OPC UA
Written on: 22. 01. 2014 [03:55]
rxs5
Дмитрий Лыков
In tech support
registered since: 06.11.2013
Отдельная проблема на совершенно другом сервере (физически и другая nix ОС).
На нем работает OpenSCADA OPCUA сервер, который опрашивается клиентом UAExpert.
По логам UAExpert
05:41:00.735 | Server Node | opc.tcp//ip:port/ | Could not connect to server: BadCommunicationError
05:40:49.260 | TypeCache | opc.tcp//ip:port/ | Translate failed with error BadConnectionClosed
05:40:49.260 | TypeCache | opc.tcp//ip:port/ | Read failed with error BadConnectionClosed
05:40:49.259 | TypeCache | opc.tcp//ip:port/ | Read failed with error BadConnectionClosed
05:40:49.225 | Server Node | opc.tcp//ip:port/ | Disconnect succeeded.
05:40:49.223 | Server Node | opc.tcp//ip:port/ | Connection status of server 'opc.tcp//ip:port/' changed to 'Disconnected'.
05:40:48.747 | AddressSpaceModel | opc.tcp//ip:port/ | Unregister for ModelChangeEvents returned Good
04:58:34.706 | Server Node | opc.tcp//ip:port/ | Connection status of server 'opc.tcp//ip:port/' changed to 'ConnectionErrorApiReconnect'.
04:58:19.700 | Server Node | opc.tcp//ip:port/ | Connection status of server 'opc.tcp//ip:port/' changed to 'ConnectionWarningWatchdogTimeout'.
20:58:25.064 | DA Plugin | opc.tcp//ip:port/ | Item [NS1|String|DAQ.SBK.aaa.C4_1_1_2_24_.Data]: RevisedSamplingInterval=500, RevisedQueueSize=1, MonitoredItemId=1 [ret = Good]
20:58:25.064 | DA Plugin | opc.tcp//ip:port/ | CreateMonitoredItems succeeded [ret = Good]
20:58:25.044 | DA Plugin | opc.tcp//ip:port/ | Item [NS1|String|DAQ.SBK.aaa.C4_1_1_2_24_.Data]: SamplingInterval=-1, QueueSize=1, DiscardOldest=1, ClientHandle=24
20:58:25.044 | DA Plugin | opc.tcp//ip:port/ | Found existing subscription for ServerId 4
20:58:25.043 | DA Plugin | | QascDaModel::dropMimeData
20:58:24.548 | AddressSpaceModel | opc.tcp//ip:port/ | QascAddressSpaceModel::mimeData
20:58:23.812 | TypeCache | opc.tcp//ip:port/ | ValueRank = -1
20:58:23.811 | TypeCache | opc.tcp//ip:port/ | DataTypeId = NS0|Numeric|11
20:58:23.811 | TypeCache | opc.tcp//ip:port/ | Description = Сhannel data
20:58:23.810 | TypeCache | opc.tcp//ip:port/ | DisplayName = Data
20:58:23.810 | TypeCache | opc.tcp//ip:port/ | BrowseName = 0:Data
Разумеется, что вместо ip:port были реальные ip и port через которые UEXpert обменивался данными с OPC UA сервером в OpenSCADA. Однако в 04-58 Connection status изменился в ConnectionWarningWatchdogTimeout и затем в ConnectionErrorApiReconnect.
Сделал Disconnect в UAExpert и снова попробовал подключиться, но не удалось с ошибкой BadCommunicationError.
Пока информации по состоянию OPC UA в OpenSCADA на том сервере нет. Появится она днем 22.01.2014. Добавлю сюда логи консоли, скриншоты транспорта из сокета и логи из дебага OpenSCADA.
[This article was edited 3 times, at last 22.01.2014 at 03:59.]
Written on: 22. 01. 2014 [04:51]
rxs5
Дмитрий Лыков
In tech support
Поле протокола не влияет прямо на свойства транспорта, почему и доступно для смены в режиме исполнения.
Т.е. его смена имеет эффект на новых подключениях, кстати тут есть вопрос, почему те два оборвали рабочее соединение.
Сделал простой тест.
Подключил UAexpert и OpenSCADA OPC UA controller к серверу OPC UA в OpenSCADA. Затем в запущенном транспорте поиграл скролом - изменил тип протокола с OPC UA на пустое поле.
В результате UAExpert отключился, с ошибкой по логу в UAEXpert
06:05:37.350 | Server Node | OpenScadaOpcServer@server... | Connection status of server 'OpenScadaOpcServer@server- None - None' changed to 'Connected'.
