How resize the widgets.
Written on: 22. 08. 2012 [03:32]
OPMOTOR
OP MOTORS
registered since: 21.01.2011
Hello i want to create a GUI of my local technological process so I need to add visual components like
pipelines, cranes, valves, etc.
I know that in OpenScada there are widgets ready to use, and I want to use those on my GUI, but I need to know how can I resize the pre-ready widgets to fit a size optimum for my technological process screen, see the attached images as example.
For example how can I reduce the size of the pipe, valves ( picture 1 ) to looks like the pipes, valves of the ( picture 2 ).
Thanks a lot.
Picture A.png (File type: image/png, Size: 138.32 kilobytes) — 3191 downloads
Picture B.png (File type: image/png, Size: 193.02 kilobytes) — 3269 downloads
Written on: 22. 08. 2012 [09:22]
Taken from QuickStart manual:
HTML
The added elements can be subsequently positioned as needed by simply selecting and dragging them by the mouse.
Also you can change its size. Simple size changing will only resize the container widget geometry, what often needlessly.
For all widget's content geometry change it need to scale, what making by key "Ctrl" holding at the widget geometry change or
by toggle state "Resize" into statusline to "Scale.
Written on: 23. 08. 2012 [08:32]
OPMOTOR
OP MOTORS
Ok thank you so much, just a little detail.
when I download the file QuickStart from
ftp://ftp.oscada.org/OpenSCADA/0.7.2/doc/en/QuickStart.pdf
The information that you lead about the resize is not there!.. See page 41 / 71
Please check this detail. or update the QuickStart available file for download.
See you friends!!.
Written on: 23. 08. 2012 [09:33]
Version 0.7.2 have not supported already.
See to online http://wiki.oscada.org/HomePageEn/Doc/QuickStart , where always last by primacy.
26829
