[BugFixed] Fedora 11 - unexpected Final Started!
Written on: 18. 08. 2010 [17:53]
juliogallegos
Julio Gallegos
registered since: 18.08.2010
Hello,
I just downloaded the RPM packages for Fedora11 x86_64 and installed the complete bundle as shown at the end of this message.
When I run "openscada_demo", right after starting mod_VCAEngine module, the console displays the message "Final started!" and the application ends. As I see in this case there does not appear to be a clear reason of this unexpected application ending.
Could anyone please give me an idea about where to search for a reason for this?
thanks,
Julio Gallegos
openscada-0.6.4.2-1.fc11.x86_64.rpm openscada-Protocol-SelfSystem-0.6.4.2-1.fc11.x86_64.rpm
openscada-ARH-DBArch-0.6.4.2-1.fc11.x86_64.rpm openscada-Protocol-UserProtocol-0.6.4.2-1.fc11.x86_64.rpm
openscada-ARH-FSArch-0.6.4.2-1.fc11.x86_64.rpm openscada-server-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-BlockCalc-0.6.4.2-1.fc11.x86_64.rpm openscada-Special-FLibComplex1-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-DCON-0.6.4.2-1.fc11.x86_64.rpm openscada-Special-FLibMath-0.6.4.2-1.fc11.x86_64(2).rpm
openscada-DAQ-Gate-0.6.4.2-1.fc11.x86_64.rpm openscada-Special-FLibMath-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-JavaLikeCalc-0.6.4.2-1.fc11.x86_64.rpm openscada-Special-FLibSYS-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-LogicLevel-0.6.4.2-1.fc11.x86_64.rpm openscada-Special-SystemTests-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-ModBus-0.6.4.2-1.fc11.x86_64.rpm openscada-Transport-Serial-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-OpcUa-0.6.4.2-1.fc11.x86_64.rpm openscada-Transport-Sockets-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-Siemens-0.6.4.2-1.fc11.x86_64.rpm openscada-Transport-SSL-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-SNMP-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-QTCfg-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-Soundcard-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-QTStarter-0.6.4.2-1.fc11.x86_64.rpm
openscada-DAQ-System-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-VCAEngine-0.6.4.2-1.fc11.x86_64.rpm
openscada-DB-DBF-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-Vision-0.6.4.2-1.fc11.x86_64(2).rpm
openscada-DB-MySQL-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-Vision-0.6.4.2-1.fc11.x86_64.rpm
openscada-DB-SQLite-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-WebCfg-0.6.4.2-1.fc11.x86_64.rpm
openscada-demo-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-WebCfgd-0.6.4.2-1.fc11.x86_64.rpm
openscada-devel-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-WebUser-0.6.4.2-1.fc11.x86_64.rpm
openscada-doc-0.6.4.2-1.fc11.x86_64.rpm openscada-UI-WebVision-0.6.4.2-1.fc11.x86_64.rpm
openscada-plc-0.6.4.2-1.fc11.x86_64.rpm openscada-visStation-0.6.4.2-1.fc11.x86_64.rpm
$ openscada_demo
3|/EmptySt/ | Station <EmptySt> is not present in the config file. Use <DemoStation> station config!
1|/DemoStation/ | Load!
3|/DemoStation/ | Change work directory to '~/.openscada' error: No such file or directory. Perhaps current directory already set correct to '/home/jgallegos/.openscada'.
1|/DemoStation/sub_Special/mod_FLibMath/ | Connect module!
1|/DemoStation/sub_Special/mod_FLibComplex1/ | Connect module!
1|/DemoStation/sub_DAQ/mod_System/ | Connect module!
1|/DemoStation/sub_UI/mod_WebCfgD/ | Connect module!
1|/DemoStation/sub_Special/mod_SystemTests/ | Connect module!
1|/DemoStation/sub_DAQ/mod_JavaLikeCalc/ | Connect module!
1|/DemoStation/sub_BD/mod_MySQL/ | Connect module!
1|/DemoStation/sub_DAQ/mod_LogicLev/ | Connect module!
1|/DemoStation/sub_Transport/mod_Sockets/ | Connect module!
1|/DemoStation/sub_BD/mod_DBF/ | Connect module!
1|/DemoStation/sub_DAQ/mod_SNMP/ | Connect module!
1|/DemoStation/sub_Transport/mod_Serial/ | Connect module!