06:05:37.349 | AddressSpaceModel | OpenScadaOpcServer@server... | Register for ModelChangeEvents failed: createMonitoredItems returned BadFilterNotAllowed for item 0
06:05:37.290 | DA Plugin | OpenScadaOpcServer@server... | Calling Republish with sequence number 41
06:05:11.622 | Server Node | OpenScadaOpcServer@server... | Connection status of server 'OpenScadaOpcServer@server- None - None' changed to 'ConnectionErrorApiReconnect'.
06:04:51.577 | AddressSpaceModel | OpenScadaOpcServer@server... | Browse succeeded.
06:04:51.554 | AddressSpaceModel | OpenScadaOpcServer@server... | Browse succeeded.
Затем по возвращению в combobox транспорта значения OPC UA клиент UAExpert удачно подключился обратно.
Однако с пустым полем все равно было 1 открытое соединение. Отключил OpenSCADA OPC UA controller, но все равно осталось 1 открытое соединение.
И по логам консоли идет обмен с устройством, ip которого соответствует компьютеру, где запущен клиент UAExpert, который отвалился вроде как. Проверяю в wireshark - действительно есть активность, именно те самые пакеты, что я выкладывал в сообщениях ранее, когда не знал, откуда идет сетевая активность по OPC UA в снифере при отключенных клиентах.
В консоли идет постоянный коннект и дисконнект от UAExpert и разумеется в транспорте OPC UA растет количество соединений.
Лог консоли
4|/sub_Transport/mod_Sockets/in_OPCUA_4848/ | Error request to protocol.
0|/sub_Transport/mod_Sockets/in_OPCUA_4848/ | Socket has been disconnected by '192.168.aaa.aaa'!
0|/sub_Transport/mod_Sockets/in_OPCUA_4848/ | Socket has been connected by '192.168.aaa.aaa'!
0|/sub_Transport/mod_Sockets/in_OPCUA_4848/ | Socket received message '61' from '192.168.aaa.aaa'.
4|/sub_Transport/mod_Sockets/in_OPCUA_4848/ | The protocol '' is not present.
После выполнения disconnect в UAExpert обмен в консоли прекратился, в wireshark новых пакетов также нет. Однако в транспорте осталось 1 открытое соединение.
Также приложил логи wireshark на момент смены протокола OPC UA в сокете на пустое поле.
В итоге
- я предполагал по цитате выше, что смена транспорта в запущенном протоколе не повлияет на уже работающие подключения, но видимо это не так
- UAExpert продолжает обмениваться с сервером OPC UA в OpenSCADA пакетами и пытаться подключиться
- зависает (?) соединение созданное UAExpert с OPC UA в OpenSCADA
Кстати, операция отключения по логам UAExpert тоже не полностью успешно выполняется.
06:47:00.002 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:47:00.002 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:47:00.001 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:47:00.001 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:47:00.000 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:47:00.000 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:46:59.999 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:46:59.999 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:46:59.998 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:46:59.998 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:46:59.997 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:46:59.997 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:46:59.996 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:46:59.996 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:46:59.995 | TypeCache | OpenScadaOpcServer@server... | Translate failed with error BadConnectionClosed
06:46:59.995 | TypeCache | OpenScadaOpcServer@server... | Read failed with error BadConnectionClosed
06:46:59.959 | Server Node | OpenScadaOpcServer@server... | Disconnect succeeded.
06:46:59.957 | Server Node | OpenScadaOpcServer@server... | Connection status of server 'OpenScadaOpcServer@server- None - None' changed to 'Disconnected'.
06:46:58.940 | AddressSpaceModel | OpenScadaOpcServer@server... | Unregister for ModelChangeEvents returned Good
06:45:42.194 | AddressSpaceModel | OpenScadaOpcServer@server... | Browse succeeded.
06:45:42.112 | AddressSpaceModel | OpenScadaOpcServer@server... | Browse succeeded.
IWS не проверял в этот раз.
Собственно менять политику доступа к этому полю по причине возможности случайной его смены это как-то слишком и станет прецедентом для многих других комбобоксов, однако из соображения этой самой неоднозначности, когда открытые подключения ходят через старый протокол, а новые через новый наверное имеет смысл запретить его смену.
Если понять, что происходит при смене протокола транспорта, то потом можно решить, в каком виде его оставлять.
[This article was edited 2 times, at last 22.01.2014 at 04:55.]
opcua_transport_clear.pcapng (File type: application/octet-stream, Size: 10.12 kilobytes) — 897 downloads
Written on: 22. 01. 2014 [12:32]
По логам UAExpert
OpenSCADA как сервер значит не настроена корректно.
