[BugFixed] Не собирается Rev2151-2154
Written on: 23. 09. 2014 [16:03]
aNdrOS
Андрей
registered since: 07.05.2010
сборка ведётся на CentOS release 6.5 (Final)
gcc 4.4.7
[22:25:32][Step 1/1] libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../../../src -DQT_SHARED -I/usr/include/QtGui
-I/usr/include/QtCore -DQT_SHARED
-I/usr/include/QtWebKit -I/usr/include/QtCore -I/usr/include/QtGui -I/usr/include/QtNetwork
-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
-MT ui_Vision_la-vis_run.lo -MD -MP -MF .deps/ui_Vision_la-vis_run.Tpo -c vis_run.cpp  -fPIC -DPIC -o .libs/ui_Vision_la-vis_run.o
[22:25:32][Step 1/1] vis_run.cpp: In member function 'void VISION::VisRun::enterManual()':
[22:25:32][Step 1/1] vis_run.cpp:1010: warning: ignoring return value of 'int system(const char*)', declared with attribute warn_unused_result
[22:25:32][Step 1/1] vis_run.cpp: In member function 'void VISION::VisRun::cacheResSet(const std::string&, const std::string&)':
[22:25:32][Step 1/1] vis_run.cpp:1364: error: 'sort' was not declared in this scope
[22:25:33][Step 1/1] make[3]: *** [ui_Vision_la-vis_run.lo] Error 1
Written on: 23. 09. 2014 [17:56]
Похоже где-то заголовок "algorithm" не подтянуло, добавил прямо.
Written on: 24. 09. 2014 [15:23]
aNdrOS
Андрей
Спасибо, собралось!:)
11345
