What is oscada's development environment?
Written on: 05. 02. 2015 [05:06]
yaraba
yaraba seo
registered since: 05.02.2015
What is your oscada's development environment?
- Do you use IDE for coding and debugging?
- Do you use static analysis tools?
- Do you use Design tools for QT or Web module?
I am a oscada starter.
Thanks in advance!
Written on: 05. 02. 2015 [08:43]
For developing exclusively into OpenSCADA, for self projects into the creation, you do not need any external IDE but OpenSCADA has all you wanted!
For same OpenSCADA developing you also do not need any external IDE but the developing independent from any IDE and simple text editor for that enough. Sure if you too want you can bind OpenSCADA sources tree to any like IDE/RAD which knows about program based at "autotools" building. See here for building: http://wiki.oscada.org/HomePageEn/Doc/BuildFromSource
I am best source code analysis tool and I do not need for some else. :)
For memory debug I some time use valgrind.
For external or new source code format can be used command:
$ indent -bli0 -i4 -ts8 -l100 -npsl -npcs -nprs -nsaf -nsai -nsaw -brs -br -cdw -nbc -lp <filename>
I do not but OpenSCADA has self transparent for Qt-based and Web-based interfaces generic development environment: http://wiki.oscada.org/HomePageEn/Doc/VCAEngine
But sure the possible for using some like.
Are you starter as user or as developer? :)
Any way see before here please:
- http://wiki.oscada.org/HomePageEn/About
- http://wiki.oscada.org/HomePageEn/Function
- http://wiki.oscada.org/HomePageEn/Doc/QuickStart
51136