Как оказалось поле "Протокол" используется при любом запросе, почему и отключается, как и у меня в случае с любым клиентом.
Это поведение исправил, что несколько должно уменьшить время отклика.
И поле конфигурации "Протокол" таки отключил в режиме "Исполнение".
Клиент OpenSCADA не отключает исходящий транспорт, да и запроса закрытия канала безопасности не шлёт, поскольку браузинг должен работать. И если транспорт закрыть руками то будет 0.
Written on: 28. 01. 2014 [15:20]
rxs5
Дмитрий Лыков
In tech support
Уже 4 дня не было ошибок и сбоев, думал все хорошо. Однако...cегодня появилась ошибка без внешних вмешательств (насколько помню). Посмотрите, пожалуйста, чем эти сообщения могут быть вызваны.
Исходное: 2 клиента UAExpert (с различных PC) опрашивают OPC UA сервер OpenSCADA.
На клиентах лог следующий
17:01:39.206 | Devices Plugin     | OpenScadaOpcServer@centos97... | Read NamespaceArray failed with status code BadConnectionClosed
17:01:39.188 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'Connected'.
17:01:39.188 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Read namespace array failed (BadConnectionClosed)
17:01:39.188 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Register for ModelChangeEvents failed: createSubscription returned BadTooManySubscriptions
17:01:39.162 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 459667
17:01:39.100 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionErrorApiReconnect'.
17:01:34.106 | Devices Plugin     | OpenScadaOpcServer@centos97... | Read NamespaceArray failed with status code BadConnectionClosed
17:01:34.085 | DA Plugin          | OpenScadaOpcServer@centos97... | Call Republish failed (ret = BadConnectionClosed)
17:01:34.085 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'Connected'.
17:01:34.085 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 459665
17:01:34.085 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Read namespace array failed (BadConnectionClosed)
17:01:34.085 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 459664
17:01:34.085 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Register for ModelChangeEvents failed: createSubscription returned BadTooManySubscriptions
17:01:34.085 | DA Plugin          | OpenScadaOpcServer@centos97... | Call Republish failed (ret = BadTooManySubscriptions)
17:01:34.085 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 459663
17:01:34.081 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 459662
17:01:34.045 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionErrorApiReconnect'.
17:01:29.048 | Devices Plugin     | OpenScadaOpcServer@centos97... | Read NamespaceArray failed with status code BadConnectionClosed
17:01:29.041 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'Connected'.
17:01:29.041 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Read namespace array failed (BadConnectionClosed)
17:01:29.041 | DA Plugin          | OpenScadaOpcServer@centos97... | Call Republish failed (ret = BadInvalidState)
17:01:29.041 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 459660
17:01:29.041 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Register for ModelChangeEvents failed: createSubscription returned BadTooManySubscriptions
17:01:29.041 | DA Plugin          | OpenScadaOpcServer@centos97... | Call Republish failed (ret = BadTooManySubscriptions)
На OpenSCADA
в консоли
0|/sub_Protocol/mod_OPC_UA/ | MSG Req
0|/sub_Protocol/mod_OPC_UA/ | MSG Resp
4|/sub_Protocol/mod_OPC_UA/ | Element 'OPCUA_484831' is not present or disabled!
0|/sub_Transport/mod_Sockets/in_OPCUA_4848/ | Socket received message '91' from '192.168.195.97'.
0|/sub_Transport/mod_Sockets/in_OPCUA_4848/ | Socket write message '66'.
Непонятно, кто держит 1 соединение (возможно свой собственный контроллер), и почему клиенты не могу подключиться. И еще неясно, почему раньше оборвалось соединение с клиентами.
Во вложении
- wireshark дамп
- скриншот настроек транспорта OPC UA
Продолжение.
Отключил 1 клиент UAExpert и спустя некоторое время 2-й клиент UAExpert подключился к OPC UA, перестали идти ошибки в UAExpert и в консоли OpenSCADA, и работа связки OPC UA восстановилась.
[This article was edited 2 times, at last 28.01.2014 at 15:27.]
opcua_not_present_or_disabled.pcapng (File type: application/octet-stream, Size: 21.8 kilobytes) — 916 downloads
Written on: 28. 01. 2014 [21:04]
Это UAExpert DOSит, создавая левые подписки на некорректный параметр. Ранее думал он их не повторяет, точнее замечал только при пересоздании канала ранее. А похоже он повторяет попытку создать подписку не удаляя старых. В дампе как раз этих пустышек по индексу уже десяток, в то время как рабочая подписка одна и работает корректно. По скорости пересоздания получается раз в 10 часов пересоздаёт, надо будет записать обмен, на предмет что приводит к пересозданию или он действительно сам так DOSит.