1|/DemoStation/sub_Protocol/mod_UserProtocol/ | Connect module!
1|/DemoStation/sub_DAQ/mod_DAQGate/ | Connect module!
1|/DemoStation/sub_Archive/mod_DBArch/ | Connect module!
1|/DemoStation/sub_Transport/mod_SSL/ | Connect module!
1|/DemoStation/sub_UI/mod_Vision/ | Connect module!
1|/DemoStation/sub_UI/mod_WebUser/ | Connect module!
1|/DemoStation/sub_DAQ/mod_Siemens/ | Connect module!
1|/DemoStation/sub_UI/mod_WebVision/ | Connect module!
1|/DemoStation/sub_Archive/mod_FSArch/ | Connect module!
1|/DemoStation/sub_DAQ/mod_SoundCard/ | Connect module!
1|/DemoStation/sub_Protocol/mod_HTTP/ | Connect module!
1|/DemoStation/sub_DAQ/mod_OPC_UA/ | Connect module!
1|/DemoStation/sub_Protocol/mod_OPC_UA/ | Connect module!
1|/DemoStation/sub_DAQ/mod_BlockCalc/ | Connect module!
1|/DemoStation/sub_DAQ/mod_ModBus/ | Connect module!
1|/DemoStation/sub_Protocol/mod_ModBus/ | Connect module!
1|/DemoStation/sub_DAQ/mod_DCON/ | Connect module!
1|/DemoStation/sub_Special/mod_FLibSYS/ | Connect module!
1|/DemoStation/sub_BD/mod_SQLite/ | Connect module!
1|/DemoStation/sub_UI/mod_QTCfg/ | Connect module!
1|/DemoStation/sub_UI/mod_WebCfg/ | Connect module!
1|/DemoStation/sub_UI/mod_VCAEngine/ | Connect module!
1|/DemoStation/sub_Protocol/mod_SelfSystem/ | Connect module!
1|/DemoStation/sub_UI/mod_QTStarter/ | Connect module!
3|/DemoStation/ | Change work directory to '/mnt/home/roman/work/OScadaD/share/OpenScada' error: No such file or directory. Perhaps current directory already set correct to '/home/jgallegos/.openscada'.
1|/DemoStation/sub_DAQ/mod_DAQGate/cntr_test/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_ModBus/cntr_testTCP/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_ModBus/cntr_testRTU/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_SNMP/cntr_localhost/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_Anast1to2node_cntr/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM102cntr/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM101/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM102/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_КМ202/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM201/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_Anast1to2node/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM301/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM302/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_JavaLikeCalc/cntr_testCalc/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_System/cntr_AutoDA/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_OPC_UA/cntr_test/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_SoundCard/cntr_test/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_LogicLev/cntr_experiment/ | Load controller's configs!
1|/DemoStation/sub_DAQ/mod_Siemens/cntr_test/ | Load controller's configs!
1|/DemoStation/sub_UI/mod_VCAEngine/ | Load module.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_doc/ | Load widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_mnEls/ | Load widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_AGLKS/ | Load widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_Main/ | Load widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_test/ | Load widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_originals/ | Load widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/prj_tmplSO/ | Load project.
1|/DemoStation/sub_UI/mod_VCAEngine/prj_AGLKS/ | Load project.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_doc/ | Enable widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_mnEls/ | Enable widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_AGLKS/ | Enable widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_Main/ | Enable widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_test/ | Enable widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/wlb_originals/ | Enable widget library.
1|/DemoStation/sub_UI/mod_VCAEngine/prj_tmplSO/ | Enable project.
1|/DemoStation/sub_UI/mod_VCAEngine/prj_AGLKS/ | Enable project.
1|/DemoStation/ | Start!
1|/DemoStation/sub_Transport/ | Start subsystem.
4|/DemoStation/sub_Transport/mod_Sockets/out_testOPC/ | Connect to Internet socket error: Operation now in progress!
4|/DemoStation/sub_Transport/ | Start output transport <testOPC> error.
1|/DemoStation/sub_DAQ/mod_DAQGate/cntr_test/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_ModBus/cntr_testTCP/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_ModBus/cntr_testRTU/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_Anast1to2node_cntr/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM102cntr/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM101/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM102/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_КМ202/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM201/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_Anast1to2node/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM301/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM302/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_JavaLikeCalc/cntr_testCalc/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_System/cntr_AutoDA/ | Enable controller!
