Transport Sockets
Written on: 09. 03. 2016 [11:17]
BranKo
Branislav Kopun
registered since: 09.03.2016
Hi I'm newbie in OpenScada. I'm trying to create some communication with Simatic S7 PLC. But based on TCP socket layer (this conditions was done by partner owning Simatic).
Our OpenScada is on Linux and we are testing communication. I can test TCP communication on TCP level by Packet Sender Win utilities - it is working OK (send/receive).:)
Big problem is - how to read this data (from communication) in OScada? I mean to get data from socket..
Can I put this data to DB or some system/my variables in project ?
I tryied to create own project from cratch . As I said configuration od socket sommunication was withou problem but next step...
Written on: 09. 03. 2016 [12:27]
Then you need to start from the Quick Start
Read then documentation for the module DAQ.Siemens before, where you will understand about some parameter's template creation need.
And sure, for connection variant "ISO-TCP" you must a output Socket's transport to port 102 of the PLC host create.
25186
