Проблема с установкой
Written on: 19. 05. 2010 [09:21]
andrelek
Андрей Полевой
registered since: 13.12.2008
Устанавливаю OpenScada из исходников, на Fedora11 и получаю такую ошибку:
Making all in Vision
make[5]: Entering directory `/home/user/OScadaSys/OpenSCADA/src/moduls/ui/Vision'
/bin/sh ../../../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../.. -I../../../../src -I/usr/include -I/usr/include/QtCore -I/usr/include/QtGui -MF
.deps/moc_vis_widgs.Tpo -c moc_vis_widgs.cpp -fPIC -DPIC -o .libs/moc_vis_widgs.o
moc_vis_widgs.cpp:14:2: error: #error "This file was generated using the moc from 4.5.1. It"
moc_vis_widgs.cpp:15:2: error: #error "cannot be used with the include files from this version of Qt."
moc_vis_widgs.cpp:16:2: error: #error "(The moc has changed too much.)"
make[5]: *** [moc_vis_widgs.lo] Ошибка 1
Вот файл yum.log
[root@WaterPrepare log]# cat yum.log
May 18 15:07:12 Installed: 1:mc-4.7.1-2.fc11.x86_64
May 18 15:58:49 Updated: mysql-libs-5.1.46-1.fc11.x86_64
May 18 15:58:51 Installed: mysql-5.1.46-1.fc11.x86_64
May 18 16:00:38 Installed: lm_sensors-devel-3.1.0-1.fc11.x86_64
May 18 16:05:12 Updated: 1:net-snmp-libs-5.4.2.1-13.fc11.x86_64
May 18 16:05:14 Updated: 1:net-snmp-5.4.2.1-13.fc11.x86_64
May 18 16:10:22 Updated: elfutils-libelf-0.145-1.fc11.x86_64
May 18 16:10:23 Installed: xz-libs-4.999.9-0.1.beta.20091007git.fc11.x86_64
May 18 16:10:24 Updated: elfutils-libs-0.145-1.fc11.x86_64
May 18 16:10:25 Updated: elfutils-libelf-devel-0.145-1.fc11.x86_64
May 18 16:10:25 Installed: elfutils-devel-0.145-1.fc11.x86_64
May 18 16:10:26 Installed: tcp_wrappers-devel-7.6-55.fc11.x86_64
May 18 16:10:27 Updated: elfutils-0.145-1.fc11.x86_64
May 18 16:10:31 Installed: 1:net-snmp-devel-5.4.2.1-13.fc11.x86_64
May 18 16:13:14 Installed: libfreebob-1.0.11-5.fc11.x86_64
May 18 16:13:15 Installed: jack-audio-connection-kit-0.118.0-1.fc11.x86_64
May 18 16:13:16 Installed: portaudio-19-8.fc11.x86_64
May 18 16:14:53 Installed: portaudio-devel-19-8.fc11.x86_64
May 18 16:17:50 Installed: fftw-3.2.1-2.fc11.x86_64
May 18 16:17:52 Installed: fftw-devel-3.2.1-2.fc11.x86_64
May 18 16:51:57 Updated: 1:qt-4.6.2-18.fc11.x86_64
May 18 16:51:57 Installed: 1:qt-sqlite-4.6.2-18.fc11.x86_64
May 18 16:52:01 Updated: 1:qt-x11-4.6.2-18.fc11.x86_64
May 18 16:52:17 Installed: 1:qt-devel-4.6.2-18.fc11.x86_64
May 18 17:02:08 Installed: mysql-devel-5.1.46-1.fc11.x86_64
May 18 17:18:33 Installed: sip-4.10.2-1.fc11.x86_64
May 18 17:18:35 Installed: PyQt4-4.7.3-1.fc11.x86_64
May 18 19:02:24 Installed: sip-devel-4.10.2-1.fc11.x86_64
May 18 19:02:35 Installed: PyQt4-devel-4.7.3-1.fc11.x86_64
May 19 07:55:59 Installed: fftw2-2.1.5-18.fc11.x86_64
May 19 07:57:18 Installed: fftw2-devel-2.1.5-18.fc11.x86_64
May 19 08:31:32 Installed: Io-language-20071010-10.fc11.x86_64
May 19 08:31:38 Installed: Io-language-graphics-and-sound-20071010-10.fc11.x86_64
Честно признаться опыт работы в линуксе не большой, подскажите пожалуйста какого пакета не хватает?
Written on: 19. 05. 2010 [10:32]
В смысле с чего собираете, с тарбола или SRPMS, и откуда он взят?
Written on: 19. 05. 2010 [10:36]
registered since: 31.07.2008
Андрюха, ты чего. Мы с тобой уже это не раз делали.
Written on: 19. 05. 2010 [10:52]
andrelek
Андрей Полевой
Исходники отсюда
Checked out revision 1095.
Да делали, да я и сам несколько раз ставил, а тут затык такой что не пойму в чем дело, все вроде установил
yum.log на рабочей скаде смотрел, все и установил, а не идет. Думаю может новая revision 1095 требует чет новое
я бы у тебя Алексей спросил, но контакт из icq-клиента пропал кудато, а номер я не помню...
Written on: 19. 05. 2010 [11:23]
"andrelek" wrote:
Исходники отсюда
Дерево исходников значит таскаете между дистрибутивами с разной версией QT. Очистить всё нужно: "make distclean".
Written on: 19. 05. 2010 [12:12]
andrelek
Андрей Полевой
Спасибо Роман! Вы оказались правы, все установилось. Хотя я уже так делал и все работало, да и команду $ make distclean вначале выполнял.
Written on: 19. 05. 2010 [15:26]
Братан, я ж тебе и это показывал. Что-б ничего в следующий раз не забывать исполняй так
make distclean; autoreconf -ifv; ./configure --prefix=/home/andrey/OScadaD/ --disable-FireBird;make install
Путь только НЕ ЗАБУДЬ поменять.
30829
