[BugFixed] Краш при попытке выделить из строки элементы
Written on: 29. 12. 2011 [08:29]
yozhik
Алексей Николаев
registered since: 29.11.2010
Вылетает при попытке выполнить, к примеру, команду
".".slice(-3);
Лог:
1|/053G01A/sub_UI/mod_QTCfg/ | root| Нажат '/053G01A/sub_DAQ/mod_JavaLikeCalc/lib_terminal/fnc_test/%2fexec%2fcalc'!
Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'std::out_of_range'
what(): basic_string::substr
7|/053G01A/ | OpenSCADA прервана!
Programm result: 134
Written on: 29. 12. 2011 [08:52]
Исправлено.
11712
