface; if I change this parameter directly to the table, the table take the changes but the web interface only display 100s and also the acquisition occur every 100s
is 100 sec the maximum?
can I modified the period of the task data acquisition to be longer of 100 sec?
how I can change this parameter to be longer of 100 sec?
Written on: 17. 09. 2009 [19:11]
It is correct limit to maximum period.
I has add call planing by cron-schedule today, for this module. Use it for long period planing.
0932
