How to configure OpenSCADA to startup without QT / QTStart / QTConfig?
Written on: 02. 02. 2014 [00:31]
Philapol
Phila Pol
registered since: 24.12.2013
Under the Ubuntu (12.04 LTS) ARM embedded environment I require only the Web interface (WebCfg). There is no display on the embedded system. I have tried several things to try to prevent OpenSCADA from using QT. For example, changing openscada_start:
pCmd="openscada --ModDeny UI.QTStarter.so;UI.QTCfg.so --CoreDumpAllow --Config=./oscada.xml"
What do I need to do to make this work?
Written on: 02. 02. 2014 [11:50]
You do not need use openscada_* for that, but you can simple start OpenSCADA into daemon mode, by RC-script /etc/init.d/openscada, like: "$ /etc/init.d/openscada start".
10892