Добавлю отладочное сообщение по созданию подписок и их удалению.
Я Вам говорил ранее, что это сам исходящий транспорт контроллера клиента OPC UA OpenSCADA его удерживает, поскольку не закрывает для задач браузинга.
Ну так, подписи по закрытию сеанса закрываются. А сами подписи это общий массив для сервера где лимит и стоит.
Собственно лимит на подписи у сервера сейчас 10, в перспективе этот параметр хотел вынести в настройки.
Да и лимит к сеансу не мешало-бы привязать, что-бы один всех остальных не DOSил.
Written on: 29. 01. 2014 [16:41]
Сделал и отладку добавил.
Written on: 31. 01. 2014 [18:29]
rxs5
Дмитрий Лыков
In tech support
Сегодня проверял работу со сборкой 2045. Было подключено 2 клиента OPC UA. Спустя некоторое время все 10 зарезервированных соединений были открыты. И клиенту UAExpert стал недоступен сервер OPC UA.
Лог в UAExpert
16:27:45.878 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionErrorApiReconnect'.
16:27:29.878 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionWarningWatchdogTimeout'.
16:27:29.878 | Devices Plugin     | OpenScadaOpcServer@centos97... | Read NamespaceArray failed with status code BadTimeout
16:27:19.880 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'Connected'.
16:27:19.880 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Read namespace array failed (BadTimeout)
16:27:09.238 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Register for ModelChangeEvents failed: createSubscription returned BadTooManySubscriptions
16:27:03.877 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionWarningWatchdogTimeout'.
16:19:05.979 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'Connected'.
16:19:05.972 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Register for ModelChangeEvents failed: createMonitoredItems returned BadFilterNotAllowed for item 0
16:19:00.882 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionWarningWatchdogTimeout'.
16:16:36.014 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'Connected'.
16:16:36.012 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Register for ModelChangeEvents failed: createMonitoredItems returned BadFilterNotAllowed for item 0
16:16:30.878 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionWarningWatchdogTimeout'.
16:16:14.933 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'Connected'.
16:16:14.931 | AddressSpaceModel  | OpenScadaOpcServer@centos97... | Register for ModelChangeEvents failed: createMonitoredItems returned BadFilterNotAllowed for item 0
16:15:59.861 | Server Node        | OpenScadaOpcServer@centos97... | Connection status of server 'OpenScadaOpcServer@centos97.server - None - None' changed to 'ConnectionWarningWatchdogTimeout'.
16:14:08.769 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 1539
16:14:08.767 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 1538
16:14:08.763 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 1537
16:14:08.762 | DA Plugin          | OpenScadaOpcServer@centos97... | Calling Republish with sequence number 1536
Скриншот OpenSCADA во вложении
И хотя UAExpert отключен, все равно есть активность в wireshark. Дамп во вложении.
openscada_limit_connections_20140131.pcapng (File type: application/octet-stream, Size: 4.18 kilobytes) — 881 downloads
Written on: 31. 01. 2014 [19:02]
Скриншот мне ни о чем не говорит, поэтому не выкладывайте!
Лог UAExpert уже когда забито подключений тоже бесполезен.
Нужно ловить момент, когда это начинается иначе я ничем помочь не могу!
Что значит отключен, вообще закрыт?
Кто такой тогда 192.168.195.192, что долбёт HELLO сообщениями ?
Written on: 31. 01. 2014 [19:13]
rxs5
Дмитрий Лыков
In tech support
Вообще-то в логе указал момент перехода от нормальной работы UAExpert к ошибке.
Как можете предложить ловить момент когда начинается ошибка ?
Отключен это так, как на скриншоте, когда UAExpert не может подключиться из-за ошибки.
Это компьютер, на котором запущен тот самый UAExpert, который должен быть уже отключен.
[This article was edited 1 times, at last 31.01.2014 at 19:16.]
Written on: 31. 01. 2014 [19:21]
Да ну. "Calling Republish with sequence number 1536" уже говорит о том, что там проблемы.
"Keep alive время ожидания" в транспорте можно таки поставить скажем в 10 секунд, т.е. пока активность будет сокет не закроется, а если активность прекратится то он закроется через 10 секунд.
И можно поставить прямо сейчас если ничего не закрыто.
А ловить, записью дампа WireShark всё время.
Ну так к чему комментарий о том, что трафик есть и 10 подключений?
Закройте их всех и сколько станет?
48468
