| Author |
Written on: 14. 04. 2023 [10:48]
alnet
Александр П.
registered since: 09.10.2019
If I have two different database (SQLite and PostgreSQL), openSCADA can't load Data Acquisition's config properly if all databases "To enable".
[This article was edited 1 times, at last 14.04.2023 at 10:49.]
Written on: 14. 04. 2023 [12:06]
I can, and that works in loading from MySQL and SQLite.
Not a bug!
Written on: 14. 04. 2023 [12:38]
alnet
Александр П.
Not a bug!
Templates library loads - OK. I can't load Siemens DAQ and Beckhoff
Written on: 14. 04. 2023 [12:48]
It is in the "Work DB", which is specific one and always downloaded in the first!
Not a bug!!!
Written on: 14. 04. 2023 [13:38]
alnet
Александр П.
Not a bug!!!
Please see demo video
bug demo
Written on: 14. 04. 2023 [14:32]
And what? I have no problem with that and 0.9.5 is not actual more after 0.9.6 releasing!
Written on: 14. 04. 2023 [14:43]
alnet
Александр П.
The new version has exactly the same problem.
But... OK
I just wanted to help.
Written on: 14. 04. 2023 [14:48]
But... OK
Do you think I want your help about missing problems? :)
Written on: 14. 04. 2023 [14:58]
alnet
Александр П.
Previous (0.9.4, 0.9.3...) versions work perfectly. This problem is only with new versions 0.9.5, 0.9.6. I tried the AGLKS configuration and got the same problems.
Thanks for your work.
Written on: 15. 04. 2023 [12:09]
So, that was a problem in DB.PostgreSQL which reproduced only at loading this DBs type from the program start and at new Tables creation.
- !!:FIX:DB: Processing the table emptiness some softened during problems in DB.PostgreSQL about that, that is no exception generated now.
- !!:FIX:DB.PostgreSQL: Switched to the standard way of detection the missing Tables with it creation at "toCreate" and the exceptions generating else, so preventing the message "Table is empty.".
