Реализация Phonon бекенда для Media виджета
Written on: 28. 03. 2012 [23:09]
aleax
Alexey Bondarchuk
registered since: 27.01.2010
"gsxr" wrote:
Есть возможность организовать вещание прямо с ip камер. В наличии axis и evidence. Нужно?
Было-бы замечательно!
Written on: 02. 04. 2012 [12:36]
aleax
Alexey Bondarchuk
Реализовал переключение в fullscreen по двойному клику ЛКМ:
Index: src/moduls/ui/Vision/vis_shapes.cpp
--- src/moduls/ui/Vision/vis_shapes.cpp	(revision 1777)
+++ src/moduls/ui/Vision/vis_shapes.cpp	(working copy)
@@ -58,7 +58,7 @@
 #include "vis_shapes.h"
 #ifdef HAVE_PHONON
-#include <phonon/VideoPlayer>
+#include "vis_mediaplayer.h"
 #endif
@@ -1000,7 +1000,7 @@
 #ifdef HAVE_PHONON
-    VideoPlayer *player = dynamic_cast<VideoPlayer*>(shD->addrWdg);
+    MediaPlayer *player = dynamic_cast<MediaPlayer*>(shD->addrWdg);
     if(player)
 	if(shD->mediaType == 0 || shD->mediaType == 1)	{ player->deleteLater(); shD->addrWdg = NULL; }
@@ -1012,7 +1012,7 @@
     QLabel *lab;
 #ifdef HAVE_PHONON
-    VideoPlayer *player;
+    MediaPlayer *player;
 #endif
     bool up = true, reld_cfg = false;
@@ -1112,7 +1112,7 @@
 #ifdef HAVE_PHONON
-	    else if((player=dynamic_cast<VideoPlayer*>(shD->addrWdg)))
+	    else if((player=dynamic_cast<MediaPlayer*>(shD->addrWdg)))
 		if(shD->videoPlay)
@@ -1127,7 +1127,7 @@
 	case 30:	//roll
 	    if(shD->videoRoll == (bool)atoi(val.c_str())) break;
 	    shD->videoRoll = (bool)atoi(val.c_str());
-	    if((player=dynamic_cast<VideoPlayer*>(shD->addrWdg)))
+	    if((player=dynamic_cast<MediaPlayer*>(shD->addrWdg)))
 		if(shD->videoRoll) connect(player, SIGNAL(finished()), player, SLOT(play()));
 		else disconnect(player, SIGNAL(finished()), 0, 0);
@@ -1135,7 +1135,7 @@
 	    break;
 	case 31:	//pause
 	    shD->videoPause = (bool)atoi(val.c_str());
 		if(shD->videoPause && !player->isPaused()) player->pause();
 		if(!shD->videoPause && player->isPaused()) player->play();
@@ -1144,12 +1144,12 @@
 	case 33:	//seek
 	    if(shD->videoSeek == atof(val.c_str())) break;
 	    shD->videoSeek = atof(val.c_str());
-	    if((player=dynamic_cast<VideoPlayer*>(shD->addrWdg))) player->seek(shD->videoSeek);
+	    if((player=dynamic_cast<MediaPlayer*>(shD->addrWdg))) player->seek(shD->videoSeek);
 	    break;
 	case 34:	//volume
 	    if(shD->audioVolume == atof(val.c_str())) break;
 	    shD->audioVolume = atof(val.c_str());
-	    if((player=dynamic_cast<VideoPlayer*>(shD->addrWdg))) player->setVolume(shD->audioVolume);
+	    if((player=dynamic_cast<MediaPlayer*>(shD->addrWdg))) player->setVolume(shD->audioVolume);
 	    break;
 #endif
 	default:
@@ -1247,12 +1247,12 @@
 		//> Create player widget
 		if(!shD->addrWdg)
-		    shD->addrWdg = new VideoPlayer(Phonon::VideoCategory, w);
+		    shD->addrWdg = new MediaPlayer(Phonon::VideoCategory, w);
 		    if(shD->videoRoll) connect(shD->addrWdg, SIGNAL(finished()), shD->addrWdg, SLOT(play()));
 		    mk_new = true;
 		//> Set new data
-		player = dynamic_cast<VideoPlayer*>(shD->addrWdg);
+		player = dynamic_cast<MediaPlayer*>(shD->addrWdg);
 		if(!player) break;
 		MediaSource mSrc;
 		if(player->isPlaying()) { player->stop(); player->seek(0); }
@@ -1314,8 +1314,11 @@
     ShpDt *shD = (ShpDt*)w->shpData;
