Written on: 12. 11. 2023 [13:49]
jurdome
Jurgen Meyer
registered since: 27.10.2023
in Openscada what is the recommended way to store user settings? To put it simple - need to keep record of user entered Temeterature setpoint so that when power fails and system reboots same value could be retrieved and used again.
I think it could be done by creating TemplateLib java function to read/write some file on disk, or is there any other/better way to acheive this?
Written on: 12. 11. 2023 [14:39]
Parameters like to SP are stored not in SCADA but in PLC, which implements such regulators, obviously.
If this regulator is builtin to OpenSCADA like to simulators-models, then all its data is stored in the simulator storage — http://oscada.org/wiki/Special:MyLanguage/Using/Model_AGLKS
And read FAQ about that — http://oscada.org/wiki/Documents/FAQ#Physical_and_logical-virtual_data_acquisition
Written on: 12. 11. 2023 [21:22]
jurdome
Jurgen Meyer
Thanks for answer. Yes, decision making and storage is job of PLC, but this SCADA is so powerful that it can easily do that work also. I think I will make a separate RS485 module with microcontroller and EEPROM to store some parameters while decion making still assign to SCADA. Thanks a lot
