json library
Written on: 08. 04. 2025 [23:07]
arccis
Arkadii Kysil
registered since: 18.11.2023
Hello everyone. I have implemented some functions for working with json. In the attachments there is a project with json.db. There is also a set of json files and a python script for checking the functions.
About json: https://www.json.org/json-en.html
Main functions is:
areBracketsBalanced
decode_unicode_esc (decode /uXXXX to UTF8-symbol )
encode_unicode_esc (ecode UTF8-symbol to /uXXXX )
deserialize (load/import object from string)
getOneValue (get Value without recursion)
pretty (structured text like tree + decode \uXXXX)
searchFirstJson
serialize (save/export object to string)
I am not a professional programmer, but I tried to cover all the code with tests. I will gladly accept comments.
json.zip (File type: application/zip, Size: 28.36 kilobytes) — 585 downloads
Written on: 10. 04. 2025 [09:48]
That is are you about "comments" or you want to include this in the standard OpenSCADA libraries?
If you are about the first, then I have no need in json right now for throw down all other and start to develop-debug-test your code. :)
If you are about the second with documenting and following support yourself, then say that directly, go to http://oscada.org/wiki/Special:MyLanguage/Documents/How_to/Create_module and satisfy the requirements!
PS: I am going to expand shortly the document by a part of the code creation for internal libraries with User API, but most the requirements there is actual.
Written on: 11. 04. 2025 [15:41]
arccis
Arkadii Kysil
ok, I'll read the requirements and write documentation for the functions like in other OpenSCADA libraries. By comments I meant feedback from people who will use the library.
Written on: 27. 03. 2026 [17:35]
OK, I have included the library to the standard OpenSCADA libraries without your documenting as is, due to your mention "License: GPLv2"!
And I have tested only deserialize(), which works, but you must not to include temporary internal variables "str" and "i" to the function arguments!
51165