     if(!shD->en) return false;
+  //  qDebug() << event;
     switch( event->type() )
 	case QEvent::Paint:
 	    QPainter pnt( w );
Index: src/moduls/ui/Vision/vis_mediaplayer.cpp
--- src/moduls/ui/Vision/vis_mediaplayer.cpp	(revision 0)
+++ src/moduls/ui/Vision/vis_mediaplayer.cpp	(revision 0)
@@ -0,0 +1,36 @@
+#include <QMouseEvent>
+#include <phonon/VideoWidget>
+MediaPlayer::MediaPlayer( Category category, QWidget *parent ) : VideoPlayer( category, parent )
+    this->videoWidget()->installEventFilter(this);
+MediaPlayer::MediaPlayer( QWidget *parent ) : VideoPlayer( parent )
+bool MediaPlayer::eventFilter(QObject *obj, QEvent *event)
+     if ( obj == this->videoWidget() )
+         if( event->type() == QEvent::MouseButtonDblClick )
+	      QMouseEvent *mouse = static_cast<QMouseEvent *>(event); // mouseEvent
+	      if( mouse->button() == Qt::LeftButton )
+		    this->videoWidget()->setFullScreen( !this->videoWidget()->isFullScreen() );
+		    return true;
+	 return false;
+     else
+         // pass the event on to the parent class
+         return VideoPlayer::eventFilter(obj, event);
\ No newline at end of file
Index: src/moduls/ui/Vision/vis_mediaplayer.h
--- src/moduls/ui/Vision/vis_mediaplayer.h	(revision 0)
+++ src/moduls/ui/Vision/vis_mediaplayer.h	(revision 0)
@@ -0,0 +1,20 @@
+#ifndef VIS_MEDIAPLAYER_H
+#define VIS_MEDIAPLAYER_H
+#include <phonon/VideoPlayer>
+using namespace Phonon;
+class MediaPlayer : public VideoPlayer
+    Q_OBJECT
+    public:
+	MediaPlayer( Category category, QWidget *parent = 0 );
+	MediaPlayer( QWidget *parent = 0 );
+    protected:
+	bool eventFilter( QObject *obj, QEvent *event );
+#endif //VIS_MEDIAPLAYER_H
Index: src/moduls/ui/Vision/Makefile.am
--- src/moduls/ui/Vision/Makefile.am	(revision 1777)
+++ src/moduls/ui/Vision/Makefile.am	(working copy)
@@ -5,9 +5,9 @@
 ui_Vision_la_LDFLAGS = -module -avoid-version -no-undefined
 ui_Vision_la_SOURCES = tvision.cpp qrc_vision.cpp vis_widgs.cpp moc_vis_widgs.cpp vis_shapes.cpp moc_vis_shapes.cpp \
     vis_devel.cpp moc_vis_devel.cpp vis_devel_dlgs.cpp moc_vis_devel_dlgs.cpp vis_devel_widgs.cpp moc_vis_devel_widgs.cpp \
-    vis_run.cpp moc_vis_run.cpp vis_run_widgs.cpp moc_vis_run_widgs.cpp vis_shape_elfig.cpp moc_vis_shape_elfig.cpp
+    vis_run.cpp moc_vis_run.cpp vis_run_widgs.cpp moc_vis_run_widgs.cpp vis_shape_elfig.cpp moc_vis_shape_elfig.cpp vis_mediaplayer.cpp moc_vis_mediaplayer.cpp
 ui_Vision_la_DIST = tvision.cpp vis_widgs.cpp vis_shapes.cpp vis_devel.cpp vis_devel_dlgs.cpp vis_devel_widgs.cpp \
-    vis_run.cpp vis_run_widgs.cpp vis_shape_elfig.cpp vision.qrc
+    vis_run.cpp vis_run_widgs.cpp vis_shape_elfig.cpp vision.qrc vis_mediaplayer.cpp
 ui_Vision_la_LIBADD = $(QT4_LIB) $(LIB_FFTW3) $(phonon_LIBS)
 ui_Vision_la_LIBTOOLFLAGS = --tag=disable-static
@@ -35,6 +35,9 @@
 moc_vis_shape_elfig.cpp: vis_shape_elfig.h
 	$(QT4_MOC) vis_shape_elfig.h > moc_vis_shape_elfig.cpp
+moc_vis_mediaplayer.cpp: vis_mediaplayer.h
+	$(QT4_MOC) vis_mediaplayer.h > moc_vis_mediaplayer.cpp
 I18N_mod = $(oscd_modulpref)Vision
 clean-local:
Written on: 02. 04. 2012 [13:28]
Класс "MediaPlayer" тут вообще лишний, а использование eventFilter() можно сделать прямо и примеры там есть.