4|/DemoStation/sub_Transport/mod_Sockets/out_HDDTemp/ | Connect to Internet socket error: Operation now in progress!
1|/DemoStation/sub_DAQ/mod_OPC_UA/cntr_test/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_SoundCard/cntr_test/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_LogicLev/cntr_experiment/ | Enable controller!
1|/DemoStation/sub_DAQ/mod_Siemens/cntr_test/ | Enable controller!
1|/DemoStation/sub_Archive/ | Start subsystem.
4|/DemoStation/sub_Archive/va_MemInfo_use/ | Archivator <DBArch.1s> error or it is not started.
4|/DemoStation/sub_Archive/va_CPULoad_load/ | Archivator <DBArch.1s> error or it is not started.
3|/DemoStation/ | No permition for create realtime policy. Default thread is created!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_Anast1to2node_cntr/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM102cntr/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM101/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM102/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_КМ202/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM201/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_Anast1to2node/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM301/ | Start controller!
1|/DemoStation/sub_DAQ/mod_BlockCalc/cntr_KM302/ | Start controller!
1|/DemoStation/sub_DAQ/mod_System/cntr_AutoDA/ | Start controller!
1|/DemoStation/sub_DAQ/mod_LogicLev/cntr_experiment/ | Start controller!
1|/DemoStation/sub_UI/mod_VCAEngine/ | Start module.
1|/DemoStation/ | Final started!
Programm result: 1
Written on: 19. 08. 2010 [10:50]
I don't see problems into start log and I can't check it by cause I have not this distributive.
Wait or write to the packages maintainer.
Written on: 19. 08. 2010 [19:09]
juliogallegos
Julio Gallegos
yes, the lack of an error message in the start log makes this app ending confusing and difficult to resolve.
I'm adding information about the environment on which it is being executed:
[jgallegos@localhost ~]$ file `which openscada`
/usr/bin/openscada: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, stripped
[jgallegos@localhost ~]$ uname -a
Linux localhost.localdomain 2.6.29.4-167.fc11.x86_64 #1 SMP Wed May 27 17:27:08 EDT 2009 x86_64 x86_64 x86_64 GNU/Linux
In the meantime I will install another Linux distribution in my VMware workstation.
thanks
Written on: 19. 08. 2010 [22:58]
juliogallegos
Julio Gallegos
I have just installed it on Debian 5 and the configuration form is displayed correctly after the "Final started!" message is shown on the console.
In the case of Fedora 11, that configuration form never comes up.
Written on: 21. 08. 2010 [18:05]
OK. Use other distributive. I haven't like problem at any used and OpenSCADA packaged by me distributives. And check problem on Fedora 11 x86_64 I can't by cause the distributive is too bad for me. I can't install the distributive from five tries with different errors.
Or write to Fedora 11 packager Aleksey Popkov
Written on: 23. 08. 2010 [16:41]
juliogallegos
Julio Gallegos
I just installed OpenScada Fedora 11 64-bits on a PC at home (Athlon X2) and it looks fine.
the difference between these two installations are:
at home: (the one which seems to be working correctly)
- it is real physical hardware
at work: (the one reported here)
- is running on a VM-ware workstation ACE edition 6.2
maybe the reason is the VM-ware machine.
Written on: 23. 08. 2010 [18:54]
I also install to Athlon X2. But the PC, also home, have not wide access to internet.
I see the problem and it into module UI.QTStarter. Possible version QT is broken.
Into work, with wide internet access, to Athlon 64 3000+ and P4 2600 Fedora 11 install have different errors. The PC is good and all other Linux distributives work fine.
I have not more time for resolve problem deeply for so bad distributive.
If you need it then take last revision from SVN-repository and try build it for Fedora 11 and check it.
Written on: 23. 08. 2010 [22:05]
Update your Fedora 11 from internet!
First version of QT in the distributive is 4.5.1 and allowed for update version 4.6.2 which binary incompatible. And OpenSCADA most likely builded in time version 4.6.2.
In any cases last SVN-revision of OpenSCADA build and start success at 4.6.2 of Fedora 11.
Written on: 24. 08. 2010 [17:14]
juliogallegos
Julio Gallegos
working fine now after updating Fedora11.
thank you for your assistance!
Jose J Gallegos
15539
