PROFIBUS and ISO TCP
First | 1 | 2 |
Written on: 25. 03. 2013 [16:41]
citrizin
Abolfazl
registered since: 04.10.2012
Great
I think I'm just understanding....
Therefore I'm not looking for a PROFIBUS message. I want to play the role of CP243.
I just want to receive oscada message and that's it. No matter this message is not PROFIBUS based. whatever it is, I want to receive it in my micro controller.
Seemingly this message is transferred in "ISO TCP" format (which is not a closed one). Can I receive this message using just a LAN cable?
At the end of this LAN cable is my micro controller which is able to receive bytes in TCP format.
Written on: 25. 03. 2013 [18:10]
registered since: 25.09.2008
This is another protocol. I do not know the protocol is open or not, is not known with which TCP port Ethernet it works. Perhaps Roman will tell precisely.
"iso tcp" is specific application level protocol, mostly closed, by Siemens GMBH.
If the message is to get (know which port is TCP request), but what to answer for completion exchange?
This is a server role. You need to write server protocol "ISO TCP". OpenSCADA uses the "ISO TCP" only as a client. The connection between two computers via OpenSCADA "ISO TCP" impossible. Client-client does not allow the correct exchange.
[This article was edited 1 times, at last 25.03.2013 at 18:12.]
Written on: 07. 04. 2013 [12:03]
citrizin
Abolfazl
Thanks for your answer,
Do you know on which port openSCADA sends its request?
I have written a TCP server now and I'm trying to receive openSCADA messages which are sent through ISO_TCP. but I don't on which port should my server listen.
Written on: 08. 04. 2013 [07:03]
Maybe port 102.
http://www.delta.com.tw/product/em/control/touch_hmi/download/manual/Siemens%20S7%20300%20_ISO%20TCP__ENG.pdf
http://www.faqs.org/rfcs/rfc1006.html
http://www.faqs.org/rfcs/rfc983.html
http://cache.automation.siemens.com/dnl/zUwNTEyMQAA_21555710_HB/MN_s7-cps-ie_76.pdf
[This article was edited 2 times, at last 08.04.2013 at 07:32.]
Written on: 08. 04. 2013 [10:36]
The port is 102 but you can simple the port detect from any network sniffing program, like "wireshark".
First | 1 | 2 |
16118