Written on: 02. 04. 2012 [14:30]
aleax
Alexey Bondarchuk
Ну в принципе да, но я класс заложил, что бы была возможность возможность построить граф объектов фонона по своему, и расширить возможности дефолтного Phonon::VideoPlayer.
P.S.: ну и не осилил я корректно "вклинится" в существующий код, потому пошел по пути наименьшего сопротивления (так как фича нужна была мне еще на вчера)
Written on: 03. 04. 2012 [11:35]
Osipetka
Пётр Осипенко
registered since: 27.03.2011
Отлично, полезный патч! Как раз то что нам было нужно!
Written on: 03. 04. 2012 [21:39]
Реализовал нормально!
Written on: 09. 04. 2012 [09:33]
gsxr
Андрей Ехлаков
registered since: 03.03.2010
При сборке версии 0.8:
vis_shapes.cpp:1253: ошибка: invalid use of incomplete type ‘struct Phonon::VideoWidget’
/usr/include/phonon/Phonon/../../phonon/videoplayer.h:41: ошибка: forward declaration of ‘struct Phonon::VideoWidget’
vis_shapes.cpp: In member function ‘virtual bool VISION::ShapeMedia::eventFilter(VISION::WdgView*, QObject*, QEvent*)’:
vis_shapes.cpp:1388: ошибка: comparison между разными указательными типами ‘Phonon::VideoWidget*’ и ‘QObject*’: отсутствует приведение
vis_shapes.cpp:1391: ошибка: invalid use of incomplete type ‘struct Phonon::VideoWidget’
make[5]: *** [ui_Vision_la-vis_shapes.lo] Ошибка 1
make[5]: Leaving directory `/home/sf/project/OpenSCADA/src/moduls/ui/Vision'
make[4]: *** [all-recursive] Ошибка 1
make[4]: Leaving directory `/home/sf/project/OpenSCADA/src/moduls/ui'
make[3]: *** [all-recursive] Ошибка 1
make[3]: Leaving directory `/home/sf/project/OpenSCADA/src/moduls'
make[2]: *** [all-recursive] Ошибка 1
make[2]: Leaving directory `/home/sf/project/OpenSCADA/src'
make[1]: *** [all] Ошибка 2
make[1]: Leaving directory `/home/sf/project/OpenSCADA/src'
make: *** [all-recursive] Ошибка 1
Written on: 09. 04. 2012 [09:45]
А выше почитать, прежде чем писать?
Это проблема ранего и текущего размещения заголовков Phonon, в директории "Phonon/*" и "phonon/*", соответственно.
Written on: 09. 04. 2012 [11:33]
gsxr
Андрей Ехлаков
Мне не поможет перечитывание моих собственный сообщений. В предыдущем случае сообщение об ошибке было другим.
Written on: 09. 04. 2012 [11:48]
Если поменять оба инклуда то поможет. Вы думаете как у меня для Ubuntu 10.04 собрано?
60303
